First Time Tacoma Owner Suspension Upgrade
Discussion in 'Suspension' started by Gflo488, Mar 17, 2021.
  1. Mar 17, 2021 at 11:29 PM
    Gflo488
    Gflo488 [OP] New Member
    Gabriel
    2014 White Tacoma TRD Offroad
    As the title says I am attempting to upgrade my suspension for the first time in my life. I will be honest I do not know the most but I am definitely here to learn. I have spent the last couple of weeks reading through forums on this site but decided to finally make an account and ask for some help. I do a lot of offroading but currently feel limited due to my truck being completely stock and I am looking to change that. I am looking to do a complete suspension upgrade and ideally would like to keep it under $2,000 before taxes and shipping.
    1. I want a 3-inch lift but I have seen that this is somewhat of a controversial topic on some threads. The roads near where I live tend to lead to a fair amount of bottoming out and I am looking to fix that. Some places mention that a lift may not help that. Is a 3-inch lift useful or overkill?
    2. I would like to upgrade to 33s because I have heard that the wheel size is important in raising the overall height of your vehicle. But I have also heard that 33s tend to lead to a lot of rubbing which is something I would like to avoid. I am willing to cut away and make adjustments if this is possible. Is it better to get a size smaller than 33s? Are we speaking 32s or 31s? I would also like to get a small offset. Does an offset help with rubbing?
    3. With this being my first time I am not the most educated on quality brands. Currently, I am looking at an Old Man Emu 3 Inch Lift Kit. Now while this is what I am looking at this is not what I am sold to. I have heard great things about OME, Bilsteins, Fox, and King. I would like to hear any opinions that y'all have on these different brands.
    Any help or guidance will be greatly appreciated. These forums seem like a great place to learn within a kind community and I am proud to finally join the club. Thank you all for your time and consideration.
  2. Mar 17, 2021 at 11:41 PM
    tcjacado
    tcjacado Well-Known Member
    Welcome to tw...
    3" is not a guarantee, if you have added weight, then it will sag to 2.5 to 2 inch, which is perfectly fine.
    I would look into toytec or old man emu springs and bilstein 5100s or 6112s.
    You will get lots of options on here, but almost nobody has tested every suspension option. Its your butt dyno that matters, not mine.
  3. Mar 18, 2021 at 7:30 AM
    JC713
    JC713 Well-Known Member
    2021 Tacoma SR5
    Welcome! and as you have seen there is lots of information on this topic(maybe too much lol).
    OME makes quality stuff, I have the 2" lift.
  4. Mar 21, 2021 at 3:03 AM
    Sumo’s_Taco21
    Sumo’s_Taco21 Active Member
    James
    Somewhere in the 818 valley …bruhh
    Blk beauty 2 lifted edition
    Eibach stage 1 lift kit, torch off road AAL, Mishimoto intake pipe, K&N drop in filter, PEDAL commander. 55w HID’s FUEL off road 18x9’s. EIBACH UCA’s and Reservoir shocks coming soon.
    I’m a first time lifter as well and I’m trying to decide between Rough Country or Eaibach’s stage 1 ..only thing about Eaibachs. Is that it’s not a complete kit.
  5. Mar 21, 2021 at 3:28 AM
    Mmaira2018
    Mmaira2018 Well-Known Member
    Rough country is crap. I know its cheap but you'll be replacing the shocks and springs quickly if you do a lot of off roading. If you want the lift for the look then by all means go RC. But if you actually want a lift with true suspension upgrades stay away. From what I've heard from the guys who went RC the first time, it was worse than stock and they ended up replacing it anyway. Some complaints were that the truck dove hard into corners, shimmied from bumps or whoops, and got wobbly at high speed. Doesn't sound like a fun time to me.
  6. Mar 21, 2021 at 3:37 AM
    Mmaira2018
    I have the OME 3in with dakar heavies and love it. I have about 400lb of add-ons which is why I went the heavy route.
    If you want to run 33s or even fat 32s, you'll need to do a cab mount chop. You *might* not have to if you run pizza cutters (tall/skinny) which would depend on your offroad needs.
    You'll also need new uca's because the stock ones won't give you the down travel needed for a 3in lift. They'll rub your springs and also not allow proper alignment if not replaced.
    You'll also most likely need to replace the needle bearing with something like the ECGS bushing, otherwise you're potentially sitting on a ticking time bomb. Also depending on how much you flex out the rear suspension you'll want to extend your back brake lines too.
    I can't think of anything else off the top of my head but those are all things that should also be factored into your cost. I was able to do the OME lift in my driveway with the help of a buddy and an impact gun. Took us about 10 hours start to finish.
  7. Mar 21, 2021 at 12:26 PM
    Dalegribble02
    Dalegribble02 Well-Known Member
    Savona British Columbia
    2014 SR5 4x4 meg grey sold
    Dobinson mrrs Deaver leafs archive garage hammer hangers.
    I vote a dobinsons mrr set up way better then ome or crap country
  8. Mar 22, 2021 at 8:02 AM
    Sumo’s_Taco21
    James
    Thanks for insights.
    Mmaira2018[QUOTED] likes this.
  9. Mar 22, 2021 at 8:08 AM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Im getting the Eibach 2.0 kit for $1k
    Its comes with adjustable coilovers for the front
    dakar leaf pack in the back with cost you about $500 so thats $1500 for a decent 2.5 inch lift
    I decided on monotube shocks rather than twin tube because they wont get aeration inside the shock which leads to rougher ride and more body roll
  10. Mar 23, 2021 at 9:32 PM
    Sumo’s_Taco21
    James
  11. Mar 23, 2021 at 9:46 PM
    Sumo’s_Taco21
    James
    Yeah.... I’ve decided on the EiBaCH kit stage-1. W/ 1in rear lift blocks. I mean for the price point and quality you can’t go wrong... aside from that I really didn’t want to go higher then 3in leveled. I would have gone with TOYTECH set up but I don’t think ill be doing that much off-roading. I think ill be good w/2.5 lift leveled for now at least ....
    Now comes the fun part ..wheels & tires ...??
  12. Mar 24, 2021 at 6:24 PM
    gudujarlson
    gudujarlson Well-Known Member
    Minnesota
    2020 TRD Off-Road DCSB 6MT
    Kings, Dakars, SPCs, 33's, Mobtown Sliders, TRD Skid
    1. Why do you think you are “bottoming out”? It’s hard to hit your bump stops on a road unless you try hard. Even if that is actually happening to you, increasing your ride height might not be the solution. Beefier shocks might be the answer though.
    2. Wheel diameter is important for getting over obstacles and increasing traction. It increases your ground clearance and angle of attack when driving over rocks, logs, etc. There are a lot of trade offs though. If you aren’t getting high centered, dragging your hitch receiver over rocks, bashing your front splash guard, etc, you probably don’t need 33’s.
    I’m guessing you should drive the truck stock until you know what you really need.
