First Timer Looking At Long Travel
Discussion in '3rd Gen. Tacomas (2016-2023)' started by nate_the_reptile, Oct 20, 2017.
  1. Oct 20, 2017 at 2:52 AM
    nate_the_reptile
    nate_the_reptile [OP] Think I can clear that
    Nate
    US of A
    2017 DCSB OR 6MT
    I just want to be done.
    Hello,
    First off I did quite a bit of research and I think Ive finally came up with the kit, shocks, rear suspension, etc I want to install. This is mostly for peoples inputs and advice to a beginner.
    Truck- 2017 DCSB TRD OR
    3.5" Dirt Kings LT Kit w/ extended CV axles
    King Shocks front and rear w/ Comp Adjuster
    Dakar Leaf Spring Pack
    Road Runner 4" Bulge Fenders
    Want it to sit on 33"/12.5"/17"
    Looking at Tire- KO2s
    w/ Method Double Standard wheels
    If i am missing anything please let me know.
    Thank you !
    Radarninja likes this.
  2. Oct 20, 2017 at 3:52 AM
    splitbolt
    splitbolt Voodoo Witch Doctor
    NW Arkansas
    2016 TRD OFFROAD DCSB MGM
    What's the plan to long travel the rear?
    Coot83 and Joe23 like this.
  3. Oct 20, 2017 at 6:39 AM
    nate_the_reptile
    Nate
    US of A
    2017 DCSB OR 6MT
    Just the King Shocks and and Dakar Leafs.. I was looking at the TC Mid travel Kit for the rear but thats an extra 1.5k and thats diving a little further in my pockets than id like to right now. I was told that the rear end will be able to keep up with the bigger leafs and kings.
  4. Oct 20, 2017 at 6:56 AM
    Joe23
    Joe23 Canuckistikian
    The Great White North
    2017 TRD Off-road DCSB
    You'll need new mount points to really get any out of the rear.
    I feel there's a lot missing here.
  5. Oct 20, 2017 at 6:57 AM
    ChadsPride
    Sponsored by TacomaWorld.com
    Coot83 likes this.
  6. Oct 20, 2017 at 7:04 AM
    nate_the_reptile
    Nate
    US of A
    2017 DCSB OR 6MT
    Everything im getting is OEM the rear end the shocks and leafs come with the larger U bolts. Im mostly getting the rear end to level the truck back out as the Kings up front will lift the truck about 3 in.
    The kit is...
    http://shop.dirtkingfabrication.com/Long-Travel-Kit-DK-811908.htm
    Includes:
    Boxed upper arms• WSSX16T stainless steel uniballs
    • Pollyurethane bushings
    • Zinc plated bushing washers
    • Grease fittings for easy servicing
    • 3/16" boxed plate construction
    Boxed lower arms
    • Bump stop plates
    • Limit strap tabs
    • Bypass tabbing
    • Delrin bushings
    • 3/16" & 1/8" boxed plate construction
    • Internally ribbed with extrusions for weight reduction
    8" quad wrapped limit strapsWeld on adjustable limit strap mounts
    17-4 stainless steel misalignment spacers
    17-4 stainless steel tie rod extensions
    DOT approved extended brake lines Grade 8 mounting hardware
    Bump stop spacers
    ChadsPride likes this.
  7. Oct 20, 2017 at 7:09 AM
    Radarninja
    Radarninja Safety 3rd
    Northern California
    06 taco
    Chromed out radiator cap
    Cam tab gussets, spindle gussets, coil buckets gussets. Hydro bumps for the rear would be nice.
    I'll think of more shit later.
  8. Oct 20, 2017 at 7:10 AM
    Radarninja
    Northern California
    06 taco
    Dmz...
  9. Oct 20, 2017 at 7:13 AM
    Coot83
    Coot83 DORKEL NATION
    Scottsdale, Az
    2012 Baja TX
    TC 3.5 LT, RCV axles, Demello sliders, BD light bar/fogs, LP6, DMZ rear, SOS skids, custom bumper, King 16" triples, Locked-on hydro rear bumps...
    Just to give you some insight...I got the TC 3.5 LT kit on my front with the TC mid travel SUA on the rear with relocated 12s. The mid travel SUA in the rear severly limits my front due to it flying all over the place. If you don't want to LT the rear, then you don't need a 3.5 as you wont ever get the use out of it...especially with an SOA rear. I would look into a 2+ kit which doesn't require glass fenders and stuff as you can just slightly trim up your stock fenders for that. I assume you want LT for better overlanding stuff? 3.5 is for the guys who like the high speed driving and flying through whoops and stuff...not that you cant do that in a 2+, but obviously you wont have the same travel and articulation as a 3.5.
    jeff b and ChadsPride like this.
  10. Oct 20, 2017 at 7:16 AM
    Joe23
    you're going through all that but not doing a U bolt flip kit and new bump stops?
    I haven't heard much about the dirt kings UCAs and LCAs, but for what its worth the best on the market to use is the Total Chaos.
    I have the TC UCAs they're amazing.
    Might have mentioned it and I missed it but what about your fenders? you'll need new front fenders.
    spacers for the back to keep the wheel track the same? Your front will be wider than the rear.
  11. Oct 20, 2017 at 7:17 AM
    nate_the_reptile
    Nate
    US of A
    2017 DCSB OR 6MT
    Thank you. So I got a hell of a deal on the DK 3.5 Travel Kit thats what made up my mind. my original plan was the TC 2" standard kit but I Can get the DK kit with the built CV axel for the same price as just the TC 2" Kit. But the I cant find any input on the DK kit. Like i said i am pretty new to this scene so Thank you guys for all the info.
  12. Oct 20, 2017 at 7:17 AM
    Joe23
    This
    Unless you're doing desert racing and going off jumps etc, don't see the point in doing LT.
    You'd be better off doing a mid travel set up.
    rlx02 and ChadsPride like this.
  13. Oct 20, 2017 at 7:18 AM
    Joe23
    probably because the TC kit is a lot better lol.
  14. Oct 20, 2017 at 7:21 AM
    Joe23
    what can you do to get more out of the rear.
    I've got fox extended travel, so mid travel set up and I know for sure my rears are being held back right now.
  15. Oct 20, 2017 at 7:27 AM
    nate_the_reptile
    Nate
    US of A
    2017 DCSB OR 6MT
  16. Oct 20, 2017 at 7:28 AM
    ChadsPride
    Replace the AAL with full leaf packs
    The stocks are trash
    Thank me later
    Masshole_And_His_Taco and jeff b like this.
  17. Oct 20, 2017 at 7:35 AM
    Joe23
    that's very similar to my set up. just I have Fox all around and dakar leafs not a stupid toytec add a leaf.
    Long travel is a bit much just for rock crawling. Its more meant for racing and jumps. It would work for crawling but then again at the same time, real crawling is best with a solid axle and coils all around for better articulation.
    For what its worth this is from the recent trip I did.
    Check the time stamps you can see some of the 'crawling' https://www.youtube.com/watch?v=IzR0w5SM2Rk
    The spot at 18min I took different lines that were much harder for the fun aspect lol. we needed that bypass because the water swallowed the front of a 93 dodge ram with a 6" lift on 35s.
    From what I heard from all the others on the trail, I had pretty decent flex going in the back and travel from the rear.
    There's more pics in my build thread too and you can see full set up of what I've done.
    If that's similar to what you want to do mid travel might be better off as its the best of both worlds and still keeps some on road driveability
  18. Oct 20, 2017 at 7:36 AM
    Joe23
    lmao ya thats pretty much what I figured.
    I started looking into it when I first did my suspension but not sure what route to go.
    Right now I've just got fox 2.5 extended in the rear and dakars. I know its for sure limited on what it can do. Hell front is probably limited as well on what I can do.
    But I spent a lot already and have it as is for now. Might add to it later down the line just not sure what to do. Besides welding on new shock mounts etc
  19. Oct 20, 2017 at 7:37 AM
    Mxpatriot
    Mxpatriot Well-Known Member
    '06 4x4 AP LT and Locked
    Read the FAQs in the LT forum.
  20. Oct 20, 2017 at 7:39 AM
    Joe23
    build thread.
    its in signature
    jeff b[QUOTED] and ChadsPride like this.
