First Toyota in 25 year
Discussion in '1st Gen. Tacomas (1995-2004)' started by Tline155, Sep 14, 2023.
  1. Sep 14, 2023 at 1:58 PM
    Tline155
    Tline155 [OP] Member
    2003 Red Tacoma TRD
    Hello,
    Well after my brother flipped my 1st Gen 4Runner on its roof in 1998, I finally have another Toyota. Well I didn't have to really own a vehicle for the last 15 years due to work, but that has changed and I am excited to start customizing my new Toy.
    2003 Tacoma 4-Door
    I don't know much about the truck, been out of the game to long.
    Looks to already have some custom aftermarket cosmetics.
    Suspension looks like maybe a stock 2.5" with blocks?
    Any tips on what should be the first things to check out or upgrade would be awesome.
    det107 and Cortez the Killer like this.
  2. Sep 15, 2023 at 11:49 AM
    Potomus Pete
    Potomus Pete Love my little truck
    Hippy
    Sarasota Florida The Great Place To Live.
    1999 Prerunner single cab. With a BO7A rear end
    All kinds 3 inch body lift/2 1/2 suspension lift. 31/11 1/2/15 tires All work done by myself for years. The only work performed by mechanic was fuel pumps. I also have a 90 Mustang 350 hp and I can never understand how come my Tacoma gets more respect Just got a 99 Jeep TJ that I rebuilt, and painted in the garage
    Looks good. How about the part of the frame that goes over the rear axle.
  3. Sep 15, 2023 at 12:34 PM
    Red_03Taco
    Red_03Taco Well-Known Member
    Jerad
    2003 Tacoma Xtra Cab 4WD
    I'd start with replacing all fluids (brake fluid, coolant, ATF, gear oils, power steering fluid, engine oil). I'd attack them in roughly that order. Then I'd check brakes and bushings. Safety and reliability first.
    Edit: Add lower ball joints near the top of the list. Only use Toyota OEM for these.
  4. Sep 15, 2023 at 4:49 PM
    Tline155
    2003 Red Tacoma TRD
    Like this?
  5. Sep 15, 2023 at 4:50 PM
    Tline155
    2003 Red Tacoma TRD
    Great suggestions. Definitely a good fluid job is a must.
  6. Sep 15, 2023 at 5:23 PM
    Potomus Pete
    Hippy
    Looks acceptable..Nice color. Im sure you have read up on ball joints and tie rods. If not be sure to do it.
  7. Sep 15, 2023 at 5:25 PM
    Potomus Pete
    Hippy
    Id consider a two inch body lift. The tires are fillin up those holes to the point it might bottom out
  8. Sep 15, 2023 at 5:48 PM
    Cincy Tacoma
    Cincy Tacoma Well-Known Member
    Cincinnati, Ohio
    Welcome to TW.
  9. Sep 15, 2023 at 7:06 PM
    redneck_adjacent
    redneck_adjacent Well-Known Member
    Bellevue, WA
    1997 Tacoma 2.7L 4x4 W59 MT
    5 PSI supercharger 3" lift Bilstein 5100 shocks Old Man Emu springs General Spring leaf springs with 2" blocks and extended shackles 31" Firestone Destination XT tires LCE header and catback exhaust HPS CAI Tundra S13WE front brakes KC HiLites flood, ditch, fog, and backup lights Eaton Bussmann relay/fuse panel with custom power tray All Pro bumpers, sliders, and skid plates
    I presume this truck has the six cylinder engine?
    If so - I cannot be of much help. I know far more about the 3RZ.
    Nevertheless, a few things:
    - Upgrade your battery cables. The factory battery cables are terribly small. So small, in fact, that I personally regard them as a fire hazard. Check out the "Big 7" kit.
    - Invest in an aftermarket oil pressure gauge. It's a crucial metric which you should monitor.
    - ScanGauge2, similarly, is also a wise investment.
    - Frame rot is a known issue for these trucks. You are in the Pacific Northwest so it is less of a concern. Nevertheless, consider coating the frame with Waxoyl, Eastwood, or something else.
    Those are some tips off the top of my head.
  10. Sep 15, 2023 at 9:11 PM
    Tline155
    2003 Red Tacoma TRD
    I surely want to lift it another 2 to 3 inches. I am just not sure what if anything g it already has.
    If definitely has blocks in the back so I am not sure if that is considered a 2" lift already.
    I been looking at lifts and most are like a 3" coils and leafs. So I'm not sure if that will give me more lift or just replace my height with better equipment.
    Lots of options.
  11. Sep 15, 2023 at 9:14 PM
    Tline155
    2003 Red Tacoma TRD
    Yes it for the V6.
    Great advice on the battery cables. I'll be sure to take a look and note that this weekend.
  12. Sep 15, 2023 at 9:20 PM
    redneck_adjacent
    Bellevue, WA
    Something else. You might want to delete that bull bar. Those bars tend to worsen damage in collisions. If you want armor then look into a steel tube bumper instead. Baja trucks use those for a reason. ARB is great but plate steel is less sturdy.
  13. Sep 16, 2023 at 2:46 PM
    Tline155
    2003 Red Tacoma TRD
    I will say it looks super clean with out it!
  14. Sep 16, 2023 at 3:33 PM
    Tline155
    2003 Red Tacoma TRD
    Ok. Off with the plastic steps.... lol
    Hope to add a nice bad in future but this looks better for now lol.
  15. Sep 16, 2023 at 4:23 PM
    Cloud99
    Cloud99 Well-Known Member
    Georgia
    1999 Tacoma SR5 TRD 4x4
    So much better without the steps.
    Potomus Pete likes this.
  16. Sep 16, 2023 at 4:34 PM
    e_engstro
    e_engstro Well-Known Member
    Eric
    Arizona
    2019 Tacoma TRD Off-Road 4x2
    The paint seems to be in pretty good shape at least from the pictures you've posted
  17. Sep 18, 2023 at 4:45 PM
    Potomus Pete
    Hippy
    Much better....Now like some are thinking. buff it out....Maybe Clay Bar
