First toyota I've owned are they all prone to wear parts fast
Discussion in '2nd Gen. Tacomas (2005-2015)' started by timboslice85, Jul 2, 2020.
  1. Jul 2, 2020 at 11:06 AM
    vtown
    vtown Well-Known Member
    CT
    09 Access TRD OR 4x4 V6 6spd
    That doesn't sound too bad. Plugs and brakes are regular maintenance (little early for rears). Yes the front wheel bearings are shit. My drivers when out at 90k, passenger side at about 105k. AC sounds like bad luck. Make sure you lube the drive shaft u-joints regularly, I kinda forgot about them for a few years and needed them replaced at 100K.
    Only other thing I needed was new exhaust at 115K (pin hole leak in the can made it sound crappy). Other than that, this truck is a good as the day I bought it new.
    timboslice85[OP] likes this.
  2. Jul 2, 2020 at 11:29 AM
    Larzzzz
    Larzzzz Grande' Ricardo
    Larry
    MA
    '06 dclb 350+ kmiles
    Aux back up lights, Bed lights, Re-located trailer plug, Good dooby, a.k.a. jumper cable mod, Heated seats, back up camera,
    Plugs.....maybe. My brakes at 100,000 miles still had lots of life left in them, but replaced anyways with new rotors as well.
    The rears got replaced around 150k due to an axle seal leaking.
    Went OEM pads and Napa drums and rotors.
    Just to add: other than maintenance/wear items, this truck has been amazingly reliable.
    The motor popped the head gasket somewhere around 235k, months after a new frame install. Couldn't not get a motor for it.
  3. Jul 2, 2020 at 12:04 PM
    timboslice85
    timboslice85 [OP] Member
    Timothy
    11 raptor lined tacoma prerunnerI
    I
    Lol yeah the big company beers just don't cut it anymore
    m603holden and whatstcp like this.
  4. Jul 2, 2020 at 12:10 PM
    TnShooter
    Deogee
    07' TRD Off-Road, Auto
    STOCK
    I replace my wheel bearings @ roughly 100k
    Front pads around 70k. I replaced them with Ceramic pads, still going on those now.
    Still rolling on the Stock rear shoes. @128k
    I bought my truck used with just under 30k on it.
  5. Jul 2, 2020 at 12:26 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Sparks plugs do not need to be done every 30k.
  6. Jul 2, 2020 at 12:40 PM
    Larzzzz
    Larry
    MA
    The v6 is spec'd out for every 30k. My understanding is with the SC, some plugs are inaccessible when installed so they put irridium plugs in.
    Why they use copper plugs in the v6...:notsure:
  7. Jul 2, 2020 at 1:05 PM
    vtown
    CT
    I did my plugs at About 60 and 120k with the 4.0, only because that’s when I got around to it. I can tell you the engine was starting to ping at about 110, and the new factory plugs solved the issue
  8. Jul 2, 2020 at 1:27 PM
    Marshall R
    Marshall R Well-Known Member
    Marshall
    07 White TRD double cab
    none
    My F150 got new front pads at 83,000 miles. The Tacoma has only had rear pads replaced once in 205,000 miles, done at 170,000. I have put new pads on the front twice, so I'm averaging about 70,000 miles on front pads. The rotors and drums are factory.
    I don't know of any newer vehicle where plugs don't last 100,000 miles anymore.
  9. Jul 2, 2020 at 2:42 PM
    GrundleJuice
    GrundleJuice Well-Known Member
    Michigan
    2016 TRD Bro
    [S]Un-Molested[/S] Lightly Molested
    I pulled mine at 60k, they were so far past worn it was laughable.
    Many (most?) newer vehicles have platinum/iridium plugs from the manufacturer. Toyota specd the 4.0 v6 with copper.
  10. Jul 2, 2020 at 2:43 PM
    gotoman1969
    Did mine at 60 and looked fine. But I stand corrected the manual does say every 30k.
  11. Jul 2, 2020 at 4:41 PM
    Too Stroked
    Too Stroked Well-Known Member
    Tom
    South shore of Lake Ontario
    2021 4Runner SR5 Premium
    Just a quick reminder that the kind of parts you put in to replace the worn out OEM (I'm assuming they were OEM) parts can make a huge difference in how long something lasts. Generally speaking, OEM parts will far out last aftermarket parts.
  12. Jul 2, 2020 at 4:45 PM
    knayrb
    knayrb Well-Known Member
    Bryan
    Somewhere in the square states
    2010 Dbl-Cab Off-Road
    Pure stock
    I think the wheel bearings are very unusual for a stock truck. Might are still tight and quiet at 158k miles
    BillsSR5 likes this.
  13. Jul 2, 2020 at 5:00 PM
    winkel
    winkel Well-Known Member
    Corydon, IN
    2014 Spruce Mica, TRD Off-Road, 6 Spd Manual
    Sliders, Tailgate Liner
    I just rolled over 97,000 and am still on original brakes. A couple of months ago, I pulled the rear drums, cleaned and re-lubed everything, sanded the ridge out of the inside of the drums, painted and re-installed them. The still looked good and I use my parking brake religiously. My front pads are getting thin but my rotors are still smooth and no vibration. I have a new set of Power Stops, rotors and pads in the garage, but have been busy with home improvements so will get to those in the next couple of months. I'm still on original wheel bearings too, but think I'm starting to hear the slightest bit of noise on sweeping left hand turns.
    It really does depend a lot on how the previous owner drove it. The A/C compressor thing sucks but that varies from one to the other.
    Don't get discouraged, overall these are good trucks.
  14. Jul 2, 2020 at 7:17 PM
    centurion
    centurion Well-Known Member
    Northern New Jersey
    2006 Tacoma TRD Sport,double cab, 4X4, auto, speedway blue
    Air-Raid air filter, de-badged,custom grill,hood and tailgate struts
    My 06 has been great, very reliable, just take care of your taco and it will take care of you. My a/c was blowing hotter than the ambient temp, brought it in to a local guy, he oiled the compressor, and charged it, it's now blowing colder than when I first bought it. My rear shoes are original, they did have to be cleaned and lubed, have 120k on the odo still riding on original wheel bearings, just need to do the needle bearing soon but not expensive if you do it yourself.
  15. Jul 2, 2020 at 8:11 PM
    #35
    Sprig
    Sprig Well-Known Member
    Ken
    N. Calif. The Twilight Zone
    Tacoma TRD double cab 4x4, Barcelona Red
    Buying a 10 year old vehicle is always a crap shoot. You know nothing about how it was driven, where it was driven and maintenance. You have zero, nada, zilch to complain about other than maybe the wheel bearings. Yeh there will be other things going wrong or breaking too but that’s kind of what one expects when you buy a 10 year old vehicle and have little or no knowledge about its history.
    Nick2014, BillsSR5 and Blockhead like this.
  16. Jul 3, 2020 at 12:00 AM
    #36
    Luis1
    Luis1 Well-Known Member
    Alberta, CA
    2013 Tacoma DCLB TRD SPORT 4x4
    - OME 2.5 inch lift nitro charger with 886 coils in front and 2 inch lift OME nitro charger with heavy Dakar leaf pack - custom high clearance rear steel bumper with swing out made by Vertan Kustoms out of Alberta. Carts full size spare and 2 x 20L Jerry cans - Allpro Apex front bumper - Smittybilt 10000lbs winch w/ synthetic line - Dobinsons Snorkel - RA Motor sports roof rack and bed rack - 5 x 6inch Diode Dynamic light bars on roof - 2 x unknown brand ditch light pods - 5 x 285/70/17 BFG Ko2 - 5 x Black Rhino Stadium wheels - deep dish - 17x9.5 with - 18 offset - exhaust chop mod - rear seat delete - horrendous mpgs lol
    Believe it or not I just went past 130,000 km on my original brake pads. I think there is approx. 2 to 3 mm left on them. Yes it is reckless, but it's also a lot of highway driving VS city.
  17. Jul 3, 2020 at 2:46 AM
    #37
    Blockhead
    Blockhead Well-Known Member
    Pittsburgh, Pa.
    2024 Silver SR5 DCLB
    It’s a 9 yr old truck with 80k miles. Did you expect to never have to replace parts? Maybe you should’ve bought a brand new one...:eek:
    That one old guy and Sprig like this.
  18. Jul 3, 2020 at 4:42 AM
    #38
    rgmrgm
    rgmrgm New Member
    bob
    Albuquerque
    2014 tacoma 4wd v6
    wheels, led tail lights
    Warped heads at 82k miles on a 2014 4.0. Never overheated in the 66k miles I have owned it. Still under warranty so the dealer covered $5800 repair cost.
  19. Jul 3, 2020 at 8:55 AM
    #39
    Crosis
    Crosis Tertiary adjunct to unimatrix 01
    Dunedin Fl
    09 Tacoma 4x4 TRD Off Road
    I didn’t change my pads until 105k miles. Tacomas are hearty vehicles so no you don’t expect to go through wear items often.
  20. Jul 3, 2020 at 9:10 AM
    #40
    That one old guy
    That one old guy Well-Known Member
    Chuck
    08 Base 4x4 2.7 Access 5spd
    Stockish
    A lot of abuse/neglect can be done in 9yrs. Whadja expect? :notsure:
    Sprig and Blockhead like this.
