First Trip to the Dealer (repair/warranty)
Discussion in 'Technical Chat' started by Benson X, Feb 6, 2012.
  1. Feb 6, 2012 at 8:04 PM
    Benson X
    Benson X [OP] My build thread sucks...
    Ben
    Olympia, WA
    '11 MGM DC/LB
    If you don't draw blood, you're doing it wrong!
    I went to the dealer today for 2 reasons: fix my chirpy blower, and have them diagnose a "clunk" that's developed in the front. I did not have high expectations.
    I have a 2011, and I have only gone to the dealer for parts and free oil changes, and other than long wait times (2+ hours for an oil change!!!:eek:) I've had no problems. This was my first time going there for any "repair" work and warranty coverage. I wasn't too optimistic, but I wanted to "test the waters" so to speak, and find out if they would get any business from me in the future.
    Within the last month, my truck had developed a definite "clunk" when the taking a hard right at low speed. This was more noticeable while reversing and the wheels fully clocked to the right. Last weekend I took off the wheels and made sure all my suspension and drive-train components were torqued to spec. After a thorough inspection, everything looked good. Reversed out of my driveway, and the clunk was still there. I thought it must be steering related. So, I called the dealer and made an appointment for today.
    When I arrived at the dealer today, I saw TW member Mike (Chickenmunga) at the parts counter getting some parts. I let him know what I was hoping to get done today, and neither of us were expecting the outcome to be positive.
    I pulled into the service bay, and "checked in". Since I have OME shocks (885 Coils/90k shocks) and LR UCAs up front, and OME shocks with Dakars in back, I thought for sure they would immediately attribute any issues/sounds to the aftermarket parts that I installed myself. The service manager was cocky and assuming, and he immediately began asking run of the mill questions about my lift: "Is it a body lift?" "You got spacers in there?" "Who installed it?" I explained everything I had installed, and he handed the keys to the mechanic, Mike.
    I walked around back to the garage, and saw Mike, the mechanic, making the rounds with a torque wrench. I let him know what I had checked/torqued already, and he agreed that it was most likely not suspension related. He was surprisingly "cool" to work with. It was like talking with a mechanic buddy that is actually trying to help, and not feed you bullshit instead of saying "I don't know". He drove it around a couple times, and the clunk was still there so back on the lift it went.
    As he was backing my truck out again, he turned hard-right and there was no clunk. I hopped in and we drove around trying to recreate the sound, but it was gone!!! He said both the body-to-frame mounts were loose, especially the driver's side. After tightening them down TIGHT (*34ft/lbs is the proper torque as found by Chickenmunga) the sound had subsided. I have no idea how they got so loose in the first place, but now I know to check on them periodically. Mike didn't have a specific torque spec., but since they have bushings, he said get them as tight as you can.
    Here's the bolt you need to check (both sides)
    I shook Mike's hand, and thanked him for finding and fixing the problem. We talked for a bit about mods, and the DIY ethos in general. I walked back in to the service bay to sign-off on the work order. The service manager asked "Was it the lift?" with a shitty grin. I explained about the body mounts, and he seemed as surprised as I was. I signed my invoice for $0.00 and thanked them for the good service. The whole process was about 90 minutes, I think it was a pretty successful trip.
    After I left (and made sure the sound was truly gone) I called Chickenmunga to let him know the outcome. He said he was going to check his body mounts also. Voilà!!! It seemed to have cured his mysterious front-end sounds too! Could this be an easy fix for some of your impossible to track down noises? Check your front body mounts!!!
  2. Feb 14, 2012 at 10:16 PM
    MountainEarth
    MountainEarth Well-Known Member
    Bryan
    CO
    2010 TRD OR Access
    Leer 100XR Shell, BedRug mat - comfy sleeping, GT Covers microfiber seat covers, BFG All Terrains 265/70r16, Dashmat, Antennax 13" shorty antenna, Weathertech liners, Ultra Gauge, Avid Light Bar, PIAA 520 ATPs, one old dog
    Pics? I have no idea where those would even be.:notsure:
  3. Feb 15, 2012 at 6:26 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    I will take pics later today. They are the holes on the bottom of the frame rail, behind the front tires. That's where the cab mates to the frame.
  4. Feb 15, 2012 at 12:19 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Here's the mount bolt that needs to be checked:
    Same on the passenger side. Tighten to at least 34 ft/lbs torque.
  5. Feb 15, 2012 at 12:33 PM
    Taqoma
    Taqoma Well-Known Member
    Brennan
    Los Angeles
    2011 TRD Off-Road
    TRD Supercharger, TRD CAI, Camburg LT, Fox 2.5x8 coilovers, Fox 2.0 bumps, Deaver e30 leafs, Fox 3.0x18 triples, Avid sliders, Yaesu 2900R, Pro Comp 7089 16x8, DDM 55w HID Hella 500FF, DDM 35w HID headlights, Magnaflow 11255 muffler, PLX DM-100 OBDII, Autometer Ultra-Lite II Boost gauge, Flex Pod gauge mount, LSK tube bumper, McNeil fenders, Fiberwerx bedsides, 285/75/16 Toyo MT's
    subbing for later! thanks!
  6. Feb 19, 2012 at 5:21 PM
    Crownedcustoms
    Crownedcustoms Well-Known Member
    Gilbert
    07 dc 4x4 fox coilovers 20's & toyo mudders
    Fox coil-overs, Fox shocks, 20" Helo wheels, blowthough, Jl and focal system, Grillcraft grill, Toyo Mud terrains
    I have been chasing this same symptom for a while now. I'm going to try that and let you know.
  7. Feb 20, 2012 at 12:12 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    I hope that fixes your mysterious sound. It worked for me and Chickenmunga. Good luck, let us know if that helped!!!
  8. Feb 20, 2012 at 12:16 PM
    jackhart
    jackhart Well-Known Member
    11 DCLB
    thanks for posting, i have an '11 also. no clunking sound (yet), but at least i can now be proactive and keep an eye on this.
  9. Feb 20, 2012 at 12:25 PM
    OffroadToy
    OffroadToy pull my finger
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Piaa driving lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    Great story and outcome...thanks for sharing!! :thumbsup:
  10. Mar 20, 2012 at 10:23 AM
    backcountryj
    backcountryj Pending Approval
    Jonathan
    GA
    sub'd for sure
  11. Mar 20, 2012 at 10:27 AM
    RockyMtnTRD
    RockyMtnTRD Wanderlust.
    Noah
    Colorado
    '11 TRD OR
    hack job
  12. Mar 20, 2012 at 10:35 AM
    carmellocafe
    carmellocafe Begin With The End In Mind.
    KEVIN
    N. California
    2014 TRD OR Access cab longbed
    It'd be nice if we could find the exact torque specs. for this. IDK, it just seems that 34#'s on a frame mount is on the "light" side? Congrats. on the dealer visit though. You don't often hear of them going so well.
  13. Mar 21, 2012 at 7:24 PM
    phantomblackgto
    phantomblackgto Well-Known Member
    Martin
    Parkville, MO
    2012 MGM TRD Sport 4x4 DCSB
    TRD exhaust, Debadged, Tacoma door sill protectors, Weathertech DFL's, Twoplankers center console organizer, Escort S2 cordless radar detector, AFE Pro Dry S air filter, Ultra Type 62 wheels 17x8 et +10 w/ 108mm - 106.1mm hubcentric rings, 265/70/17 Goodyear Wrangler Duratracs, Bilstein 5100's - front set to .85, Nfab 2" step bars w/ LineX coating
    What'd they do about the blower? I have the same issue.
  14. Mar 26, 2012 at 9:23 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    They installed a new one no problem...it's a common problem, and they will most likely be aware of it. That doesn't mean the new one is not going to go out again in though (at which time I will just get another one under warranty :D).
  15. Mar 26, 2012 at 9:30 AM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    I thought so too, especially since I asked the mechanic what torque, and he replied just get it TIGHT!!! Since there's a rubber bushing in there, it shouldn't matter as much but according to this TSB (there was a similar issue on 2005 model Tacos).
  16. Mar 4, 2015 at 12:43 PM
    Benson X
    Ben
    Olympia, WA
    '11 MGM DC/LB
    Another good experience with Toyota of Olympia today.
    My airbag light came on a few days ago...my VIN is not part of the "Spiral Cable Recall" so I didn't know if it would be covered or not.
    I made an appt. for 8:30 this morning and spoke to the Service Writer, Otay. He checked all the options, and said even though it is not part of the recall he would see if he could get it covered under the powertrain warranty (I have 51,278 miles on the ODO). He was able to pull some strings and get it replaced under warranty, no charge.
    Took 3.5 hours at the dealer to get it replaced, but I had my laptop so I was able to work while I waited. All is well now, and they have kept me as a happy customer! :)
