First trip
Discussion in '4 Cylinder' started by 06 4cyl 5sp SR5, Nov 17, 2012.
  1. Nov 17, 2012 at 8:25 AM
    06 4cyl 5sp SR5
    06 4cyl 5sp SR5 [OP] Member
    MO
    06 SR5 4cyl 5spd man. 4x4
    Just got back from a 250 miles trip. Probably half highway miles at 70mph with cruise and half twisting up and down roads through Noel Mo. into Arkansas. Averaged 21.5mph so not to bad, hoping to get better on my flat daily commute of 60 miles round trip, I usually don't get in a big hurry to work so only run about 65 most of the time. Have discovered my speedo is about 5 mph off at 70 indicated by my iphone GPS. Anyone know how accurate an iphone GPS app is ?
  2. Nov 17, 2012 at 10:45 AM
    wolftree
    wolftree Well-Known Member
    Rick
    Ohio
    2011 Tacoma 4x4 Regular cab automatic trans,
    Rear Leaf TSB, Bilstein 5100s, extra leaf added
    GPS is only accurate if you are sitting still.
  3. Nov 20, 2012 at 7:15 AM
    bambooshoots
    bambooshoots Be a fountain, not a drain.
    Kevin
    College Station, TX
    2015 Honda Accord Sport
    I did it again. Got tired of paying truck payments and gas and traded in for a 2015 Honda Accord Sport since I enjoyed my 2013 Sport so much.
    Actually I think it's been proven that GPS speeds are more accurate, with the Garmin units at least.
    I believe it's common knowledge that these Tacoma's do run their speedo a bit slower; when I had a Tacoma it was indeed 5mph slower; I had a V6 so throwing on larger tires corrected that.
    I'm not sure exactly how accurate the iPhone app is, but it wouldn't surprise me that it'd be more accurate than the speedo.
  4. Nov 20, 2012 at 7:46 PM
    Rackster
    Rackster Well-Known Member
    Kevin
    Connecticut
    '04 E/cab 4x4 2.7 Auto SR5
    My experience: speedo reads higher than actual speed at normal driving speeds.
    True on all of my vehicles and confirmed by my Ultraguage and the occassional side-of-road radar systems the police setup in places where they want to control the speed of traffic.
    But tire size will impact that reading and the error I experience is nonlinear. I don't run the vehicle about 70 or so on the speedo, but the error on my Tacoma starts out somewhere around 30 mph on up through 70 mph. At lower speeds, the speedo might even understate my actual speed.
    Do the studies and learn your curves. Good luck!!
