First truck: What do you guys think of this one?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by jay_taco, Feb 5, 2016.
  1. Feb 5, 2016 at 8:57 AM
    jay_taco
    jay_taco [OP] Member
    Howdy folks!
    I'm purchasing my first truck and I test drove this Taco I found on CL last week.
    162k miles, 2005 blue, toytec lifted. Windshield has a crack on it, which is pretty common for trucks in Montana. I'm using it for very light duty (moving) and traveling short distances, hauling things for the house/garden. $11500 is the price the seller is asking.
    I drove it and didn't notice anything major. Nothing that stood out to me as "wrong"or bad for the age of the vehicle. it has some marks on the body, but again nothing I don't expect for a truck. NADA reports it roughly at $13. I instantly liked the truck and don't feel like it's bad deal.
    I'm taking it on a 2700 mile move from the west to new England in September.
    I also found an f150 that is newer with less miles, but only has 2WD rear. nope.
    What do you guys think?
  2. Feb 5, 2016 at 9:01 AM
    ThunderCookies
    ThunderCookies This is the Wait
    Jon
    North Carolina
    06 Wolfpack Edition
    5100s at 2.5 setting up front 5100s with 2" AAL around back TC Uniball UCAs 285/70/17 Fierce Attitude M/T SCS Ray 10s 17” 14" Magnaflow w/3.5" Stainless Tip SOS aluminum armor front bumper SOS high clearance rear bumper Stealth grill light bar and pods 4" Westin Nerf Bars Weathertech in-channel visors Window tint Bed Mat Proven Ground Locking Roll-Up Tonneau Cover All-weather rubber floor mats Custom Wolfpack TRD Decal TOYOTA Vintage Tailgate Decal 4 Wheel Drive vintage decal Tailgate Anti-Theft Mod Bed Mat Anti-Theft Mod Sliding back glass Anti-Theft Mod Future Mods: Bedside bottle opener Bedside storage lock/key mod Bed pod lights
    Ask about the frame - there is a recall due to rust issues. I'd assume higher risk in your location with the snow. Dealer will replace it for free but it's a pain, especially since this one seems to have a lot of after market parts. Maybe the owner has already had it inspected under the recall or even replaced. Didn't see it mentioned on the CL ad.
    Drew_05Tacoma likes this.
  3. Feb 5, 2016 at 9:07 AM
    jay_taco
    The owner did take it in for a recall inspection (passed with no work needed) and also took it to a master tech to inspect the timing belt and what not. The timing belt hasn't been changed and the tech indicated it didn't need it.
  4. Feb 5, 2016 at 9:17 AM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Clearly the owner knew what he was doing. I'd lay under it and push up on the driveshaft at the center bearing - there should be very little movement of the bearing and check the u joints for excessive play. IMO go for it.
  5. Feb 5, 2016 at 9:23 AM
    ThunderCookies
    Jon
    North Carolina
    06 Wolfpack Edition
    Yup - sounds like you found a good one and that's a great price too. Pull the trigger before someone else on here does :D
  6. Feb 5, 2016 at 9:24 AM
    jay_taco
    Yeah, the owner (he is the 2nd or third), took good care of it and did all the usual maintenance himself. He said he'll gladly show me around the truck and give me some help if needed.
  7. Feb 5, 2016 at 9:36 AM
    Iowa10
    Iowa10 Well-Known Member
    Love that color. Good looking truck. With the lift, you need some cooler tires than the Rugged Trails, in my opinion.
  8. Feb 5, 2016 at 9:38 AM
    jay_taco
    You guys don't seem to be bating an eye on the mileage. I'm so accustomed to having newer vehicles. I totally like the truck. So much less lame than the outback I was considering.
    Do you guys recommend any particular oil? I've always used M1, but have heard godo things about the royal purple stuff. I'm a full synth guy.
  9. Feb 5, 2016 at 9:40 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    The truck is just getting broken in. Use the oil the owner is using.
  10. Feb 5, 2016 at 10:04 AM
    Iowa10
    Mobil 1 and you're good to go for life. I wouldn't be at all afraid of that truck with those miles, as long as prev owner did his part.
  11. Feb 5, 2016 at 10:05 AM
    jay_taco
    What oil would you guys recommend for mostly highway driving as far as weight is concerned? I was thinking 5w-30 or whatever the manual says. I don't go crazy on the throttle. I'm very accustomed to driving a prius, and before that, a 2003 honda insight. Driving this truck is gonna be very different.
  12. Feb 5, 2016 at 10:16 AM
    jay_taco
    Noted. thanks for the feedback! I figured I was being a bit overly cautious. I'll take the dive and learn as I go! I'm sure you'll see me around.
  13. Feb 5, 2016 at 10:50 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Maybe get under the truck and make sure the cat heat shields mounted to the cab are firmly attached (not corroded away from the mount) then I'd think the truck is pretty solid.
