First Tune Up 60,000 Miles
Discussion in '2nd Gen. Tacomas (2005-2015)' started by duque00, Sep 24, 2021.
  1. Sep 24, 2021 at 1:21 PM
    duque00
    duque00 [OP] Well-Known Member
    Long Island, NY
    Hey All,
    Doing my first tuneup on my 2012 Tacoma 2.7L
    I know of the following:
    Oil Change
    Plugs
    Cabin Filter
    Air Filter
    Coil packs or just the boots?
    PCV Valve?
    Anything else I am missing?
    Thanks in advance guys!
  2. Sep 24, 2021 at 1:25 PM
    Steves104x4
    Steves104x4 Well-Known Member
    Buffalo NY
    2010 RC 2.7 4x4
    Check the coils at the plugs are not covered in oil if they are you need a valve cover and spark plug tube gaskets. Good luck! Edit: clean the maf, too
    eherlihy likes this.
  3. Sep 24, 2021 at 3:12 PM
    Dm93
    Dm93 Test Don't Guess
    Texas
    2014 DC OR 6spd 4x4
    Coils rarely fail on these trucks so I wouldn't replace them, as stated above make sure there's no oil in the spark plug tubes.
    If the boots are in good condition there's no need to replace them either just put a little dielectric grease around the inside to help it slide and keep it sealed.
    PCV valve shouldn't go bad either unless oil changes are neglected.
    I'd consider changing the fluids in your transmission, rear axle, and if your 4wd front axle and transfer case.
    Also grease your Ujoints if they have grease fittings.
    TnShooter likes this.
  4. Sep 24, 2021 at 3:12 PM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    At 60k. I’d also do diffs, tranny, coolant, ps fluid, brake fluid.
    Dm93 likes this.
  5. Sep 25, 2021 at 6:25 AM
    duque00
    Long Island, NY
    Sound advice Gentlemen!
    Anything else I missed?
    Thanking you again!
  6. Sep 25, 2021 at 6:51 AM
    b_r_o
    b_r_o Gnar doggy
    Alex
    WA
    2015 DCLB
    Clean and adjust the rear brakes
    Steves104x4 likes this.
  7. Sep 25, 2021 at 7:49 AM
    Steves104x4
    Buffalo NY
    2010 RC 2.7 4x4
    Start looking for take off shocks and struts from a new truck in the bst section. Edit: I’ve got upper and lower control arms sitting here ready to go on, too
  8. Sep 25, 2021 at 8:51 AM
    tacomavan
    tacomavan Well-Known Member
    Oregon
    grease your zerks
