first welder?
Discussion in 'Garage / Workshop' started by Cohbsteq, Nov 6, 2013.
  1. Nov 6, 2013 at 12:20 PM
    nagorb
    nagorb Should be a dang perma mod
    Alabama
    2001 dbl cab 4x4
    Depending on the area, i searched everyday forabout a month and never found a decent deal, most people wanted almost new prices for old equipment.
    Not much can go wrong with a gas one that can't go wrong with flux, unless you let the bottle drop on its neck:eek: as long as you strap it down its fine.
    this
    Some yes, mine is gas and runs off of 110v.
    From what i hear most guys are happy with the Lowes/ home depot 180 Lincolns. Also the millermatic series. I found a few of the 180 s on craigslist, most were almost new price. but i went with thermal arc 211i. But with your budget and needs iwould suggest one if the Lowes our hd units.
  2. Nov 6, 2013 at 12:44 PM
    Gaunt596
    Gaunt596 Well-Known Member
    Matthew
    Central Maryland
    well, that opens my options up a bit.... who needs a dryer lol
  3. Nov 6, 2013 at 2:15 PM
    Cohbsteq
    Cohbsteq [OP] Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    whats a good used price for a lincoln, im sure i can find a good deal in the local classifieds if im patient enough.. :goingcrazy:
  4. Nov 6, 2013 at 3:34 PM
    nagorb
    Alabama
    2001 dbl cab 4x4
    which Lincoln?
    alsodepends on your location. Around here for the 180 i was seeing $500 or so.
  5. Nov 6, 2013 at 5:48 PM
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
  6. Nov 6, 2013 at 7:41 PM
    TenBeers
    TenBeers Well-Known Member
    Rich
    Bentonville, AR
    2018 TRD Pro Cavalry Blue
    Yeah.
  7. Nov 8, 2013 at 10:02 AM
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    Buying a decent MIG welder should be considered an investment. They aren't inexpensive, so you might as well get a good one. Here's what I'd suggest: Infinite wire speed, Infinite voltage, Definately a gas regulator. A good 5 years ago I bought a Lincoln 135 plus mainly for a classic car restoration project and it does almost everything that I've needed to do. It runs on 115V but in the manual states to use a 25amp fuse if welding a full power. I did try to weld on a 15amp breaker but it would pop if welding thick material. So, I've run a dedicated plug off of a sub panel on 10 gage wire for the welder and used a screw in fuse so that I don't cause the breaker contacts to arc shut (It ain't fun when that happens and you're trying to disconnect the breaker). If I were to do it again, I'd seriously consider the 220V 180amp version. Of couse, if you don't have 220V near where your going to weld then that won't work. Also, look at duty cycle and cool down time. Cheap ones have a really short "weld" window. Finally get an automatic darkening helmet, good long cuff welding gloves and a welding jacket. I built a bumper for my last truck a few summers ago and didn't completely cover my arms as it was hot and ended up with a really bad sunburn from the UV.
  8. Nov 8, 2013 at 10:54 AM
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    good info, thanks for the comment man!
  9. Nov 8, 2013 at 1:29 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Read this thread as well if you have not already. http://www.tacomaworld.com/forum/garage-workshop/113957-anything-welding.html
    I read through the whole thing, and before reading I was going to go with a cheaper HF or Hobart/Lincoln, but with all of the really experienced guys that fab for a living on there having had those and knowing what they do now, the Miller 180 came highly recommended. I will be picking one up in the next few months (having never welded before) with the goal of learning how to use it and then building a rear and then front bumper for my runner.
  10. Dec 17, 2013 at 9:27 PM
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
  11. Dec 18, 2013 at 4:15 AM
    TenBeers
    Rich
    Bentonville, AR
    Yeah.
  12. Dec 18, 2013 at 7:13 AM
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
  13. Dec 18, 2013 at 7:31 AM
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    I am not 100% sure but I believe you might end up kicking yourself for only getting a 130 amp if you decide on that one. maybe some others can chime in but I would think that low of amperage output would greatly limit your capabilities. again I am not an expert in any kind of way, in fact 95% of all my welding is done with stick at a rock quarry, but I would think you might need a bit more umph from your welder.
  14. Dec 18, 2013 at 7:33 AM
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
  15. Dec 18, 2013 at 7:59 AM
    #35
    BamaToy1997
    Bill
    Navarre, FL
    Working on the same general thread discussion here, I already have a welder that I got years ago. It is a 110V model, and is a 135A unit. Question is, would that be sufficient to weld together the plate bumper kit. I'm not concerned about speed of welding, or single pass. I just am curious if it will get the job done. I'd love to get a new welder, but why spend the money at all if I don't have to, ya know?
  16. Dec 18, 2013 at 8:08 AM
    #36
    JLee
    JLee The Man! Vendor
    Jerry
    Benicia, CA
    02 Extra cab SAS Linked front and rear
    I lost track thousands of dollars ago.
    I guess it can be done but do you really want to spend all that money on a nice bumper kit Just to bugger it up with cold welds. I would step up to a 180A unit to weld a bumper kit. You and even rent welders if you really have to.
  17. Dec 18, 2013 at 8:08 AM
    #37
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Miller is not the best welder, their wire feed is absolute shit and their 210 millermatics are prone to over heat even when indoors on .030 wire. Then again I am a Lincoln guy through and through so I am a bit biased, even though I have used both, professionally.;)
    As a learner I would buy a Lincoln 140c as you have both wire speed and heat control. You can find most on the list for cheap and all parts are replaceable. I would steer clear of the cheap shit as you get what you pay for.
  18. Dec 18, 2013 at 8:14 AM
    #38
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    x2 i feel the same way if i can get by with a 130a welder just to do the extremely basic stuff i plan to do with it anyways, would it work?
    if i were you id just take it to a welding shop and have them throw it together for you youll still come out cheaper then buying one pre built, for me i guess i wouldnt want to ruin my new bumper but thats just me and im not a very good welder haha
  19. Dec 18, 2013 at 8:24 AM
    #39
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Yes, a quality 110 welder will have no issue doing quarter inch plate with a single pass weld.
  20. Dec 18, 2013 at 8:36 AM
    #40
    BamaToy1997
    Bill
    Navarre, FL
    It's not a matter of "ruining" a bumper. It is a personal challenge. I have welded many times before, but it has been either arc for heavy work, or light MIG for light work. Nothing bigger than basic sheet metal. So this will be the thickest I will have welded in MIG. If I make a mistake, I can simply spend the hours grinding it down and fixing it! :D And hours, and hours, and hours....
    I appreciate the input. Thanks.
