first welder?
Discussion in 'Garage / Workshop' started by Cohbsteq, Nov 6, 2013.
  1. Dec 18, 2013 at 8:42 AM
    #41
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    If you are worried that it wont get hot enough, through flux in it and strap on a tank of pure C02 to getter nice en hot.
  2. Dec 18, 2013 at 8:47 AM
    #42
    45acp
    45acp Paint me back in Wyoming again...
    Jonathan
    Boring, Wisconsin
    1981 Long bed 4x4
    Run CO2 with Flux?:confused:
  3. Dec 18, 2013 at 8:59 AM
    #43
    Phil Dammit
    Your Mom
    Tempe, Arizona
    FCAW-G gas shielded flux, the C02 will give better penetration than a regular C25 mix on non flux single shield wire.
  4. Dec 18, 2013 at 9:01 AM
    #44
    Welder
    Welder Active Member
    Cape Breton
    2010 Tacoma TRD Sport
    SRI
    With proper joint prep. and preheat with propane, you can weld a wider range of thickness' of steel with a 140 or 180 welding machine. Adding a bevel or chamfered edge with a grinder is the quickest and easiest way to obtain this result.
  5. Dec 18, 2013 at 9:16 AM
    #45
    Phil Dammit
    Your Mom
    Tempe, Arizona
    What are the advantages of using propane over a rosebud and oxyacetylene for pre-heating?
  6. Dec 18, 2013 at 9:27 AM
    #46
    TacoFMS
    TacoFMS Bubble bubble bubble pop
    Justin
    Louisa County, VA
    Just a vehicle to take trash to the dump
    One or two things modded... Check out the build thread
    I would guess more folks might have a propane torch laying around???? :notsure: we just always use the oxy/acet torch because it is on the same truck the welder is on when we have to heat up hard plate to weld... would think they both serve the same purpose though.
  7. Dec 18, 2013 at 9:29 AM
    #47
    Welder
    Cape Breton
    SRI
    I just use propane as an example since it is simple and convenient to access. Propane is typically cheaper and has a higher BTU rating at a lower temperature for heating up material.
  8. Dec 18, 2013 at 9:38 AM
    #48
    Phil Dammit
    Your Mom
    Tempe, Arizona
    Ahhhhh, gotcha.
  9. Dec 28, 2013 at 6:43 PM
    #49
    SOS CONCEPTS
    SOS CONCEPTS Bumper builder
    SOS
    Laurens SC
    17 sos buggy, 09 taco(in pieces), 14ram 3500
    Rock bouncer
    write a check or get a credit account for a miller 252. You be sooo happy
  10. Dec 29, 2013 at 6:40 AM
    #50
    robssol
    robssol If it ain't broke, leave it the eff alone!
    Rob
    S. Wisconsin
    06 Tacoma, TRD Sport, SR5, 4X4, AC
    Totaled but still alive! Frame 2.0, Fog lights anytime, Seatbelt reminder delete, Secondary air filter delete, LED bed lights, Running boards, 2017 Rims, Ultra gauge, Cup holder/consol/glove compartment lights, Interior LED conversion, Blue Sea aux. fuse panel, fuse panel mounting plate by Yotamac, ProEFX heated towing mirrors, LED engine bay lights, Redline Quicklift Elite hood struts, Wet Okole Heated Seat Covers,m, Rear bumper 2.0, Decal free visors, Washable cabin air filter, Overhead consol auto dimming override switch, BulletProof Fabricating Skid plate, 2lo module.
    Take a class, get some burn time, save up and buy a decent welder. At least you'll know what you're looking at when you're putting your money down. Personally I would buy new.
  11. Dec 29, 2013 at 6:42 AM
    #51
    Cohbsteq
    Cohbsteq [OP] Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    Haha 2500!!! Holy cow! That's a tad out of my college student budget :D
  12. Dec 29, 2013 at 7:34 AM
    #52
    USArchangels
    USArchangels Well-Known Member
    Max
    Houston, TX
    '12 TX Pro Baja
    Stock BAJA: bfg ta ko 16's 60mm racing Bilstein & TRD coil springs up front 50mm remote resevior race Bilsteins in back 71/21 mpg MODS: AeroTurbine 2525XL Muffler on all stainless TRD exhaust. Chopped and dumped TRD Tailpipe. Now 90 degrees. Cut just after axle. aFe ProDry S drop-in air filter Secondary (wire mesh) Filter delete Wilson 4ft Flex Silver Load CB antenna Midland 75-822 CB - hardwired Passport Escort 8500x60 & TomTom GPS unit wired to interior fuse panel with add a fuse BAMF antenna mount (front for CB) Relentless Fab antenna mount (tailgate) Fake Bead Lock delete reversed white wall tires All mudflaps delete Predator Tube Step delete TX Baja decal delete debadged Avid bars front and back SnugTop Rebel Rear Diff Breather mod to bed storage compartment STANT locking gas cap with fishing wire. Interior Map lights - Green LED Interior Dome Light - Red LED ConsoleVault
    I'm just starting out myself. Could go with this set-up for a limited budget:
    · At least two (2) 12-volt car batteries (charged)
    · At least two (2) sets of jumper cables or one set of jumper cables and a “patch” cable
    · Vise-Grips
    · Wire Brush
    · File
    · Leather Gloves
    · Welding Goggles or hood with at least a shade 10 lens
    · 3/32” Welding rod
    6011 welding rod
    347 stainless welding rod
    1/8 rod
    3/32 rod
  13. Dec 29, 2013 at 7:50 AM
    #53
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    Haha I have considered something like this, but I'm leaning towards this guy, looks like a nice little set up with the option to run with or without gas. It's got some solid reviews, and runs off a standard plug..
    http://www.amazon.com/Hobart-500559...&qid=1388332204&sr=8-1&keywords=Hobart+welder
  14. Dec 29, 2013 at 10:04 AM
    #54
    vssman
    vssman Rocket Engineer
    Paul
    Naugatuck, CT
    2013 SR5 double cab
    If you have any plans to ever weld sheet metal, you'll want infinite wire speed and voltage adjustments.
  15. Dec 29, 2013 at 10:14 AM
    #55
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    Ya I'm thinking just a pretty basic one to Learn on then hopefully get the hang of it and upgrade in a year or two
  16. Dec 29, 2013 at 10:21 AM
    #56
    SOS CONCEPTS
    SOS
    Laurens SC
    Rock bouncer
    Save first then buy! Its like a paintball gun you buy a cheap walmart one. then you keep upgrading to the 1200 buck bob long. Get the hobart 140 for $500 or miller 211 for 900+
    use solid wire and run 75/25 gas.
  17. Dec 29, 2013 at 11:00 AM
    #57
    HBtaco02
    HBtaco02 Well-Known Member
    Allen
    Huntington Beach
    02 4wd SR5 TRD
    ARB Front Locker grey wire mod Camburg UCA's Extended Kings All-Pro expo's 10" Bilstien Brute Force Hybrid front bumper Smitty XRC8
    Do not go cheap on a welder. Do not get a. Cheap flux core. Get a good welder and it will last a lifetime. . You don't want to go cheap..
  18. Dec 29, 2013 at 11:09 AM
    #58
    USArchangels
    Max
    Houston, TX
    '12 TX Pro Baja
    How about a Lincoln Electric K1297? $299 at Lowes
    Lincoln Electric 240-Volt / 225-Amp Stick Welder
    I call this one "The little red box welder"
  19. Dec 29, 2013 at 11:43 AM
    #59
    josh843
    josh843 Well-Known Member
    Josh
    moncks corner, sc
    2001 reg cab prerunner
    anyone got anything on this one?? looking into getting into welding, never done it but i want to learn. figure this one has a good price ad reviews
  20. Dec 29, 2013 at 12:40 PM
    #60
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    I went and looked at hat one today it looked good but it's a stick welder..Michael I guess isn't a bad thing.. I just think I want the option of gas
