first welder?
Discussion in 'Garage / Workshop' started by Cohbsteq, Nov 6, 2013.
  1. Jan 7, 2014 at 8:41 PM
    #101
    Cohbsteq
    Cohbsteq [OP] Hood Rat
    Jacob
    SL,UT
    02 Supercharged 4x4
    Pretty much stock with some crap welded to it.
    This ya what he said when I asked I'm if it ran on gas
    " Yes I turned the co2 bottle in to praxair but still have a roll of wire to go with it "
    Then this " Ya it will plug-in to a 110 outlet the wire I have you would need gas (co2) You can get welding wire at Lowe's that does not require gas "
    Maybe you guys can decipher it better then me haha.
  2. Jan 7, 2014 at 8:54 PM
    #102
    medic2230
    medic2230 Ditch Doctor
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    20% Tint, OME 3"complete lift with Dakar's, Light Racing UCA's, 285/75/16 Nitto Terra Grapplers, 10 HP TW sticker, Ultraguage, B.A.M.F. Rock Sliders, MedicFab Bed Rack, Relentless front bumper
    The wire he has is mig wire which you use gas with. He was probably renting the tank so he turned it back in for his deposit back.
    It will plug in to a standard house outlet. You can get the Flux core wire at Lowes that you can use in the welder w/o running gas.
  3. Jan 7, 2014 at 9:00 PM
    #103
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    Oh ok, I was mostly just wondering about the gas part if I have to use that particular gas or I can use different kinds..
  4. Jan 7, 2014 at 9:07 PM
    #104
    medic2230
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    You can use Co2 or C25.
  5. Jan 7, 2014 at 9:37 PM
    #105
    Cohbsteq
    Jacob
    SL,UT
    02 Supercharged 4x4
    And you can rent a tank for both of those? Does one burn hotter then the other?
  6. Jan 8, 2014 at 5:42 AM
    #106
    medic2230
    Murph
    Bama! Roll Tide
    2011 Taco 4x4 DCLB
    Most places around here you just buy them and swap them out when you need a tank. Co2 allows for more penetration. C25 is a cleaner weld.
  7. Jan 8, 2014 at 7:15 AM
    #107
    Phil Dammit
    Phil Dammit Well-Known Member
    Your Mom
    Tempe, Arizona
    05 5 lug minitrucker
    4.5/5.5 drop, DJM arms, QA1 coilovers, 6lug leafs, QA1 18-way, rear swaybar, Batwing Big brakes, high flow cat, indy/hurst shifter, memphis amps, focal 3-ways, Eclipse AV unit, SunDown 10" custom box, TRD bucket swap.
    Depending on the wire he buys. Dual shield will work with Co2 and it will penetrate hotter, as medic stated. However it is going to have slag that will need to be cleaned off. If you get single shield you will want to run C25. This is cleaner but will not be as hot.
    And that makes sense now. He returned his tank. I get all my wire, gas, torch attachments from prax. One stop shop for welding, plus my guy hooks me up since I used to go to him at least twice a week.
    Get your clamps and tool elsewhere.
