Fish Tailing...
Discussion in 'Performance and Tuning' started by crucian, Apr 23, 2010.
  1. Apr 24, 2010 at 4:57 PM
    thekidcatcher
    thekidcatcher Well-Known Member
    Corpus Christi, TX
    05 TRD offroad SR5
    Legs- --Helo rims --KM3 285/75/R16 --Bilstein 5100 in front with OME 886 --Dakar with extra leaf --Total Chaos UCA's --5165's Bilstein in the rear Electronics- --Warn M8000 w/ Warn wirless remote --Cobra 29LTD CB, --12in sub with alpine amp , --Dual Battery, --Warn Air compressor --URD MAF sensor, --touchscreen cd player hooked up to front and rear cameras Armor- --All-Pro offroad front/rear/rocksliders --AP skid plate, diff armor Cajones- --JBA headers, midpipe, exhaust --Safari Snorkel --4.56s ECGS Misc- highlift jack --UWS toolbox --u bolt flip kit --Tepui Kukenam Custom- --in dash inverter --on-board shower system --dvd anytime mod --custom bed rack and tiregate.
    25mph around a right angle turn is seems pretty quick to me lol. I slow way down.
  2. Apr 24, 2010 at 5:04 PM
    OffroadToy
    OffroadToy old, forgetful, and decomposing
    Icon Stage 8, ECGS Bushing, Timbren ubolt flip, Crown extended brake lines, Overland Custom Design sway bar links, rear differential breather extension, oil filter drain hose, a/c drain hose extension & reroute, front windows tint, Cat Security, XPEL headlight/fog & grill protection, OEM block heater, RCBS illuminated 4X4 switch, Weathertech mats, Wet Okole seat covers, Sherpa Grand Teton/Crows Nest, Baja Designs S8 light bar, Diode Dynamics SS3 Pro fog lights, Method 305 NV Double Black, 275/70/17 Toyo R/T Trail.
    :burnrubber: The only time I've ever heard of anyone needing to add weight in the bed is during winter sliding around on snow and ice. I'd say either slow down even more while cornering or get some better tires and you should be good to go. Oh, and good job on that big word Chris!:thumbsup:
  3. Apr 24, 2010 at 5:19 PM
    TacomaJack09
    TacomaJack09 Well-Known Member
    Jackson
    Montana!
    06 Access Cab 4x4
    Billie 5100's, Ride Rite Airbags, Tech Deck
    I would get some tube sand at Home depot until you need new tires, then buy new tires and get rid of the ghetto.
    BTW, its not ghetto at all, truck owners know whats up.
    I used to have kinda the same problem but I know I was going to fast and my tires sucked, then I bought some BF Goodrich AT and I can still go fast minus the fish tailing...
  4. Apr 25, 2010 at 8:03 AM
    doodle_cakes
    doodle_cakes Well-Known Member
    Canada
    08 Taco SR5 5lugger
    Install a roll bar.
  5. Apr 25, 2010 at 8:14 AM
    Brunes
    Brunes abides.
    Rotorhead
    Around
    Get better tires, make sure they are properly inflated, use less control input (throttle and brake) in turns.
    And if you need weight for driving in the rain or on normal roads- You should avoid snow completely. There are lots of ways to add weight. Get sand bags or a water bladder, cinder blocks too. Only problem with that every pound you add is a pound less cargo or people you can carry and it'll affect your mpgs.
  6. Apr 25, 2010 at 1:36 PM
    Manlaan
    Manlaan Well-Known Member
    Greg
    Riverton, Utah
    2002 XtraCab SR5 V6 4x4 Black
    See Signature
    I agree here. 25 is the speed limit in a residential area, and he's taking corners at that speed, in the rain.
    Sometimes the solution isn't to modify the vehicle, but to change driving habits based on the environment. You cant drive the same way in all situations with out causing unnecessary risk to yourself and others.
  7. Apr 25, 2010 at 2:01 PM
    Janster
    Janster Old & Forgetful
    Jandy
    Lancaster, PA
    Welcome to REAR WHEEL DRIVE vehicles.
    They all fish tail if you go too fast around the corners in the rain (and sometimes not in the rain).
    Right now, my tires are getting thin and I have to be extra careful around the corners. Because they're getting thin, I'll run lower air pressure in them also.
    29psi instead of 32psi (for example).
    Adding weight will suck up the gas. So, you have to make a decision..... put weight in, go faster, suck up lots of gas.
    OR
    Go slower and save gas.
  8. Apr 25, 2010 at 2:31 PM
    BEEFY_CHEESY_TACO
    BEEFY_CHEESY_TACO DUDE MAN BRO
    Hot Carl!!!
    Roy UT
    2010 TRD-Off Road TACO Extra value package
    Icon Ext Travel w/ Resi Front and rear, Dakar leaf springs, total chaos UCA's, color matched rear bumper, color matched satoshi grille with black chrome TRD emblem, konig countersteer offroads (black) w/ 285/75 Duratracs, sockmonkey Trailiens 3rd tail light cover, Tacomaworld.com sticker (made by me), debadged all around, Relentless Front Bumper, Sliders, Rear bumper, and bed bars with Yakima rack w/ full size spare, shovel, hi-lift
    too much weight in the back could take away from your front end traction which is pretty important, plus there goes some MPG!! i say SLOW YOUR ROLL!!
  9. May 5, 2010 at 5:40 PM
    TacoDaTugBoat
    TacoDaTugBoat Well-Known Member
    Goshen, Ct
    13 DCLB TRD Sport
    I slide a bit too. Sometyimes I try. My stock tires have sucked from day one, and I look forward to them dying so I can get some better ones. I add sand tubes from home depot for the winter, but with how light the back end is and the rear wheel drive you sometimes just have to take it easy.
  10. May 5, 2010 at 5:44 PM
    Jason'sLawnCare
    Jason'sLawnCare Prepared for Bambi
    Jacksonville Florida
    08 4x4 Double Cab TRD Rugged Trail
    CBI Moab 2.0, CBI Trail Rider 2.0, CBI sliders w/kickout, Superwinch EPi9.0S, OME sport shocks w/886 coils, OME n182, 1.5" aal, JasonBuilt 3/16th full belly skid, BuiltRight uca, Body Mount Chop, 285/75/16 km2's, Rear cat delete, exhaust crossover rerouted, Fog light anytime, Locker mod, Rear leaf tsb, Debadged, Uws Tool Box, Electric Exhaust Cutout, AFE Pro Dry S, Kiwi Wifi, Diff Breather Relocated, Grom Ipod Adapter, Dual Diehard platinum batteries isolated by BlueSea marine switch
    haha. My rugged fails have only failed me once on the road but that was my fault.
  11. May 5, 2010 at 5:49 PM
    mrobey442
    mrobey442 Well-Known Member
    Little Rock, AR
    09 Access Cab TRD 4x4
    smoked out tails, a few avs parts, and BHLM, Alpine Head unit, 2 12 Directed Comp subs, 1200 directed class D amp, Blackhand Cap, besttop
    I slide out all the time especially due in the rain and the reasoning for this is a combination of my foot, the rugged fails, and the rear being light. The only solution I have found is just to lay off the gas when cornering and to throw a couple rail road ties in the bed.
  12. May 5, 2010 at 5:53 PM
    johnw
    johnw Well-Known Member
    john
    orlando florida
    06 prerunner v-6 4.0L 4 door
    well you asked for specs..... 06 trd sport speedway blue 5.3l v8 4.0 camburg lift spindles extended travel icons total chaos lowers allpro 4" leaf pack 17" xd hoss rims 37/12.5/17 mickey thompson baja atz Allpro hybrid bumper grill craft grill wicked flow muffler inside i have..... wet okole real tree camo seat cover blue oznium dome light stealth sub box with 2 10" kicker comp subs kicker 400 watt amp weathertech floor mats
  13. May 5, 2010 at 10:00 PM
    ExpoSpy
    ExpoSpy Well-Known Member
    Brian
    Temecula
    yes like everyone else said weight...but if you want to add weight check these out.
    And welcome to TW!!! :wave:
  14. May 5, 2010 at 10:15 PM
    genxer36
    genxer36 Lord of Tomfoolery
    Sean
    Bethlehem,GA
    Tow package, XM Satellite radio, K & N Air filter, & Channel Vent Visors
    x2. You probably don't have the right tires for conditions. I never have issues. I have high performance tires that are also great for wet.
  15. Jul 9, 2010 at 6:39 AM
    #35
    woody6047
    woody6047 McGrubber
    Beau
    Austin/ Waco Texas
    05 tacoma 4x4 dc
    100%stock, except for the exhaust leak and custom windshield crack mod
    I blame Austin roads that happens to me all the time. Granted i kinda like getting her sideways. But it has happened without me trying before.
  16. Jul 13, 2010 at 10:26 AM
    #36
    tacosuprem
    tacosuprem Well-Known Member
    Florida
    4x4
    Learn how to drive before you crash into a car with kids in them:mad:!!!!!!
  17. Jul 13, 2010 at 10:30 AM
    #37
    TacoSupreem
    TacoSupreem Dirty Trucker
    Hayden
    Kentucky
    2013 MGM DCSB 4x4 Sport
    Not another one!^^^
  18. Jul 13, 2010 at 10:31 AM
    #38
    WNYTACOMA
    WNYTACOMA Well-Known Member
    Clarence, New York
    09 Metalic Grey TRD OFF ROAD
    Toyota Nerf steps Bugflector 2 Tool box Weathertech floor liners Wet Okole F/R - Bk/Char
    Maybe you're getting oil on the road surface from the BP rains.
  19. Jul 13, 2010 at 10:39 AM
    #39
    TacoSupreem
    Hayden
    Kentucky
    Haha yeah I haven't been on here as much! Cost too much money! Lol I see all these cool mods and well.... Plus I've been modding the 700xx :D
  20. Jul 13, 2010 at 10:45 AM
    #40
    TacoSupreem
    Hayden
    Kentucky
    You been ridin the Rappy?
