fishing wagon tire question
Discussion in 'Wheels & Tires' started by bagster, Aug 13, 2010.
  1. Aug 13, 2010 at 4:24 PM
    bagster
    bagster [OP] Well-Known Member
    I have a 2010 Prerunner SR5 with stock Dunsuck tires. The only time my truck leaves the pavement is when I head to one of my fishing holes. Sometimes, I drive down muddy roads , or barrel through the occasional mud hole. Since my vehicle is a 2WD, would the front tires make any difference as to what kind of thread they have as far as traction goes since the power is coming from the rear? Most of the mud I drive in is sand-based, and not the gooy-stick stuff.
    Also, if I put a couple of AT's or mudders on the rear only and left the front stock, how dorky would that look? I had mud grips on the rear only of my '78 chevy 1/2 ton, 6-banger and the set-up worked great. The body on that pickup was so banged up that appearance was not an issue.
  2. Aug 13, 2010 at 7:49 PM
    Archangel
    Archangel Special Assistant to the Regional Manager
    Charlotte, NC
    '04 T4R SR5 4x4
    Get 4 of the same all-terrain or mudders, and call it a day. Doing that will give you the ability to rotate them and get more even wear out of them and they'll last longer than you just leaving them in the rear.
  3. Aug 14, 2010 at 4:03 AM
    bivey
    bivey Well-Known Member
    X2
