Fishtailing tacoma in the snow
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jay1193, Dec 4, 2019.
  1. Dec 4, 2019 at 5:07 PM
    Jay1193
    Jay1193 [OP] Member
    Jay
    1997 2.7 4c tacoma
    Hey folks,
    Recently purchased a 1997 4wd tacoma. It needed new shocks, struts, and brakes and have so far put in the rear shocks but I’m noticing that the back end is sliding out a lot even when driving cautiously with little throttle.
    I’m driving in 4hi mostly with the locking hubs off.
    not sure if I just have really shit tyres (plenty tread) or the old struts in the front have something to do with this. Think I also need new wheel bearings too.
    Anyone have any suggestions or thoughts?
    GQ7227 likes this.
  2. Dec 4, 2019 at 5:08 PM
    OneWheelPeel
    OneWheelPeel Well-Known Member
    Phoenix, AZ
    200lbs in the bed.
    jackn7 likes this.
  3. Dec 4, 2019 at 5:08 PM
    0xDEADBEEF
    2000 reg cab 4x4 flatbed MT
    Pickup trucks are super light in the rear. Put some weight in the back, a couple hundred pounds of playground sand is pretty easy.
  4. Dec 4, 2019 at 5:10 PM
    Key-Rei
    Key-Rei Well-Known Member
    Key
    Florida
    4 high with front manual hubs unlocked means you're still 2WD. Also. It's a truck, all the weight in the front no weight in the rear means skid city.
    And yes the right tires make all the difference in the world. Also tread depth isn't the only determining factor in traction, you also need a tire that is still supple (not older than about 4 years) and correctly seiped for your conditions.
    DJB1, Nicklovin, mainedisco and 18 others like this.
  5. Dec 4, 2019 at 5:10 PM
    Jay1193
    Jay1193 [OP] Member
    Jay
    1997 2.7 4c tacoma
    It’s a 4wd..
    GQ7227 likes this.
  6. Dec 4, 2019 at 5:11 PM
    2JHilux
    2JHilux Level 8 Tinkerer
    Denver, CO
    2001 Tacoma Double Cab 4x4
    manual swap in progress
    If you don't lock the front hubs you are still in 2wd more or less.
    Usually in a truck with manual hubs, when you think you will need 4x4 you lock the front hubs before you start driving, then shift into 4hi as needed.
    You can't use 4hi on dry pavement though when turning, so after you get through the bad stuff go back to 2hi before you turn.
    If you are turning on snow, ice, or lots of slushy stuff then it is ok to leave it in 4hi for the turn.
    usually lock the hubs before snow or going offroad etc.. most of the summer you should leave them unlocked cause you won't need 4hi depending on where you live of course.
  7. Dec 4, 2019 at 5:11 PM
    Speedytech7
    FCQM+VG Cheney, Washington
    It's less Tacoma and more mod
    Not if you don't have your front hubs locked it aint
  8. Dec 4, 2019 at 5:12 PM
    Key-Rei
    Key
    Florida
    Also 4WD in the snow isn't the same as AWD in the snow. 4WD can induce a skid and I DO NOT recommend 4WD in snow at highway speeds, that's a recipe for disaster.
  9. Dec 4, 2019 at 5:12 PM
    Jay1193
    Jay1193 [OP] Member
    Jay
    1997 2.7 4c tacoma
    Thanks for this. Does that mean I’ll only be in 4wd when locking hubs are engaged? And I can only really use the locking hubs when stuck. How does that work with 4hi if I shouldn’t be driving over 5-10mph with the locking hubs on?
  10. Dec 4, 2019 at 5:13 PM
    Jay1193
    Jay1193 [OP] Member
    Jay
    1997 2.7 4c tacoma
    Thanks folks. Learning a lot here
    jackn7, GQ7227 and tinker_troy like this.
  11. Dec 4, 2019 at 5:13 PM
    Key-Rei
    Key
    Florida
    What!?
    You must be stopped to engage the locking hubs in the front, and like, you know out of the truck turning the dials.
    Do you mean REAR LOCKER!?
  12. Dec 4, 2019 at 5:15 PM
    BINK05TRD
    BINK05TRD Well-Known Member
    Massachusetts
    TRD OR AC SILVERSKY 15
    4-low low speed.
    whatstcp likes this.
  13. Dec 4, 2019 at 5:16 PM
    0xDEADBEEF
    4wd is only 4wd with the hubs engaged. The typical plan is to lock them before you leave the house, and then if you happen to need 4wd, engage the transfer case only when you need it.
    You can definitely drive faster than 10mph in 4wd, but there is a limit to how fast you should be going when you engage it. I would recommend downloading the owners manual, its full of helpful stuff.
  14. Dec 4, 2019 at 5:16 PM
    Jay1193
    Jay1193 [OP] Member
    Jay
    1997 2.7 4c tacoma
    Yeah I know that. Explained it incorrectly. If i want 4wd in 4hi, should the front lockers be on?
  15. Dec 4, 2019 at 5:16 PM
    Speedytech7
    I've only had manual hub trucks for the last 7 years so let me clear something up for you. At some point when the weather or conditions are shity get out of your truck and lock both hubs. Now at any point while you're driving you can pull the stick from 2-wheel drive into 4 wheel drive. At any point while you were driving you can put the stick from four-wheel drive back into two-wheel drive. When you are stopped in 4-wheel drive you can move the stick into 4low. You may only move it out of 4 low when you are stopped. When you are satisfied that the weather or road conditions are such that you no longer need four-wheel drive you can then unlock your hubs and reap the benefits of 1 to 2 miles per gallon better gas mileage, also reduced front component wear.
    DJB1, jackn7, cosmicfires and 9 others like this.
  16. Dec 4, 2019 at 5:17 PM
    Key-Rei
    Key
    Florida
    Bad idea. 4lo double the torque and when the front wheels want to match the back wheels speed in a turn you understeer plow through the corner overcorrect and go into the wall.
    jbrandt, xxTacocaTxx and GQ7227 like this.
  17. Dec 4, 2019 at 5:17 PM
    Jay1193
    Jay1193 [OP] Member
    Jay
    1997 2.7 4c tacoma
    Thank you!
  18. Dec 4, 2019 at 5:18 PM
    Key-Rei
    Key
    Florida
    Yes, otherwise you're spinning the differential under power but it's not being transmitted to the wheels by the hubs. (Because they're unlocked and free spining)
  19. Dec 4, 2019 at 5:18 PM
    Jay1193
    Jay1193 [OP] Member
    Jay
    1997 2.7 4c tacoma
    This is exactly what I needed. Thank you
    TXpro4X4 and Speedytech7[QUOTED] like this.
  20. Dec 4, 2019 at 5:19 PM
    2JHilux
    Denver, CO
    Think of it like this, no matter what 2HI is always 2wd.
    IF you have your hubs unlocked and you shift to 4hi... you are still in 2wd cause the hubs aren't locked.
    IF you have your hubs locked and you shift to 4hi, you are now in 4hi cause your hubs are locked.
    Basically, its just a way to save wear and tear on the front axles and carrier bearing (*cough* drivers side) when you know you won't need 4wd.
    You could roll around all the time with the hubs locked and in 2wd, but the front tires spin the front axles and the bearings in the front differential, and the bearings aren't as beefy as the ones they use on AWD vehicles like the gx470 etc.. where it is always spinning in the front. They actually do make a aftermarket bearing you can put in if and when you get the bearing noise (usually on a lifted truck), but that is probably alot of extra info you don't need.
    That being said, sometimes you get stuck in a situation where you think you didn't need it... then you have to get out and lock it real quick which is not very fun.
    TacomaJunkie8691 and Jay1193[OP] like this.
