Fishtailing tacoma in the snow
Discussion in '1st Gen. Tacomas (1995-2004)' started by Jay1193, Dec 4, 2019.
  1. Dec 5, 2019 at 7:36 PM
    #61
    Louisd75
    Louisd75 Well-Known Member
    Northwest Washington
    '02 Xtra Cab, '15 DCSB
    One gripe about the test, probably a bit nitpicky, but they should have kept the jeeps in the same "lane" for both tests. It's entirely possible for road conditions to be different enough to skew the results.
    Personal experience leads me to put it into 4 hi in snow. Both of my trucks feel more planted and responsive to my inputs when in 4 hi. I also have canopies and strap down a couple hundred pounds of ballast over the rear wheels.
    Dagosa and cruiserguy like this.
  2. Dec 5, 2019 at 7:47 PM
    #62
    SouthernYoder
    SouthernYoder If you skarred, say you skarred.
    Knoxvegas, TN
    01 dbl cab 4x4 3.4l SR5
    3" OME, 883 coils, Nitros, AAL, 07 FJ Trail team wheels, K&N CAI, Tundra brake upgrade.
    I honestly can’t even believe this is a thread. Lock the hubs, 4hi, pick the high line and have weight in the bed over the axle. Jesus Christ.
    IBTL :locked:
  3. Dec 5, 2019 at 8:21 PM
    #63
    frenchee
    frenchee Favorite Member
    Oceanside CA Area
    2003 Tacoma TRD Double Cab 4x4
    Converted to 4WD DD VW MK6 TDI
    Damn truth hurts. Must be lot of confused people tonight.
    OP. If you want any type of 4 wheel drive, hubs need to be locked.
    Good luck
    PS: My taco sucks in the snow with my mud terrains. Even with 4X and rear end locked. Proper tires is the way to go. Forget all the round abouts that fcked me in Bend Oregon.
    Jay1193[OP], Dagosa and SouthernYoder like this.
  4. Dec 6, 2019 at 6:45 AM
    #64
    Dagosa
    Dagosa Well-Known Member
    New England
    2015 Taco TRD OR
    Debaged
    Getting stuck and driving at highway speeds are two different things. My 4 Runner never got stuck in deep dry snow when in awd, but struggled in mud and heavy wet snow. A modern awd will apportion up to 50% of the torque from and rear, just like 4 wd, but it’s just not continuous. The difference is, it’s variable which is not good in mud and sand and won’t spin enough to clear the treads which is good for low speeds but poor for highway speeds. Modern traction control with awd doesn’t mean one wheel drive. All the tires can receive torque. The problem is, it limits torque, not boosting and maintaining it like locking diffs do. Again, one is better in slippery conditions and higher speeds, one at lower speeds ( 4 wd) with more drag where spinning is advantageous.
    One of the plow trucks I use, has both auto awd and locked 4 wd.
    Traveling from one job to another, it’s in awd, but actual plowing, it goes into 4 wd. I’d be all over the place driving too fast in 4 wd with a plow hanging ff the front. The awd system constantly balances the traction needs and keeps better control while traveling.
    CS_AR likes this.
  5. Dec 6, 2019 at 7:36 AM
    #65
    SierraMare
    SierraMare Well-Known Member
    Ted
    Alaska
    2001 TRD OffRoad Xtracab, stepside bed, 2.7 L, 5-speed manual
    ARE cap, BFG KO2 (LT 245/75R16), Front Bilstein 5100 with OME 2881 coils, Rear HS 3-leaf progressive AAL.
  6. Dec 6, 2019 at 10:53 AM
    #66
    paetersen
    paetersen Well-Known Member
  7. Dec 6, 2019 at 10:54 AM
    #67
    firstgentacotuesday
    firstgentacotuesday Well-Known Member
    CA
    ‘01 3.4 4x4
    Just thought id share my experience w/ snow in our trucks. I just recently drove up to Big Bear in the San Bernardino mountains last friday when they got 56 in. of snow in 2 days. The roads were horrible, icy and slushy. I had chains on the rear tires and was in 4hi the whole way up the mountain. I am a careful driver, so it was slow going most of the way but the truck never lost traction for more than a split second before regaining. This is with AT tires as well so not even close to the best setup. Fastest i went all weekend was 25 mph, but the truck performed amazing. Going right thru all sorts of tough shit. I was super impressed and kinda of proud actually haha since i saw a few 3rd gen tundras getting stuck on the way up.
    Dagosa, TacomaJunkie8691 and frenchee like this.
  8. Dec 6, 2019 at 11:27 AM
    #68
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    I think you just emphasized how important moderate speeds, experience and chains are. Chains are a great equalizer.
  9. Dec 6, 2019 at 11:59 AM
    #69
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    You just turned back automotive technology decades. Abs works because it treats every wheel separately in slippery conditions. This along with open diffs of awd, allows awd cars to stay under control while stopping and accelerating in slippery weather. Other then following a Zamboni on an ice skating rink, never will all four wheels of any car face exactly the same conditions when traveling in slippery conditions. Computer monitoring with abs and traction control with awd does what no driver can do; control each wheel separately during braking and accelerating. Locking them all together on ice is a recipe total loss of control. Deep snow.....different story.
    xxTacocaTxx and TacomaJunkie8691 like this.
  10. Dec 6, 2019 at 12:09 PM
    #70
    TacomaJunkie8691
    TacomaJunkie8691 1999WineTacoma
    WA State
    1999 Wine Tacoma SR5 Exta-Cab 4wd V6
    Completely Stock except for Ranch 5000 Shocks and Struts.
    There are some good posts here on how four wheel drive and all wheel drive systems work so I am not going to be redundant by going over these points again.
    First generation Tacomas are pick-up trucks. They have one huge fundamental problem when being used in snowy conditions. They are poorly balanced. They are heavy in the front, and lite in the ass. The best way to utilize them in the snow is to completely stay out of the throttle.
    Our old 1999 Tacoma has seen its fair share of snow, and it has gone places that even surprised me, but it is driven extremely cautiously in the snow.
    Hope that helps,
    Paul
    ffirg and Dagosa like this.
  11. Dec 6, 2019 at 12:12 PM
    #71
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    I hear you. The best Toyota trucks in snow for me, have been the 4 wds with four cylinders.....studded shows, 2-300 lbs of tube sand in the back, and they were awesome. The sixes require more weight in the back....much more. The fours were so underpowered, staying off the throttle was “ natural.”
  12. Dec 6, 2019 at 12:37 PM
    #72
    firstgentacotuesday
    CA
    ‘01 3.4 4x4
    Definitely would have been super sketchy w/o chains. Another thing to note is i have maybe 100 lbs in the bed. Idk how much that helps but its a factor.
  13. Dec 6, 2019 at 1:13 PM
    #73
    frenchee
    Oceanside CA Area
    I got a shell, roof top tent, and a drawer system full of crap. The fish tailing went away, but the whole steering was AWFUL, given why I started hating roundabouts. I was crawling at 5mph or so and weeeeeeeeeeeeeeeeee. I usually love them.
    I'm on the look out for new tires once these die. Don't want a dedicated snow, but something better than these crappy mud terrains (Snow wise).
    Dagosa likes this.
  14. Dec 6, 2019 at 1:14 PM
    #74
    Hagstromez
    Hagstromez Member
    Bradley
    Denali, Alaska
    2004 Tacoma 3.4 4x4 5spd super white ex cab
    New frame compliments of Toyota 12/18 ARB bumper 3/19 Complete OME suspension 3/19
    Right on Dagosa, I guess this is why I have chosen to drive a decades old truck :rofl:
    Our 1st gen Tacomas never came with that stuff as far as I know, so it's a little outside the point I was trying to make. (4wd stops faster than 2wd)
    But you're right - there are some real benefits to the driver aids you're referring to.
    Personally, I drove a '19 for a while and I just hated what I thought of as electronic training wheels. I like to do all my own driving.
    To each their own!
    P.S. Laughed when I read "Following a Zamboni on an ice rink".
    Shut off the arena lights and throw in some moose and you've described my morning commute.
    cosmicfires likes this.
  15. Dec 6, 2019 at 1:25 PM
    #75
    Louisd75
    Sounds like your tires are already dead to me. :notsure:
  16. Dec 6, 2019 at 1:51 PM
    #76
    frenchee
    Oceanside CA Area
    Tread wise there's plenty left. It's just the tread and tire compound. Just not designed for snow. No good. I'd say worse than an all seasons tire honestly.
  17. Dec 6, 2019 at 2:43 PM
    #77
    Louisd75
    Honestly, it wouldn't be worth it to me to run a tire that I felt was subpar for the conditions. I just wouldn't care to run out my tire life if it was sketch to drive on. I get trying to save money, but is it really saving you money if you wreck?
  18. Dec 6, 2019 at 2:53 PM
    #78
    frenchee
    Oceanside CA Area
    Well I don't live in the snow. So I'm keeping em. If I lived in the snow then yeah I'd have a winter set. They are great when there is no snow.
  19. Dec 6, 2019 at 3:23 PM
    #79
    Louisd75
    Well, when you wear 'em out, I highly recommend General Grabber AT/2's. I ran them in 265 70 R16 and 235 85 R16 on my 1st gen. I've been very happy with the 235's in dry, rain, slushy snow, dry snow and decent on icy snow. They're not a mud tire, but they still do pretty well all things considered. :)
    Dagosa and frenchee[QUOTED] like this.
  20. Dec 6, 2019 at 3:29 PM
    #80
    Dagosa
    New England
    2015 Taco TRD OR
    Debaged
    I hear you. There are situations where cars will stop faster without electronic aids. But, that’s not what abs and traction and stability control is all about. It allows the driver to steer and maneuver while stopping which is impossible otherwise. There is no way any driver can manipulate the four brakes separately, on each wheel.
    Abs arose from the systems used on airlines when they landed. I think even those who like braking a car themselves, are happy the pilot has happily given up that choice on snow and rain soaked covered runways with hundreds of passengers lives are at stake.
