Fit Without Lift?
Discussion in '2nd Gen. Tacomas (2005-2015)' started by Coastie3202, Feb 16, 2015.
  1. Feb 16, 2015 at 12:06 PM
    Coastie3202
    Coastie3202 [OP] Member
    SW soon to be PacNW
    09 Taco Prerunner
    I promised my wife that I would not buy new tires and rims until I wore out the tires on my 09 Taco Double Cab SB PreRunner. Yay, the time has finally come.
    I intend to go from BFGoodrich Rugged Trail T/A 265/70 R16 to:
    BFGoodrich All Terrain T/A KO2 275/65 R18 mounted on American Outlaw Buckshot 18 X 8.5 matt black rims.
    My PreRunner has the factory suspension with no lift.
    Does anyone know if my truck will require a lift with the new tires/rims, or just a possible trim of the wheel well plastics?
    Thanks for your help.
  2. Feb 16, 2015 at 12:15 PM
    geekhouse23
    geekhouse23 The "Liftman" - @DrFunker
    2GMGMDCSB4WDTRDFTMFW!! TL;DR
    mostly stock, grocery gettin' Prius
  3. Feb 16, 2015 at 12:17 PM
    Coastie3202
    SW soon to be PacNW
    09 Taco Prerunner
    Thanks Geekhouse. I already looked at that. But imagine it is based on no rub, not on wheel well mod possibilities. That's why I threw the question out there.
  4. Feb 16, 2015 at 12:20 PM
    geekhouse23
    What is the back psacing of the rims? You might rub on the UCAs. I run 285s and had to trim a bit. Wheel well liner, CMC, remove mudflaps. And I still have to beat the pinch weld in and trim some more likely.
  5. Feb 16, 2015 at 12:31 PM
    Coastie3202
    SW soon to be PacNW
    09 Taco Prerunner
    Geekhouse - LT275/65R18 123R E1 RWL - does any of that have the backspacing? I haven't a clue.
    What is UCA.
    I understand the wheel well liner, but CMC? I am prepared to remove the front mudflaps if necessary.
    You are running 285s and had to make some adjustments without a lift kit. I will be running 275s. So it seems that I may not have to make as many adjustments as you. Am I correct?
    Are you running 285s on 18 inch rims?
    This is all new to me, so be gentle. LOL
  6. Feb 16, 2015 at 12:35 PM
    geekhouse23
    Back spacing is on the wheel not tire I believe. So I have 4.5" backspacing on my wheels.
    UCA = upper control arms
    CMC= Cab mount chop
    I'm running 285s on a 3" lift and had to trim all that.
    I'm on 16's :eek:
  7. Feb 16, 2015 at 12:36 PM
    Coastie3202
    SW soon to be PacNW
    09 Taco Prerunner
    Well shit. Thanks for the info geekhouse.
  8. Feb 16, 2015 at 6:59 PM
    jagergirll
    jagergirll Well-Known Member
    Sam
    Midwest
    4x4 RC
    OME Suspension ARB Bumper Rock Sliders BFG KO3's Camper Shell
    Anyone run a 255/75/R16? I am looking to go to that from a 265/70/R16. Stock suspension for now.
  9. Feb 16, 2015 at 7:05 PM
    RCOTaco
    RCOTaco Long Time Lurker
    Dalton
    Hamlet, NC
    Super White DCSB 4x4
    Bilstein 5100s on Stock Coils, Light Racing UCA's, Pro Comp Wheels, 265/75 Baja MTZ's, Cobra 18 WXST, 4' Firestik, UWS Toolbox
    I'm doubtful they make that size tire jagergirll
  10. Feb 17, 2015 at 6:09 AM
    Pigpen
    Dan
    Northwest Montana
    If you found that size, it's actually smaller than 265/ 75/ 16 which fits just fine and is readily available in many styles and ply ratings. If you want skinnies, look at 235/ 85/ 16. They are widely available and are basically the same height as the 265/ 75, but are generally only available in 10 ply (E rated) because they are mostly run on duelly work trucks.
    I'm very happy with my 265s and will run those until I get UCAs so I can fit 255/ 85/ 16. I run C rated (6 ply) and they seem to hold up well and run smooth for my uses.
    Edit: That's my experience with my 6 lug, maybe someone who knows better can chime in on fit for your 4 banger.
  11. Feb 17, 2015 at 6:14 AM
    HomerTaco
    HomerTaco
    HomerTaco
    HomerTaco
    Here's 285/75r16's on a 09' Tacoma with NO lift at all:
    Basic Cab Mount Chop and pinch weld beating... Shaved off some fender flare and that's it.
    If you don't mind cutting go for it. :cool:
