fitment question?
Discussion in 'Wheels & Tires' started by whitmextaco, Feb 8, 2012.
  1. Feb 8, 2012 at 9:51 PM
    whitmextaco
    whitmextaco [OP] Active Member
    Houston
    White TRD Double cab short bed 4x4
    None
    Okay guys this is my plan.. I want to know if this setup would be possible?
    Tires 295/55/20 Nitto trail grapplers
    wheels 20x10 -24mm offset
    suspension set up would include toytec ultimate lift with lower control arms
  2. Feb 9, 2012 at 4:49 AM
    Large
    Large Red
    You'll have quite a bit of rubbing, also I suggest you get 20x9.
  3. Feb 9, 2012 at 5:46 AM
    TexasTacoma37
    TexasTacoma37 Well-Known Member
    x2
  4. Feb 9, 2012 at 5:50 AM
    whitmextaco
    Houston
    None
    okay what about 20x9 18mm offset on the same tire size?
  5. Feb 9, 2012 at 5:52 AM
    TexasTacoma37
    +18 offset? Not a chance. That's 6" of backspacing. You will want around 4.5"
    Here's a page that helps you convert width and offset to backspacing.
    https://www.rsracing.com/tech-wheel.html
