Fitment?
Discussion in 'Wheels & Tires' started by madisonsfinest, Jan 30, 2010.
  1. Jan 30, 2010 at 12:25 PM
    madisonsfinest
    madisonsfinest [OP] Addicted to my DSLR
    Madison, WI
    2010 DC OffRoad 4x4 Debaged
    Factory Roof Rack Avid Offroad Light Bar 16" XD Hoss Truxedo LoPro QT Window Tint Autobot Emblem w/Autobot Shifter Color Matched Grille
    Will these XD Hoss wheels fit my bfg all terains? They are the stock trd off road wheels on a 2010.
    Part Number: W/PXD79568068300
    • 16x8, 6 on5.5 Bolt Pattern
    • Backspace 4.50 in.
    • Max Load = 2200lbs
    • Finish = Matte Black
    • Hubcentric = No
    • Offset = 0 mm
    Thanks for any help!
  2. Jan 30, 2010 at 2:31 PM
    madisonsfinest
    Madison, WI
    does it matter if they are hubcentric or not? Help they are on sale with free shipping.
  3. Jan 30, 2010 at 2:33 PM
    automoto
    automoto Well-Known Member
    jersey shore
    07 SR5 4X4 AC
    you need lug centric wheels, so those should be fine if it says hubcentric-no. what size are the bfg's??
  4. Jan 30, 2010 at 2:42 PM
    madisonsfinest
    Madison, WI
    the stock I believe its 265/70/16. I don't think it matters at this point. The guy at 4wheelparts said that the 16" would not fit my truck
  5. Jan 30, 2010 at 2:44 PM
    automoto
    jersey shore
    07 SR5 4X4 AC
    the tires in that size will fit no problem. 4wheel always says that, ask other members. Sometimes its as simple as grinding a small amount on the caliper to get it to work, or you could go up to a 17" wheel...
  6. Jan 30, 2010 at 8:36 PM
    madisonsfinest
    Madison, WI
    I'm trying to keep this as cheap as possible so I want to use my stock tires. Evil Monkey said these wheels fit on his without any fitment issues. He has an 07 DC OR. I have a 2010. Do you know if the brake caliper is the same size between the 07, and the 10? Thanks
  7. Jan 31, 2010 at 8:34 AM
    madisonsfinest
    Madison, WI
    So I've talked with a couple people here that say the wheels fit without issue. I placed the order today. Do I need to get the extra lugs, or can I use the ones I have on my stock wheels now? Thanks
