Fitting 265/75/r16 on a regular 2wd
Discussion in '2nd Gen. Tacomas (2005-2015)' started by volcomig, Mar 24, 2013.
  1. Mar 24, 2013 at 7:58 AM
    volcomig
    volcomig [OP] Well-Known Member
    miguel
    canada
    2wd sr5
    2.75 inch lift, Bigger tires, bull bar and backrack
    Hi i bought 265/75/r16 for my regular 2wd acces cab 2009. It has got a lift (1.75back 2.75front. They are rubbing when i turn. I was thinking of getting spacers. Would it still rub? If anyone has done it, what spacer size?
  2. Mar 24, 2013 at 8:57 AM
    BradyT88
    BradyT88 Well-Known Member
    What is it rubbing on when you turn? If it is rubbing on fenders or the cab mount spacers will likely just make it worse. Spacers will really only help if you are rubbing on the frame which I kind of doubt you are. Your best option is to start trimming the fenders and/or chop the cab mount. Basically wherever you are rubbing.
  3. Mar 24, 2013 at 11:20 AM
    volcomig
    miguel
    canada
    2wd sr5
    IMG_1393.jpg its rubbing on the bar behind the tire the one in front of the frame. I think its the one that makes the truck turn.
  4. Mar 24, 2013 at 11:30 AM
    BradyT88
    The bar in the picture is the sway bar. I believe spacers will help fix that not positive though. I just took mine off but I offroad a lot.
  5. Mar 24, 2013 at 12:25 PM
    volcomig
    miguel
    canada
    2wd sr5
    ok thanks:) it would be good to have someone that has done it with same truck and same tire size.
