Fitting 285/75R16 Tires on a 2nd Gen w Bilsteins & Stock Wheels...
Discussion in 'Wheels & Tires' started by Chet_Ubetcha69, Nov 26, 2020.
  1. Nov 26, 2020 at 9:50 AM
    Chet_Ubetcha69
    Chet_Ubetcha69 [OP] New Member
    2015 PreRunner V6 Double Cab
    As the title says, I'm looking to throw some 285/75R16s on my 2nd Gen pre runner with stock wheels... just installed some Bilstein 5100's on the front at max height (2.5 in) and a 1.5 in block in the back. Will I have the clearance to be able to fit these size tires on with minimal rubbing? I do not off road or climb or anything of that nature, so they'll just be on pavement. I want to avoid buying spacers or aftermarket wheels if I can, for now at least. Just wanna make sure I can fit these comfortably under the truck before buying them. Thanks all!
  2. Nov 27, 2020 at 8:11 AM
    gotoman1969
    gotoman1969 Well-Known Member
    San Antonio, TX United States
    2015 Silver Tacoma PreRunner
    Unfortunately they’re gonna rub somewhere. Each truck is slightly different. Will more than likely need ucas for alignment to be done properly, then maybe a cmc.
