Fitting 285s?
Discussion in '3rd Gen. Tacomas (2016-2023)' started by ievko82, Oct 9, 2016.
  1. Oct 14, 2016 at 11:55 AM
    #41
    Humboldt_Homie
    Humboldt_Homie If you're not first, you're last.
    16 TRD OR DCLB
    Bilstein 6112 front, 5100's rear with blocks, camburg UCA, 17" XD's with 285/70/17 AT 3's and a blackout front grille.
    Which wheels? how much backspace? I am completely flabbergasted! :confused::bananadead:
  2. Oct 14, 2016 at 11:59 AM
    #42
    TastyTaco
    TastyTaco Well-Known Member
    Nick
    Vancouver, WA
    2003 Taco 3.4 DC TRD
    3" Lift, BFG K02 285/70/17, Pro Comp 45 Series 17x9 -6, ACME D2S Retrofit
    I also have this setup with no rub! 285/70/17 on mine -12 17x9
    DjSamthrax likes this.
  3. Oct 14, 2016 at 12:14 PM
    #43
    20taco16
    20taco16 Well-Known Member
    Beau
    2017 metallic grey double cab long bed 4wd
    I have the mb wheels model 352, with 285/70/r17 bf KO2's with no rubbing
  4. Oct 14, 2016 at 12:24 PM
    #44
    OffRd 5TRMTPR
    OffRd 5TRMTPR Well-Known Member
    2016 White Tacoma TRD Off Road
    https://www.tacomaworld.com/threads...-toyota-tacoma-no-vibes.414540/#post-13120976
    This thread is what started me to look into purchasing them. Actually ordered them directly from the website he references. Saved $50 overall vs morimotos. These run $125 a kit vs. $150
  5. Oct 14, 2016 at 1:02 PM
    #45
    Leo4x2
    Leo4x2 Well-Known Member
    Leo
    San Antonio, Tx
    2016 Toyota Tacoma SR5
    Maxtrac/Bilstein suspension 16x8 Pro Comp 69 315/75/16 Dick Cepek Morimoto Profile Prism RGB Halos & Demon Eyes
    What wattage did you go with on the lows and fogs? Do you have the H16 or H11 in the fogs?
    Also, I wouldn't go with hid's in the highs like that member did, they take time to warm up so wouldn't get the full effect of th
  6. Oct 14, 2016 at 1:07 PM
    #46
    OffRd 5TRMTPR
    Standard AC = 35W. I went with H11 bulbs.
    I didn't go with HID High beams either. I think the OEM High beams are enough. Plus i ran out of decent places to mount the Ballasts.
  7. Oct 14, 2016 at 1:23 PM
    #47
    Humboldt_Homie
    16 TRD OR DCLB
    I see you own a 2017. Is that the trd off road? I wonder if my 2016 suspension parts are different or something. I can't imagine why those wheels would work for your truck but not mine. Thanks for the responses.
  8. Oct 14, 2016 at 6:05 PM
    #48
    20taco16
    Beau
    All the suspension should be identical, I have bilstein front shockers raised 2.5", maybe your aren't getting as high in the front as you think you are
  9. Oct 14, 2016 at 6:05 PM
    #49
    20taco16
    Beau
    Mine is the SR5, not trd off-road
  10. Oct 14, 2016 at 6:09 PM
    #50
    20taco16
    Beau
    Measure from the ground through the center of the rim to the fender.....what height are you achieving? I'm at 38.5"
  11. Oct 14, 2016 at 6:24 PM
    #51
    20taco16
    Beau
    I'm running led headlights and fog lights, love them! About $90/pair, here is the spread. Mine are the 4th gen, 85 watt....the link is for the 5th gen...100w, over 5000 lumens each....I got 6000k color temp
    http://m.ebay.com/itm/231981493150?_mwBanner=1
    #51
  12. Oct 14, 2016 at 9:33 PM
    #52
    RunnerFirst
    RunnerFirst Member
    Enrique
    Orange County, CA
    '16 Tacoma TRD Sport 4X4
    Leveled 3" & 1" Grille, Vision wheels, Pro Comp tires
    The new all terrain tires have aggressive lugs compared to the original tires. The rubbing doesn't happen if turning on leveled ground.
  13. Nov 4, 2016 at 12:10 PM
    #53
    Mr. Projekt
    Mr. Projekt Well-Known Member
    Caleb
    Harpers Ferry, WV
    2021 DCLB TRD-OR 4x4 Army Green
    I appreciate all the input here... I was about to order the wrong set of wheels... I am thinking I'm going to pick up the Raceline Injector in 17x9 -12mm to fit my 285s once I get the lift on!
    #53
  14. Nov 4, 2016 at 3:24 PM
    #54
    DjSamthrax
    DjSamthrax Master Certified Toyota Product Specialist
    Sam
    Minnesnowta
    2018 Tacoma TRD-Off Road Double Cab Long Bed Cement
    18x9 Roost w/285/65/18 BFGoodrich K02, Icon Stage 4, Rough Country 30" Light Bar, Tekonsha P3 Trailer brake controller, Viper Smart Start w/GPS, Custom Screen Off Image, DDM Tuning 55w HID Low, LED everything else, Clearshield Platinum Package, Auto Armor, Tint, Every OE Toyota cargo management accessory ;-)
    I'm on 285/65/18 with an Icon S4 lift, only hits the cab mount at certain angles when compressing. Lots of plastic trimmed but worth it!
  15. Nov 4, 2016 at 5:16 PM
    #55
    ievko82
    ievko82 [OP] Well-Known Member
    WV
    17 sport DCSB quicksand
    How much lift did your stage 4 give you? Are your wheels a -12 offset?
  16. Nov 4, 2016 at 7:04 PM
    #56
    Skyking90
    Skyking90 Well-Known Member
    Steven
    Anchorage, Alaska
    2016 Tacoma TRD Sport
    Icon Stage 4, STT Pro 285/75/16, SCS Stealth6, Bakflip MX4
    I am interested in the icon stage 3 for use with 285/75/16. Anyone have this combo or any icon lift with this tire size?
    Also still pretty new to all this, but does the icon suspension lift kits come with everything you will need? Do you recommend going at it a different way?
  17. Nov 5, 2016 at 3:27 PM
    #57
    DjSamthrax
    Sam
    Minnesnowta
    I believe I am -12ET with 4.5" backspacing. I have the fronts about a half inch over the recommended settings to assist clearing the cab mount but its about 3" overall. I can take a tape to it sometime tonight and see where I'm at vs stock
  18. Jan 6, 2017 at 9:45 PM
    #58
    Biggums
    Biggums Well-Known Member
    Jade
    SoCal
    Going to be putting on 285/70/17 on the SCS Ray 10s. Anyone have this wheel/tire combo that could provide feedback on rubbing, if any?
  19. Jan 6, 2017 at 9:48 PM
    #59
    erok81
    erok81 Well-Known Member
    Imposter
    Which wheels?
    I ran that same setup (stange five though) with tubular arms and everything fit fine. Nothing extra needed.
  20. Jan 7, 2017 at 12:22 AM
    #60
    TacoSharky
    TacoSharky Well-Known Member
    Socal
    Same here will find out by Wednesday hopefully :)
