Fitting 33’s on 2019 Tacoma
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Tacoman247, Apr 21, 2020.
  1. Apr 21, 2020 at 6:57 PM
    Tacoman247
    Tacoman247 [OP] New Member
    2019 Tacoma trd off road
    I recently bought a 3 inch lift and am looking at how to best fit trail grappler 285/70r17’s without rubbing because I hear that they would.
    stacksmasher likes this.
  2. Apr 21, 2020 at 7:00 PM
    boston23
    boston23 Well-Known Member
    Adam
    Eastie
    2019 SR5 DCSB 4x4
    Cab mount chop, bfh, high caster uca’s
    t0nyvalenzuela and Tibetan Nomad like this.
  3. Apr 21, 2020 at 7:01 PM
    TacoTime850
    TacoTime850 Always Maybe Sometimes Never
    Everywhere and Nowhere
    2019 DCSB 4x4
    2.5” lift, Fox 2.5 ext tvl adjustable w/ DSC, SPC adjustable UCAs, Icon RXT leaf pack, Superbump stops, 17x9 Fuel Podium Bronze wheels, 285/70/17 Cooper STT Pro
    Welcome to TW!
    Do a search. This has been talked about and talked about so many times on so many threads. You should easily be able to find your answer with much detail and feedback from lots of folks.
    Best place to search is the suspension thread.
    https://www.tacomaworld.com/forums/suspension.18/
  4. Apr 21, 2020 at 7:07 PM
    stacksmasher
    stacksmasher Well-Known Member
    I see so many people wanting 33 inch tires. Is there a specific reason? 3 inch lift, chopping a cab mount and replacing your UCA's seems like a lot of work for a few inch bigger tire. Is this mostly for clearance so you can clear rocks and stumps? I'm just curious.
  5. Apr 21, 2020 at 7:13 PM
    TacoTime850
    2019 DCSB 4x4
    Yes
  6. Apr 21, 2020 at 7:15 PM
    Bishop84
    Bishop84 Well-Known Member
    Yes.
    Then they come back on posting about poor MPG and lack of power.
  7. Apr 21, 2020 at 7:15 PM
    Rockefelluh
    Rockefelluh Well-Known Member
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    Looks for sure are a part of it as well.
    OP, if you don't compress the suspension by going offroad and in ruts, etc, you may not rub daily driving.
    Unfortunately it varies somewhat depending on wheel backspace, tire manufacturer, vehicle etc. But You will very highly likely rub off road.
    stacksmasher[QUOTED] likes this.
  8. Apr 21, 2020 at 7:19 PM
    johntoyota
    johntoyota "I'm higher than you'll ever be." -Treetop
    Down yonder in TN
    16 truck
    Not talking shit, but some of us bought our trucks to get us to places that most trucks cant go. 31s on a truck as long as these will find its limitations very quickly.
  9. Apr 21, 2020 at 7:20 PM
    johntoyota
    Down yonder in TN
    16 truck
    33s and no cab mount chop, will rub.
    Tibetan Nomad and DR TACO like this.
  10. Apr 21, 2020 at 7:25 PM
    Rockefelluh
    Rocky
    Orange County, CA
    2018 DCLB TRDOR 4x4
    There’s anecdotal evidence suggesting a lift of 3 inches won’t rub DD. I have no idea. I would just get the CMC. but there’s always stories of no rubbing (even off roading) and it turns into a dumpster fire.
    johntoyota[QUOTED] likes this.
  11. Apr 21, 2020 at 7:28 PM
    johntoyota
    Down yonder in TN
    16 truck
    People on TW like to spit all kinds of bs. A lift doesnt really do anything for clearing bigger tires unless you limit the up travel like crazy (eliminating a huge chunk of the lifts potential) with a big ole bump stop. The only thing I will say, is that if he is going 33s, hes going to end up doing the cmc so may as well go ahead and do it. My 2 cents. :thumbsup:
    Rockefelluh[QUOTED] likes this.
  12. Apr 21, 2020 at 7:29 PM
    Aaronparker001
    Aaronparker001 Just another basic dude in a tacoma
    Pacific Northwest
    2019 TRDOR DCSB MT BLACK
    Buy 255/80r17’s. No rub at stock height.
    t0nyvalenzuela and boston23 like this.
  13. Apr 21, 2020 at 7:30 PM
    Loco_Barbon
    Loco_Barbon Just deez nutz hangin’ out
    Hugh Mungus
    Where ever my 10mm isn’t
    i LiKe tRuCkS!!
    Penis valve stem caps.
    No way around a CMC. Wheel offset will help a little, but will still rub at full lock.
    Tibetan Nomad and johntoyota like this.
  14. Apr 21, 2020 at 7:31 PM
    johntoyota
    Down yonder in TN
    16 truck
    ^^^^^ this.
  15. Apr 22, 2020 at 4:50 AM
    TacoTime850
    2019 DCSB 4x4
    Hey man, just search around. You definitely don’t have to have a cab mount chop to fit 33s. I don’t know why people get so bent about this subject.
    I have 285/70/17 KO2s which are 32.8” tires and I don’t have a CMC. The only thing I did was remove the front chin spoiler. I also trimmed about 3mm of plastic with a dremel on the front of the fender well. You can’t even tell it’s trimmed.
    You don’t need a 3” lift to fit 33s. I did this with only a 2” lift. I now have a 2.5” lift because I changed to coilovers.
    The way to get around a CMC is to install some adjustable upper control arms like SPC and adjust the caster alignment to bring the front tires as far forward as possible. This will also improve the steering and tracking after you lift the front.
    My tires never get closer than about 3/4” from the cab mount after the SPCs were installed and caster was adjusted. I have done some decent off-roading and have never rubbed so far.
    I average 21 MPG during my commutes of 20 miles each way. If I get on the interstate and speed around 65-70, It comes down to about 19 MPG.
    I also don’t notice any loss of power and/or performance.
  16. Apr 22, 2020 at 5:20 AM
    aahyut
    aahyut Well-Known Member
    Sweden, Maine
    2019 TRD OR DCSB
    Also the larger the tire, the flatter the bumps. Try rolling a floor jack over a zip tie. It may not seem like much but every inch matters when doing high speeds on logging roads.
  17. Apr 22, 2020 at 7:18 AM
    stacksmasher
    Good to know!
  18. Apr 22, 2020 at 7:21 AM
    aahyut
    Sweden, Maine
    2019 TRD OR DCSB
    I had 33s on my F-150 and went to 35s, going to to 31s on my Tacoma and I am finding all sorts of new bumps in the road. 33s are on order for the Tacoma. I think 35s on a Tacoma are a great idea, just it's a little much for me until I plan to regear.
  19. Apr 22, 2020 at 7:52 AM
    Dr. Emmett Brown
    Dr. Emmett Brown Well-Known Member
    *32.7"
    :D
  20. Apr 22, 2020 at 7:52 AM
    rlx02
    rlx02 ¯\_(ツ)_/¯
    Western WA
    2017 Inferno DCSB TRD OR 4x4
    285/70/17s. Stock gearing. 17-18mpg right now, 19-20mpg in the summer. I have all armor except for skids too.
    no ragrets.
    Rockefelluh likes this.
