Fitting 33" (285) spare
Discussion in '3rd Gen. Tacomas (2016-2023)' started by Joe23, Mar 30, 2018.
  1. Dec 9, 2022 at 9:43 AM
    #121
    tacomarin
    tacomarin ig: @travelswithchubbs
    Bay Area
    2018 DCLB TRD OR
    Prinsu Cab and Top Rack VO Drifter LED Interior, License Plate, and Reverse Lights Huskyliner Weather Beater floor mats Salex Center Console Organizers 35% Front/15% Rear Tint Debadged and De-stickered Anytime Front and Rear Cameras Brute force front bumper BAMF HC Dual swing out 285/75r17 BFG KO2 Front: ADS 2.5, EXT, RR, Clickers Rear: OME Dakar HD, ADS 2.5, EXT, RR, Clickers Stainless steel brake lines (+4 in rear) Wheeler's Offroad Superbumps Front and Rear Wheeler's Offroad U-bolt flip ECGS CV Axle Bushing SCS Stealth 6 17x8.5 wheels, matte dark bronze
    Get some ratcheting box wrenches. I don't remember what size, maybe 12mm? It's something normal, not big. Also be ready to hold a half crunch for 20 minutes unless you have a lift of jack up the truck.
  2. Dec 9, 2022 at 10:02 AM
    #122
    Nemesis-dsl
    Nemesis-dsl Well-Known Member
    21 Trd Sport.
    I will try that. Also do you recall the drill hole size? Thanks for the quick reply.
  3. Jan 30, 2023 at 1:19 PM
    #123
    itsmywifestaco
    itsmywifestaco Member
    Corey
    2021 TRD Off-Road DCSB army green
    King 2.5 all around Icon UCAs Icon rxt rear leafs Scs f5 dark bronze 285/70/17 BFG KO2s Cali raised sliders
    also interested in this. Would love to have a fully functional 5th wheel to rotate in. Suppose you could go without a sensor and it will read the spare when you rotate the 5th wheel into use.
  4. Jan 30, 2023 at 1:26 PM
    #124
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    For 2nd gens, the answer was no. You seem to have a 3rd gen though… Yes, what you suppose can be done, but kinda defeats the safety aspect of the TPMS. Just go deflate your spare and see if it trips the dash light. Then you have your answer.
  5. Jan 30, 2023 at 2:18 PM
    #125
    musicisevil
    musicisevil Lesser-Known Jack Wagon
    Alaska
    2019 TRD Sport
    Ecu only allows 4 sensors. You can add tpms to your spare, it just adds a step to each tire rotation.
    You have to remove the sensor ID of your new spare and add the ID of the former spare in its place.
    This can be done with techstream, a tpms tool, or an obd dongle and app like carista.
    You just need to make sure and write down your tpms sensor ids and keep track of them. I have mine written on the backs of the wheels
    TireFire likes this.
  6. Nov 5, 2023 at 5:29 PM
    #126
    weicheezy510
    weicheezy510 New Member
    weichao
    1999 Tacoma TRD 4X4
    None
    Commenting in case someone has a similar setup, 2022 tacoma sb with 285/70/17 at3w wild peaks. Cut off both tabs, pull the spare towards the hitch as your tightening, this will give diff clearance. You’ll still clear w/o pulling but diff will touch tire if flexed.
