Fitting 33's
Discussion in 'Suspension' started by VirginiaBound, Mar 25, 2011.
  1. Mar 25, 2011 at 6:45 PM
    VirginiaBound
    VirginiaBound [OP] Whyareyoureadingthis?
    Sam I am, green eggs and ham
    North of Maine, South of Spain
    I have searched and searched, I cant find a clear answer. I found a deal on some 33 inch Bfgs and want to jump on it. Will they fit on my truck with 5100's and Eibach coils? I understand there will be some trimming required but how bad is it? I have seen a few trucks like JLees with alot of cutting in the front, would I need all this just to drive around? If anyone could chime in and let me know Id really appreciate it. Id hate to buy these tires and they not fit.
  2. Mar 25, 2011 at 8:03 PM
    pudge151
    pudge151 Well-Known Member
    Sean
    Connecticut
    2015 Tundra Platinum
    i had 33x10.5x15 BFG AT on my 99 taco that had 3 inch lift with OME and top plate spacer, they rubbed, removed the front flaps, they rubbed. i had to trim
  3. Mar 25, 2011 at 8:12 PM
    05tacoSPORT
    05tacoSPORT Well-Known Member
    Tennessee
    TRD SPORT
    Geared and Locked
    I am fitting 35s on a 3" lift so buy them and make them fit
  4. Mar 25, 2011 at 9:48 PM
    wolfdog2314
    wolfdog2314 Well-Known Member
    Brush Prairie
    2011 Tacoma 4x4 Sport
    Eibach coils. 5100's all around. AAL. WickedFlow
    I have that suspension setup, 5100's at .85. With 285 tires. I still rub. The main point of contact is where the front mud flap used to be.
    It rubs in reverse and turning over bumps. It's not bad, but it gets kind of annoying.
    I'm sure with a little more trimming I could get it all the way gone, just lazy...
  5. Mar 26, 2011 at 8:57 AM
    VirginiaBound
    Ok, thankyou for the help guys. So basically it will be driveable from the shop getting them mounted to the house to trim. Its not going to rub unless Im nearing full lock?
  6. Mar 26, 2011 at 10:19 AM
    wolfdog2314
    Brush Prairie
    You'll be drivable for sure. The shop cut off the plastic hunk in the front part of the fender that kinda hangs down.
  7. Mar 26, 2011 at 12:05 PM
    Sublime
    Sublime Well-Known Member
    Phoenix, AZ
    08 TRD 4x4
    Icon/All Pro.....chopped for 35's
    Ya dude, you'll be good. Drive for a day or so and you'll see where it rubs. The fender liners and flares themselves can be trimmed with a utility knife.....easy peasy! If you wheel with them look into cab mount chop ($150ish), pinch weld mod (really not that bad) and UCA's to dial in your camber if still having issues.
    Good Luck
  8. Mar 26, 2011 at 3:48 PM
    VirginiaBound
    When I mounted my 32's I did the pinch weld mod. The only time these rub is at full lock with compression on the corner of the front bumper. That will have to be cut for sure, it sounds like it wont be as bad as I thought it would though. I called the guy again today on the tires, hopefully Ill get a call back.
    I really appreciate the help
  9. Mar 27, 2011 at 11:01 AM
    Sublime
    Phoenix, AZ
    08 TRD 4x4
    Dude, you've got a smooth ass lookin truck! It'll look beast with 33's!
  10. Mar 27, 2011 at 1:09 PM
    VirginiaBound
    Thanks man! I love Unknowns set up with the 33's, thats the look Im going to try to go for.
  11. Mar 27, 2011 at 11:42 PM
    chad68
    chad68 Master Jedi Member I am...
    Chad
    In a (Toyota) van down by the river! Sonoma Cownty
    2009 4x4 reg cab. Modded with more to come
    Polished 16x8 Pro Comp 1069's 4" BS Nitto Mud Grapplers 305/70/16 Magnaflow & glasspack muffler Stainless tip K&N 63 series Aircharger Vent visors Autometer volt and dig. temp. gauge custom mounted Factory chrome rear bumper (not black factory, one) TRD pedal covers TRD skid plate Hurst T handle shift knob Rear Tint Clear bra on the sides Chrome extinguisher Icon non resi coilovers, ICON RR shocks, black seat covers. And some other crap
    Well after reading most of your build, think I will just stick with my 33x12.5's. I know I would HAVE to regear with 35's, so that on top of hacking more than I have done already, doesn't sound too appealing as I once thought.
    Looks good though.
  12. Mar 28, 2011 at 8:25 AM
    05tacoSPORT
    Tennessee
    TRD SPORT
    Geared and Locked
    I was referring about running a 33.
  13. Mar 31, 2011 at 1:23 PM
    toycar18
    toycar18 Well-Known Member
    Colorado
    98 Reg Cab 2.7L
    OME Suspension, BFG 33x10.50 AT, Light Racing Upper Control Arms, Rear ARB Air Locker, LCE Header, Dynomax Super Turbo Muffler, K&N Intake
  14. Apr 27, 2011 at 1:36 PM
    mfudurich
    mfudurich Member
    Calgary AB
    Tacoma TRD
    Let's see... I have a 2.5" OMe lift and slapped on 285/70/R17 BAJA ATZ's... I had to trim quite abit of the plastic away on the front and back side of the front wheel wells... Because the mickey's are a pretty wide tire I also had to cut and fab both front body mounts so the tire wouldnt rub... it was a bitch but needed to be done.
  15. Apr 27, 2011 at 7:12 PM
    sgeezy
    sgeezy Active Member
    Shelton
    PB ARK
    SCRATCH n SNIFF
    2.5" rough country lift, Billy 5100's up front, 31X10.50x15 BFG KM2 tires, 15x7 Black Crager 397 series soft 8 wheels. One 15" kicker L7 Subwoofer in ProBox. 2000 watt volfenhag amp. K&N Cold air intake. And 266K miles
    get spacers, remove your front bumper and fab up a baja style :D
