Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Sep 30, 2020 at 2:55 PM
    #2261
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    @Evenflow custom +4 kit is coming together
    Slashaar, jdiola, oni06 and 8 others like this.
  2. Sep 30, 2020 at 3:23 PM
    #2262
    81Trekker
    La Jolla SD
    And some adjustable shackle flip hangers
  3. Sep 30, 2020 at 3:54 PM
    #2263
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I need to do this for my 63 swap. Maybe I should just buy the rear hangers/shackles from you guys
    Arcticelf likes this.
  4. Sep 30, 2020 at 4:20 PM
    #2264
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Could this theoretically work for a 63 swap? spring-over, not under. Bolt-on 63 swap would be a game changer.
    DesertRatliff and old55guy like this.
  5. Sep 30, 2020 at 4:22 PM
    #2265
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    :pccoffee::typing::yay::spending:
    Arcticelf and dk_crew like this.
  6. Sep 30, 2020 at 5:04 PM
    #2266
    CGoss
    CGoss Well-Known Member
    Las vegas
    2006 rad red offroad
    Spring over your would have to cut and weld on a new spring perch and set pinion angle. Thought about this a couple weeks ago when debating on if I want to do chevy 63s. Still doing research too, I don't know if changing the angle the leaf springs sit would effect it, also need to do more research mounting shocks inside the frame.
    Taconator_[QUOTED] likes this.
  7. Sep 30, 2020 at 5:39 PM
    #2267
    Taconator_
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Yeah, I mean I don’t mind the work for a 63 swap I just don’t know how to weld. I follow you on IG, you get some pretty crazy flex with the shackle flip. You’re on stock leafs too right!?
  8. Sep 30, 2020 at 6:21 PM
    #2268
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    add a fabbed spindle and I’m in!
  9. Sep 30, 2020 at 6:23 PM
    #2269
    81Trekker
    La Jolla SD
    There really is no point after the spindle and double shear are welded on. The custom spindle only makes sense if you go vertical uniball and then the taco hub still the weak point.
  10. Sep 30, 2020 at 6:55 PM
    #2270
    CGoss
    Las vegas
    Yeah stock leafs, haven't needed to upgrade till now. I'm getting some axle wrap and am trying avoid a traction bar. Still weighing the pros and cons of each setup so I'm not sure what I'll do.
  11. Sep 30, 2020 at 6:58 PM
    #2271
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    FIFY
    old55guy and Arcticelf like this.
  12. Sep 30, 2020 at 7:05 PM
    #2272
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    See now I'd be interested in this as a little more width and travel over the current one. I'm assuming it's pushed forward like your other one or maybe done a little differently?
  13. Sep 30, 2020 at 7:06 PM
    #2273
    81Trekker
    La Jolla SD
    Pushed forward 7/8” just like the 2.25” kit
    kasnerd and ovrlndkull[QUOTED] like this.
  14. Sep 30, 2020 at 7:07 PM
    #2274
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    You think you'd make this an option?
  15. Sep 30, 2020 at 7:16 PM
    #2275
    81Trekker
    La Jolla SD
    The 4” over kit?
    ovrlndkull[QUOTED] likes this.
  16. Sep 30, 2020 at 7:29 PM
    #2276
    RonRon23
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    That’s what I had meant tbh. A spindle with vertical uniball and stronger hub. Something similar to solos kit but having all the little details @81Trekker is designing into his kits.
  17. Sep 30, 2020 at 7:33 PM
    #2277
    savage1016
    savage1016 Well-Known Member
    Tempe Arizona
    3rz SR5 4x4
    custom bumper, 2 inch lift, header, custom intake, custom flared fenders
    So being in my current state of big dreams and no budget i can only ask questions and plan. You have mentioned that the tacoma unit bearing will be the weak point on a fabbed spindle, would a full floating dana 60 hub/spindle set up work or are you running into bolt pattern issues? I have also noticed you mention Dana 44 hubs and spindles. what is the strongest set up of the three provided your already headed down the path of a fabricated spindle?
  18. Sep 30, 2020 at 7:36 PM
    #2278
    81Trekker
    La Jolla SD
    Chevy D44 big bearing snouts as the Chevy stuff is all 6x5.5 lug pattern
  19. Oct 1, 2020 at 3:21 AM
    #2279
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yes
  20. Oct 1, 2020 at 5:47 AM
    #2280
    81Trekker
    La Jolla SD
    I’m making two 4+ kits, one for @Evenflow and the other is up for grabs
