Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Nov 7, 2020 at 10:21 AM
    #2721
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
  2. Nov 7, 2020 at 10:22 AM
    #2722
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Noooo. Don't tempt me...
    Dalandser likes this.
  3. Nov 7, 2020 at 10:24 AM
    #2723
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    DOO EEET
    Torspd[QUOTED] likes this.
  4. Nov 7, 2020 at 10:25 AM
    #2724
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Have to get that built Magnum in there with a lower gear ratios first. This T56 with my tire size and final drive get me over 50 mph in first gear. Then I'll consider it. I keep wanting to lift my truck back up for a while.
  5. Nov 7, 2020 at 10:26 AM
    #2725
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    Been watching this thread because these parts are right up my alley.
  6. Nov 7, 2020 at 10:26 AM
    #2726
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I already made a bedcage and have giant holes in my bed, but I would love to run the rest of this rear end setup. Is this better suited to the +4" kit? Is there a ratio for balancing front to back travel? Using the 2.25" kit in the front with 13" of travel, is 18+" in the back too much to be practical? I'm genuinely curious.
    smw62891 likes this.
  7. Nov 7, 2020 at 11:24 AM
    #2727
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    Does that shock tower interfere with the filler neck? Looking at my long bed, that seems to be right where my filler neck comes up.
  8. Nov 7, 2020 at 11:30 AM
    #2728
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    not when you move the tank behind the axle. :D
    565hunter likes this.
  9. Nov 7, 2020 at 11:52 AM
    #2729
    RonRon23
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Are you going with a cell? Or did you have Harry move your stock tank behind the axle.
  10. Nov 7, 2020 at 12:24 PM
    #2730
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    transplant, so carb legit. They found a tank that fit between the frame rails. 36gal.
  11. Nov 7, 2020 at 12:24 PM
    #2731
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    They found a tank that is the right shape to go behind the axle. Think when he showed it to me he said it was a bronco tank.
    RonRon23[QUOTED] likes this.
  12. Nov 7, 2020 at 2:46 PM
    #2732
    NcTaco27
    NcTaco27 Well-Known Member
    Brenton
    East Tennessee
    2015 TRD off-road taco
    Lt front/rear Jd fab…
    So your saying I should start ripping of those pesky archive mounts soon... :D
    Slashaar and RonRon23 like this.
  13. Nov 7, 2020 at 3:08 PM
    #2733
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    That's interesting. Maybe I'll.do that after I get the front end built.
  14. Nov 7, 2020 at 3:09 PM
    #2734
    Arcticelf
    Gladiator
    Clever.
    No, trigonometry.
  15. Nov 7, 2020 at 4:02 PM
    #2735
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Kinematics, sprinkled with some dynamics?
    Arcticelf[QUOTED] likes this.
  16. Nov 7, 2020 at 4:20 PM
    #2736
    Arcticelf
    Gladiator
    That's the tuning part. Making a 14" shock work with 18" of axle travel is just triangles.
    ETA: and a bunch of top notch fabrication.
  17. Nov 7, 2020 at 8:34 PM
    #2737
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Well, got the slide rack, new spindles and heimed tie rods in. Took about 12hrs, just need to do the alignment tomorrow.
    Cutting the notch out without a plasma is a difficult task especially with my skid brace in the way.
    Too dark and starting to snow to get pics
  18. Nov 8, 2020 at 8:00 AM
    #2738
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    This rear kit is ideal for any front end. And how and where you drive will dictate what’s practical or not.
    Slashaar, tetten and 01 dhrracer like this.
  19. Nov 8, 2020 at 8:01 AM
    #2739
    81Trekker
    La Jolla SD
    Yes, the good news is your install will be a lot easier since the rear OE rivets have already been removed!
  20. Nov 8, 2020 at 10:53 AM
    #2740
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    First drive and part of it is probably just the new, not blown out rack, but everything feels tight and right and great other than the wheel is a bit crooked from my alignment. Not too bad, but snowing today so it’ll have to do until it warms up or I just take it in for an alignment.
    Torspd likes this.
