Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Nov 16, 2020 at 10:56 AM
    #2861
    JeffBoyardee
    JeffBoyardee Well-Known Member
    Jeff
    Seminole, FL
    2011 TRD Off-Road Tacoma DCSB
    Where'd you get a solid model of the frame? I'd like to get a copy to model a flatbed for my truck.
  2. Nov 16, 2020 at 1:10 PM
    #2862
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Shock mount cross bar is all done for @kasnerd
  3. Nov 16, 2020 at 2:13 PM
    #2863
    NcTaco27
    NcTaco27 Well-Known Member
    Brenton
    East Tennessee
    2015 TRD off-road taco
    Lt front/rear Jd fab…
  4. Nov 16, 2020 at 2:13 PM
    #2864
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    So the mounts do cut through the bed? If that’s the case, it should work on the long bed. I thought the mount was completely under the bed. Is it sealed to the bed?
  5. Nov 16, 2020 at 2:35 PM
    #2865
    81Trekker
    La Jolla SD
    Yes the shock mount is notched into the bed. This was done to pull the shock closer to the frame so the tire doesn’t rub on the bypass tubes when it’s all flexed out. And yes the tower is sealed up against the bed. The cross bar isn’t necessarily needed but it definitely adds some strength to the setup
    CMScheid, TireFire, oni06 and 2 others like this.
  6. Nov 16, 2020 at 2:37 PM
    #2866
    81Trekker
    La Jolla SD
    FYI you have the upper shock mount installed wrong... it should look like this
  7. Nov 16, 2020 at 2:42 PM
    #2867
    RonRon23
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Makes sense. I want to give it a try on my long bed.
  8. Nov 16, 2020 at 7:55 PM
    #2868
    NcTaco27
    Brenton
    East Tennessee
    is that what the plate that says 3" hole saw is for? cause I couldn't get the shock bolt in when I tried it like that.
  9. Nov 16, 2020 at 8:52 PM
    #2869
    81Trekker
    La Jolla SD
    You use the metal template provided to hole saw a 3” hole in the top of the shock bucket. You will also need to change your resi fitting to the stubby style
    Slashaar likes this.
  10. Nov 17, 2020 at 7:04 AM
    #2870
    Y2kbaja
    Y2kbaja Well-Known Member
    Sacramento
    05 Total Chaos Tacoma
    Total Chaos
    What plate is that? Can you take the shock off without removing the 3 bolts? I'm looking to replace my TC aluminum piece as I'm tire of taking the 3 bolts off to remove the shock.
  11. Nov 17, 2020 at 7:44 AM
    #2871
    81Trekker
    La Jolla SD
    It’s a top hat we make specifically for our kit to maximize up travel and yes you can pull the shock without removing the top hat
    Jowett and Slashaar like this.
  12. Nov 17, 2020 at 8:10 AM
    #2872
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Is that top hat available as a separate part?
    Y2kbaja likes this.
  13. Nov 17, 2020 at 11:50 AM
    #2873
    81Trekker
    La Jolla SD
    Yes but I will have to get more laser cut as I only have enough for the LT kits we have
    Arcticelf[QUOTED] and Nimble9 like this.
  14. Nov 17, 2020 at 12:00 PM
    #2874
    Arcticelf
    Gladiator
    Excellent. I'll shoot you an email when it's closer to need.
  15. Nov 17, 2020 at 12:24 PM
    #2875
    NcTaco27
    Brenton
    East Tennessee
    Awesome thanks! And I had planned to change fitting like yours with the description in the email you sent but I’m gonna run these until I can save for a rebuild/re valve on these and some bypasses.
  16. Nov 17, 2020 at 12:32 PM
    #2876
    Y2kbaja
    Sacramento
    Total Chaos
    Did you cycle the shock without the spring? With the top of the shock that much lower it makes it shorter and could bottom out. The older TC design is like this in the 2wd config and to go 4wd you flip the top hat over and need a longer bottom eyelet.
  17. Nov 17, 2020 at 12:43 PM
    #2877
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    To get that extra uptravel, the stock bump stop needs to be removed?
  18. Nov 17, 2020 at 12:51 PM
    #2878
    81Trekker
    La Jolla SD
    You get all the uptravel without removing the bumpstop. We run an 8” coilover on the LT kit and the top hat we have allows for all the uptravel with the correct leverage ratio on the shock
  19. Nov 17, 2020 at 1:15 PM
    #2879
    NcTaco27
    Brenton
    East Tennessee
    No I did not cause I was too lazy to take the spring off again. But I cycled without the shock to verify cv bind and limit strap position. Makes sense why it was sitting so high lol.
  20. Nov 19, 2020 at 4:25 PM
    #2880
    ekliptiko
    ekliptiko Well-Known Member
    Portland, OR
    @81Trekker - can you tell me the offset of the mounting location of your top hat relative to the mounting face (ie- the bottom face of the upper coil mount) ? Id buy a pair if they're close to what I need... Thanks in advance
