Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Jan 23, 2021 at 6:26 PM
    #3641
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Not saying that at all. You just have to know how to order or the parameters that work. My assumption is that none of the big name companies make a shock that fits this kit "out of the box." I have yet to get my hands on a kit to try though.
  2. Jan 23, 2021 at 6:29 PM
    #3642
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    We are not and never will be
  3. Jan 23, 2021 at 6:34 PM
    #3643
    81Trekker
    La Jolla SD
    The kit is designed around an off the shelf 8” King shock, the hose length and fitting is the only change
    ovrlndkull and TheBlueBeast15 like this.
  4. Jan 23, 2021 at 6:39 PM
    #3644
    TheBlueBeast15
    TheBlueBeast15 Well-Known Member
    Kevin
    H-Town
    2015 Blue Ribbon Metallic TRD Off Road double cab short bed
    Forgive me and my inexperienced shock knowledge. Sounds like I can make the Fox shocks work with custom requests. I was going to go with accutune with this setup and I’m sure they can make it work.
    whatstcp likes this.
  5. Jan 23, 2021 at 6:46 PM
    #3645
    desertjunkie760
    Shane
    Check My Sig.
    What size hose does King use on their standard 8”?
  6. Jan 23, 2021 at 6:47 PM
    #3646
    desertjunkie760
    Shane
    Check My Sig.
    Yes, they can if they order the above posted specs. Why not go through JD?
  7. Jan 23, 2021 at 7:03 PM
    #3647
    TheBlueBeast15
    Kevin
    H-Town
    I know they are a Kings dealer never thought to ask if they could order Fox shocks for me. I wasn’t planning on running a secondary bypasses shock so I like fox’s DSC shock. My application is mostly a DD with going on fire roads for work occasionally.
  8. Jan 23, 2021 at 7:06 PM
    #3648
    desertjunkie760
    Shane
    Check My Sig.
    I believe they are a Fox dealer as well. Worth asking while you’re ordering your kit since they know the specs.
  9. Jan 23, 2021 at 8:08 PM
    #3649
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    So you want an adjustable shock beyond what comes with the valving. King makes a shock that does the same thing
    https://accutuneoffroad.com/product...lovers-compression-adjuster-remote-reservoir/
    If you are not wanting a secondary bypass shock but the advantages of the bypasses you'd need to get their ITB COs. But IMO that's a waste you are paying A LOT more for a CO that makes some pretty big compromises where if you just went with the Std RR or adjustable RR then you have the option of upgrading to a true bypass if you ever wanted or needed too. BTW King also makes a shock that does that.
    I just got everything from JD they valve the shocks to their specs and set up everything that needs to be done to fit with the hoses and fittings. No need for me to figure that out and relay that to another company for my COs.
  10. Jan 24, 2021 at 9:58 AM
    #3650
    81Trekker
    La Jolla SD
    We are a fox dealer as well
  11. Jan 24, 2021 at 6:18 PM
    #3651
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    Had a few more hours at today. It’s slow progress, but I plan to have this thing ready for welding by the end of the month I threw on some primer so the metal wouldn’t rust until then.
    I’m going to try to post as much as I can along the way for those still wondering what is all involved. By far this is the most time consuming part. 3FB737EA-7E43-4A35-B820-35B85BFDE644.jpg
    Suicyco, Torspd, Mully and 7 others like this.
  12. Jan 24, 2021 at 6:23 PM
    #3652
    TacoTuesday1
    FL
    am looking at a grinder to buy
    for installing this kit,
    regarding prepping the metal bare for welding.
    Anyone know which one is best?
    I've heard some necessary features are:
    -4.5"
    -corded
    -trigger
    -better than the $20 Harbor Freight one that is loud and shakes
    which narrows it down to
    -Milwaukee 11 amp, $130
    -DeWalt 13amp, $150
    -Ryobi 7.5amp, $60
    I imagine more amps is better, but for some reason the DeWalt despite being the most amps, has the lowest RPM (9000) while the others are 11000
    The Ryobi seems most popular, with like 300 reviews vs 15 reviews on the Milwaukee
    though all 3 of their review average ratings are pretty good
  13. Jan 24, 2021 at 6:40 PM
    #3653
    BertH2O
    BertH2O Well-Known Member
    Bert
    Bay Area, CA
    2015 Tacoma TRD Pro AC
    Just going to say I have the Ryobi and I like it. I imagine I'd like whichever one I bought...but I bought the Ryobi because of the rotating grip which is handy.
  14. Jan 24, 2021 at 6:46 PM
    #3654
    81Trekker
    La Jolla SD
    Those things are too big and awkward... get this one instead, its my personal favorite
  15. Jan 24, 2021 at 6:46 PM
    #3655
    65skyturbo
    65skyturbo Well-Known Member
    Mesa, AZ
    06 Speedway Blue DCSB TRD Off Road
    I would recommend the Makita. I've had mine for over 20 years and it is indestructible. Been through more car projects than I can count...
    https://www.amazon.com/Makita-9557P...11542646&sprefix=makita+angle+,aps,206&sr=8-1
    Hawk373 and Mully like this.
  16. Jan 24, 2021 at 6:50 PM
    #3656
    slander
    slander Honorary Crawl Boi
    Hickory, NC
    02 Tacoma, fixed with curse words.
    I just get the $40 skil grinders from Amazon. Buy 3, put a cut off wheel on one, flap disc on one and a grinding disc on another. Saves SO much time.
  17. Jan 24, 2021 at 7:12 PM
    #3657
    NcTaco27
    NcTaco27 Well-Known Member
    Brenton
    East Tennessee
    2015 TRD off-road taco
    Lt front/rear Jd fab…
  18. Jan 24, 2021 at 7:24 PM
    #3658
    RonRon23
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    I’m using a Ryobi small 4.5in grinder. I too think one of the larger grinders would of been awkward to use.
    DocME likes this.
  19. Jan 24, 2021 at 7:44 PM
    #3659
    65skyturbo
    Mesa, AZ
    I probably use my 4" grinder more than my 4.5" just because it is so maneuverable and fits better in tight spots. It's a little harder to find the 4" discs locally though.
  20. Jan 24, 2021 at 7:48 PM
    #3660
    TacoTuesday1
    FL
    you're right
    the triggered ones look too big
    just ordered 6130-33
    will match my other Milwaukee tools...
    Torspd and 10tacotrooper like this.
