Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Mar 6, 2021 at 10:38 AM
    #4321
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Yep I've started looking at ways to strip more weight yet again.
    Yeah the hp per dollar isn't really there.
    Slashaar likes this.
  2. Mar 6, 2021 at 10:52 AM
    #4322
    TireFire
    TireFire Superunknown Member
    Olympic Peninsula
    The guys in the HPTuners thread are getting way more than that. It’s not too difficult to put in different cams and supercharger, a decent exhaust for the setup and custom tune and you’ll be at around 400hp. Loose the back seats, tow hitch and all that other unnecessary crap and you’ll be close to the 10:1 ratio.
    It does get expensive though, and speaking of power to weight ratios, all roads lead to LS swap
    Slashaar, Airdog and nudavinci64 like this.
  3. Mar 6, 2021 at 11:42 AM
    #4323
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I'll give you a 20 to put an extra layer of cloths on.
  4. Mar 6, 2021 at 11:47 AM
    #4324
    Arcticelf
    Gladiator
    Fully loaded for a pre-landing trip I'm around 6200#, including armor, tent, 4 days of food and water. I'm making some extra HP from long tube headers and intake mods, and desperately need gears to make up for the lack of power.
    Still not 1:10, although that power / weight ratio does sound like a shitload of fun. Possibly too much fun for a truck without a full cage though.
  5. Mar 6, 2021 at 12:10 PM
    #4325
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    400hp at the crank, after the power goes through a slush box, locked diff and 37’s you would be lucky to put 225 to the wheels
  6. Mar 6, 2021 at 12:51 PM
    #4326
    TireFire
    Olympic Peninsula
    Okay 37s... how’s that look with stock 236 at the crank though lol
  7. Mar 6, 2021 at 1:02 PM
    #4327
    Arcticelf
    Gladiator
    600 hp to the wheels is terrifying, even in a 6000# 4wd truck.
    Let's say I was going to drop the coin for the LS, and driveline to handle it, what do I need for safety?
  8. Mar 6, 2021 at 1:17 PM
    #4328
    nudavinci64
    nudavinci64 Robert @ Holy Horsepower
    Robert
    San Mateo/Cayucos, CA
    13 S/C TRD OffRoad 4x4
    Boosted Money Pit....
    Pretty easy to stack on top of that. I should be around 300whp now. Still not 400 that’s hard without going all in and stroking it but you can get some good power.
  9. Mar 6, 2021 at 1:17 PM
    #4329
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    I’m hoping to try it on my long bed after the front is done. It should work, it would just put the mount about a foot back from the front wall of the bed. I guessed it would be in the downward slope of the front of the wheel Wells on the long beds.
  10. Mar 6, 2021 at 1:20 PM
    #4330
    nudavinci64
    Robert
    Def on 37’s it will kill big time. Could get better than that def feel it. When I went 35’s and thr S/C I felt my truck was faster before (minus my swing out I have now)
  11. Mar 6, 2021 at 1:23 PM
    #4331
    Arcticelf
    Gladiator
    If you're will to do a bit of fitting it should work, but the frame is a bit different from the shortbed.
  12. Mar 6, 2021 at 3:18 PM
    #4332
    RonRon23
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    In the spot where JD mounts their tower, it looks almost identical. The bed isn’t however. The notched out area would not be the same.
    Without measuring I couldn’t be sure.
    Maybe I should turn Harry loose on testing it on my long bed.
    Seeing @Evenflow and his 3 link again also got me undecided on what I want to do with the truck haha
    Arcticelf[QUOTED] likes this.
  13. Mar 6, 2021 at 3:25 PM
    #4333
    Arcticelf
    Gladiator
    If you're close enough.you should definitely turn him loose.
  14. Mar 6, 2021 at 7:56 PM
    #4334
    Slvr14tacoma
    Slvr14tacoma Well-Known Member
    Mid travel
    Is it mostly the fronts or a combination of the front and rear bypasses that’s making it unbearable? Wouldn’t think there would be too clicking on daily driving roads?
  15. Mar 6, 2021 at 8:08 PM
    #4335
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    When the cage ties everything together it is quite noisy. I don’t feel bypass clicks are too too bad even with a cage, but I only have rear 3tube. Rode in a buddies last summer with 3 tube up front and 5 tube out back with front to rear cage. His was 100x worse than mine as far as bypass clicks. That said, his rode 10x better than mine and as not a daily driver it is 1000% worth it for the off road performance
    Slvr14tacoma[QUOTED] likes this.
  16. Mar 6, 2021 at 8:23 PM
    #4336
    Pickup90
    Pickup90 Well-Known Member
    North Carolina
    09 DCLB TRD Sport
    Is anyone interested in a set of total chaos spec front bypass shocks (tc1119-34)? I have a set I'm thinking of letting go and figured there are a bunch of people here that have kits ordered but won't have shocks for 8 months.
  17. Mar 6, 2021 at 8:24 PM
    #4337
    81Trekker
    La Jolla SD
    The rears are worse than the fronts and they are awful on the street, if you don’t believe me I can call you on speaker phone tomorrow when I’m driving... it’s actually almost funny how obnoxious the shocks are
  18. Mar 6, 2021 at 8:32 PM
    #4338
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    8” triple bypasses? You own the Goldilocks of wanted shocks. Pm me if $600 + shipping entices you
  19. Mar 6, 2021 at 8:49 PM
    #4339
    Pickup90
    North Carolina
    09 DCLB TRD Sport
    I should add they're new in packaging, haha.
    nudavinci64 likes this.
  20. Mar 6, 2021 at 8:53 PM
    #4340
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
