Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Oct 25, 2019 at 12:32 PM
    #421
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Like a weld on tube to the exterior? Same concept of a gold valve on a Fox bypass?
  2. Oct 25, 2019 at 2:40 PM
    #422
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Do you really think you will need to notch the frame for up travel? That is usually kept for linked trucks with upper shock mounts up above the bed rails. I know you’re doing your own geometry and kit design, but none of the spring under long travel kits on the market have you do this. My dmz kit with 16” shocks the leafs are just a little negative at full bump just before the axle hits the frame. Just don’t see how it would be utilized with a 12” shock not going through the bed. Shock will bottom out long before the axle comes close to the frame.
    As for static up/down travel I have always heard you want 60/40 at ride height. At least for go fast applications. The wheel needs to be able to have uptravel when you hit that hard bump that came out of nowhere. Crawlers I’ve heard 50/50 or the opposite at 40/60 up/down travel as ideal numbers.
  3. Oct 25, 2019 at 2:42 PM
    #423
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    This has worked well for me so far. 4ish" up travel on a 12" shock. Allows for plenty of droop.
  4. Oct 25, 2019 at 2:57 PM
    #424
    Richie Rich
    Richie Rich Toyota Hoarder
    760 (San Diego)
    2010 X-Runner 2011 TRD Sport DC 4x4
    More than I can afford
    Planning on sticking with a balljoint on the LCA?
  5. Oct 25, 2019 at 3:12 PM
    #425
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Yeah crawlers and rock bouncers are more droop than bump. Some are even less than 40% bump. I've seen some crawlers that are really low slung with like 3-4" of up on 14" shocks. The high speed stuff needs more up due to the jumping and stuff. Just don't want so little droop that the wheel can't droop enough into dips and holes while running down a trail.
  6. Oct 25, 2019 at 3:16 PM
    #426
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    for now yes
  7. Oct 25, 2019 at 3:16 PM
    #427
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Hence why I found some Chevy 63s with a 6.75" arch compared to the rest with 5.25" of arch. So I have a good amount of bump and droop, more than my 14" shocks can cycle.
  8. Oct 25, 2019 at 7:00 PM
    #428
    81Trekker
    La Jolla SD
    The total travel is still the same it’s just where the truck sits in the travel that drastically changes the ride of the truck
  9. Oct 25, 2019 at 7:27 PM
    #429
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    I can agree. But also with where suspension pickup points are located and designed.
  10. Oct 28, 2019 at 9:59 AM
    #430
    sicki
    sicki Well-Known Member
    why does the backwards UCA bolt make you nervous?
  11. Oct 28, 2019 at 10:34 AM
    #431
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
    Because in that orientation they have a tendency to back off and fall out over time
  12. Oct 28, 2019 at 10:42 AM
    #432
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    What he said and if the nut comes off in the other orientation the bolt will still stay in place so it doesn't fall off
  13. Oct 28, 2019 at 12:12 PM
    #433
    rob1208
    rob1208 Well-Known Member
    Rob
    SF Bay Area
    2014 Toyota Tacoma DCSB MGM TRD OR
    TRD Supercharger AFE CAI ProDryS ADS 2.5 Remote Resi Shocks ADS Rear Piggy Back 10" Travel Shocks ADS 2.0 Rear Hydro Bump Kit Deaver U402 Leaf Pack + Add a Leaf MCM Fab Uniball UCAs TC Spindle Gussets BAMF 100% Bolt On Sliders BAMF 1/4" Steel Skid Trilogy BAMF Diff Diaper Brute Force Fab Hybrid Front Bumper with Warn VR10000-s Winch Brute Force Fab High Clearance Dual Swingout Rear Bumper Custom Car Grills Mesh Grill Insert Stealth Custom Series SR8 - Matte Black 16x8 285/75/16 Toyo Tires Open Country AT2 Relentless Fabrication Ditch Light Bracket Mounts 2x2 Ditch Lights Apex Fab Works Flush Lower Grill Light Bar Mounts Caliraised 32" Light Bar Tech Deck Extreme Vagabond Outdoors Drifter
    +1. had a buddy's nut on the UCA bolt come off and luckily it was oriented the other way. bolt backed off on a fireroad and the cab side of the UCA fell lose. Luckily I caught it right after it happened and he didn't drive very far. Had it been the other way, the bolt could have fell all the way off and did more damage if not discovered in time.
  14. Oct 28, 2019 at 12:16 PM
    #434
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    @literallynothing and @ovrlndkull - have you seen or heard of this happening? "tendancy" for nut to fall off, as in you know of it, or are you talking pure theory? I think there has been millions of people replace UCA and not put the bolt back in the ridiculous way the factory does it. And I believe that with any proper fit, the nut/washer should be tightening against a sleeve that doesn't rotate. And even if the bushing were to get grip on the nut/washer, the control arm articulates in both directions, who is to say that it wouldn't happen with the other OEM orientation? And anyone seen a bolt work its way out? I would have thought the side loading of the UCA would prevent the bolt working its way out.
    But perhaps I am missing something, and this is a common thing that I've missed.
  15. Oct 28, 2019 at 12:18 PM
    #435
    racebug68
    Travis
    Chandler, AZ
    OK then, I stand corrected. Is this common, or is this a corner case of not enough torque / torque check after a few miles?
    rob1208[QUOTED] likes this.
  16. Oct 28, 2019 at 12:18 PM
    #436
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Yes I've seen it! It fucked some shit up too!!!
    rob1208 likes this.
  17. Oct 28, 2019 at 12:21 PM
    #437
    rob1208
    Rob
    SF Bay Area
    not really sure. I know it was torqued when the aftermarket UCA was first installed but not sure if it was ever loosened / re-torqued after (it had been less than 6k miles since the install). On my truck, I check torque every so often but I also drew a line with a paint pen so I can visually spot it quicker if it does come loose.
    BassAckwards, ovrlndkull and tcjacado like this.
  18. Oct 28, 2019 at 12:24 PM
    #438
    tcjacado
    tcjacado Well-Known Member
    I have seen it happen on 2 rigs.
    ovrlndkull likes this.
  19. Oct 28, 2019 at 12:25 PM
    #439
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Not horribly common but has happened. My question to you is why tempt fate. Why not just do things the right way.
    rob1208, desertjunkie760 and tcjacado like this.
  20. Oct 28, 2019 at 12:28 PM
    #440
    desertjunkie760
    Shane
    Check My Sig.
    I hope it's not a common occurrence, but even if it's theory based, why risk it? You can torque everything occasionally and take the chance, likely with success, but what happens if you're apart of the small number that it happens to?
    rob1208 and ovrlndkull like this.
