Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Apr 28, 2021 at 5:58 PM
    #5321
    Taconator_
    Taconator_ IG: ohv_tacotruck
    Eric
    SoCal
    18' DCSB TRD OR 4x4
    Also curious.. but, most 2nd/3rd gen parts are relatively Interchangeable?
  2. Apr 28, 2021 at 6:01 PM
    #5322
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Totally different motor so it will most definitely not work. Not that they aren’t capable of making a kit for 3rd gen that will work. But this one won’t
  3. Apr 28, 2021 at 6:19 PM
    #5323
    CGoss
    CGoss Well-Known Member
    Las vegas
    2006 rad red offroad
    I dont think its an issue with the motor.
    The pump will most likely bolt to the motor just fine. Its up to the installer to make sure the pulley is aligned. Hose fittings should be the same, if not its not hard to find some adapters at your local hydraulic hose shop. The difference will most likely be with mounting the resevoir.
    But its been said before,
    Harrys kits will get you 90% there, its up to you to finish it.
    I used a trail gear pump from a 3.4l on my 4.0, just needed to drill out the upper bolt hole to accept the stock bolt and i reused my old pulley.
    T.Barn and Slashaar like this.
  4. Apr 28, 2021 at 6:24 PM
    #5324
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I'm just waiting for mine to arrive now. Harry's work is outstanding. My springs have already shown up.
  5. Apr 28, 2021 at 7:17 PM
    #5325
    Offthewall
    Offthewall Well-Known Member
    Southern OR
    12 tx pro
    That’s why I’m here
    All right guys stupid question for you. On the upper arm gussets what direction are the washers supposed to face? I apparently was in a hurry this weekend taking it apart. And the way I figured them to fit the bolt seems a little short with the extra steel of the gussets.
  6. Apr 28, 2021 at 7:25 PM
    #5326
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Throw the washers in the trash... they are not needed with the double shear gussets
    ovrlndkull and Slashaar like this.
  7. Apr 28, 2021 at 7:39 PM
    #5327
    Offthewall
    Southern OR
    12 tx pro
    That’s why I’m here
    Thank you
  8. Apr 28, 2021 at 7:40 PM
    #5328
    Slashaar
    Josh
    Kansas City, MO
    @81Trekker you have a photo of the 62 swap bumped out? Or does the setup limit it mechanically with the springs? Thought I saw somewhere the frame was bump.
  9. Apr 28, 2021 at 7:43 PM
    #5329
    81Trekker
    La Jolla SD
    Yes the axle bumps on the frame and can go up another 2” with a frame notch
    Slashaar[QUOTED] likes this.
  10. Apr 28, 2021 at 7:44 PM
    #5330
    Slashaar
    Josh
    Kansas City, MO
    That's what I thought! :thumbsup:
  11. Apr 28, 2021 at 9:45 PM
    #5331
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    Harry have you done the notch yet on any of the trucks with your kit? I remember you mentioning that “your” silver truck was working well and didn’t see the need. If one were to do the notch, what kind of reinforcement would be needed? Is that something JD could provide?
  12. Apr 29, 2021 at 6:00 AM
    #5332
    NcTaco27
    NcTaco27 Well-Known Member
    Brenton
    East Tennessee
    2015 TRD off-road taco
    Lt front/rear Jd fab…
    i plan to when I do mine. I purchased the dirt king frame box kit and bump stop mounts.
    Harry did not recommend it cause he said you would have to tub the whole wheel well in the bed. But for me I don’t mind.
    RonRon23[QUOTED] likes this.
  13. Apr 29, 2021 at 7:12 AM
    #5333
    81Trekker
    La Jolla SD
    This is correct, in order to tuck the 35’s you will have to tub the wheel wells or ditch the bed. I will end up doing it to the silver truck when we put a real axle in it but I’m in no hurry as to do it right is going to require a lot of messing around with the plastic bed
    NcTaco27[QUOTED] and RonRon23 like this.
  14. Apr 29, 2021 at 9:24 AM
    #5334
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Hey @81Trekker does the rear kit include bump mounts as well? I already have the cans. I can also probably make some. Otherwise it's just the leaf hangers, shackles, straps and brake lines, is that right? Anything else I would need? Lower shock mounts?
    I'm going to continue running my bed cage (modifying it to work) with the 16" IBP's because that's what I have. I can revalve them if it's too soft or firm as well. Hopefully they pair well enough with the kit until I can do bypasses.
    Slashaar likes this.
  15. Apr 29, 2021 at 9:53 AM
    #5335
    NcTaco27
    Brenton
    East Tennessee
    I may be wrong but in my invoice, no straps included, definitely not bump mounts. and the under the bed shock mounts are sold separately for anyone else wondering.
  16. Apr 29, 2021 at 11:50 AM
    #5336
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Almost looks like you used silicon bronze. Did you?
  17. Apr 29, 2021 at 12:39 PM
    #5337
    81Trekker
    La Jolla SD
    I only do sheet metal with it
  18. Apr 29, 2021 at 12:56 PM
    #5338
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    I recently found out about it from Kibby Racing(?) In a Banks Power video. Used it on my tailgate. Works magnificently.
  19. Apr 29, 2021 at 2:38 PM
    #5339
    Slashaar
    Josh
    Kansas City, MO
    Deaver springs, powdercoated front and rear hangers and shackles, U bolts, bushings, hardware, spring plates, brake lines.
    Shock Relocates come with the cross bar. Confirmed separate.
    I think that's everything on my invoice.
    This is the only photo I have at work.
    WormSquirts[QUOTED] likes this.
  20. Apr 29, 2021 at 4:28 PM
    #5340
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
    The WarFab kit will include tube steel for the new cross member, thicker material and larger studs for the frame horns (as well as a few pieces to strengthen that area), a plate to start your bumper off of (probably the plate you saw), a winch tray, and a new front skid that will tie in to your new cross member. We put a prototype on my 3rd gen and then beat the crap out of it so he could make some final adjustments. The winch now sits roughly 4" higher and 4" further back than the highest clearance "bolt on" bumpers currently available for Tacomas
    ovrlndkull, Mully and Slashaar like this.
