Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Jul 9, 2021 at 7:48 AM
    #6941
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm assuming that was intentional and so you can easily swap out in the future. Do you think that's why it failed?
  2. Jul 9, 2021 at 7:48 AM
    #6942
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    You didn’t put the clip on?!?
    the axle will pull out of the outer at full droop/lock with out them. I’ll bet you didn’t even break your outer... you’re axle pulled out of the outer CV and stripped the very end of the axle splines.
    YOU HAVE TO RUN THE OUTER CV CLIP
    DocME likes this.
  3. Jul 9, 2021 at 7:49 AM
    #6943
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    That's not what Jesse told me on the phone
  4. Jul 9, 2021 at 7:50 AM
    #6944
    81Trekker
    La Jolla SD
    It’s absolutely why it failed, you can not run them without the outer clip
  5. Jul 9, 2021 at 7:50 AM
    #6945
    81Trekker
    La Jolla SD
    No, we both told you that you do not run the inner clip
  6. Jul 9, 2021 at 7:51 AM
    #6946
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Oh boy, Harry used caps lock. It's getting serious now.
    Hawk373, Airdog and desertjunkie760 like this.
  7. Jul 9, 2021 at 7:52 AM
    #6947
    WormSquirts
    Braeden
    BC
    Maybe I misunderstood. The inner was already assembled so I assumed it was all good and I asked about the outer clip, but whatever, not a big deal. I'll pull it apart and see
  8. Jul 9, 2021 at 7:54 AM
    #6948
    81Trekker
    La Jolla SD
    We assemble all the inners without a clip as they are not needed. The outer clip is always needed.
  9. Jul 9, 2021 at 7:55 AM
    #6949
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
  10. Jul 9, 2021 at 7:57 AM
    #6950
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    @81Trekker, what is the actual loss in travel staying with the stock inners? Not sure if it’s been mentioned or not. I’m personally just trying to decide if I can justify it or not.
  11. Jul 9, 2021 at 7:57 AM
    #6951
    81Trekker
    La Jolla SD
    I’d limit it almost 2” with stock inners to be on the safe side
  12. Jul 9, 2021 at 7:58 AM
    #6952
    906taco
    Cory
    08 Taco
    Ok, they are justifiable then.
  13. Jul 9, 2021 at 8:00 AM
    #6953
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    The actual loss w/o 934’s is…your manhood :boink:
  14. Jul 9, 2021 at 8:00 AM
    #6954
    WormSquirts
    Braeden
    BC
    Good to know. At least swapping it will be easy as long as the axle is fine!
  15. Jul 9, 2021 at 8:05 AM
    #6955
    desertjunkie760
    Shane
    Check My Sig.
    When's the last time your truck hit dirt?
    Because I've put some miles on my setup already w/o 934s and my manhood is still debatably intact... :laughing:
  16. Jul 9, 2021 at 8:05 AM
    #6956
    81Trekker
    La Jolla SD
    I’m willing to bet you stripped the very end of the axle splines when it pulled out of the CV. If so I’ll send you a new shaft on the house because I like you :)
  17. Jul 9, 2021 at 8:07 AM
    #6957
    desertjunkie760
    Shane
    Check My Sig.
    It's worth doing the 934s. Are you considering the +2.25"? I didn't write the numbers down but I think I lost at least .5" of shock travel (maybe more) running non-934s which is about 1" at the wheel. Then you have to take the stretch of the strap into consideration so you'll strap earlier than that to be safe so the 2" recommendation isn't far off.
  18. Jul 9, 2021 at 8:10 AM
    #6958
    906taco
    Cory
    08 Taco
    I'm sold on doing the 2.25. Just trying to plan it all out appropriately before I start forking cash over. I will also be doing the SUA. SUA is my top priority because I absolutely hate the rear as it sits now.
    Slashaar likes this.
  19. Jul 9, 2021 at 8:24 AM
    #6959
    dirty deeds
    dirty deeds Big Blue Nation!
    Nick
    Eastern KY
    '14 Wht AC SR, 2.7, MT, Baja wheels
    PlastiDip front emblem, twine, and Scotch tape
    Sorry to ask a repetitive question gents, but there's no posts that really compile all the info in this thread with pros/cons and each "stage" with respective capabilities.
    That said, what does JD Fab @81Trekker offer for 35s on a stockish setup to get better alignment, wheel travel in the fender well, stop the rub, and beef the stress points (axles, steering)?
    I've already chopped the cab mount pretty aggressively and hammered shit, I do have body mount relocation brackets from AllPoo to put on since the chop wasn't enough. I still rub a fair amount inside the fender too. Trimmed outer fenders and don't believe I touch them at all.
    Running SPC UCA, stock lower, 5100s set to 0 cup height with HS 2" lift coils, 3rd gen OR wheels with Spidertrax 1.25" spacers, and gusseted spindles. I have bumpstop spacers for the Superbumps and thought about going one notch up on the 5100 to mitigate uptravel, in theory.
  20. Jul 9, 2021 at 8:26 AM
    #6960
    BEAR_KNIFE_FIGHT
    BEAR_KNIFE_FIGHT bearly famous
    Alex
    Minnesota
    2016 TRD OR 4X4 DCSB Slowsand, 2017 WRX WRB
    The LCA Relocation Pivots (https://jdfabrication.com/collections/05-15-6-lug/products/tacoma-05-18-lower-arm-pivots) is going to do a lot of what you're looking for, but I think the "correct" answer is that 35s are going to rub unless you can get down with the :sawzall::sawzall:
    dirty deeds[QUOTED] likes this.
