Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Jul 23, 2021 at 1:57 PM
    #7401
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I like your definition of "fine tune." :cheers:
  2. Jul 23, 2021 at 1:58 PM
    #7402
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    My tolerances when working or building anything are +/- 0.75" so I'm the definition of inaccurate.
  3. Jul 23, 2021 at 1:59 PM
    #7403
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Crazy it deflected that much in the first place! Makes me wonder about your rack bushings, only thing I can think of that would cause that much deflection.
  4. Jul 23, 2021 at 2:01 PM
    #7404
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Could you flip the interior bracket and reweld it to the same surface as the other one?
  5. Jul 23, 2021 at 2:02 PM
    #7405
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I don't think it has anything to do with deflection. I removed the steering stop per the instructions so there was no hard stopping point for the steering, aside from the rack itself. With little effort I could push the banjo bolt into the secondary tab. Now, with my improvised steering stop, it doesn't move at all. Rack is OEM and less than a year old so the bushings are fine.
    Slashaar likes this.
  6. Jul 23, 2021 at 2:04 PM
    #7406
    906taco
    Cory
    08 Taco
    So your before picture wasn't at lock?
  7. Jul 23, 2021 at 2:04 PM
    #7407
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    On the LCA? Sure, maybe before it's powdercoated but that still doesn't solve the problem of no hard steering stop point for the rack like the OEM stop. Normall, there's steering stop that makes contact with the LCA, so a metal on metal contact to stop steering in each direction. With that removed, it's on the physical limits of the rack to stop itself. I agree with @Arcticelf that this was the proper fix vs just clearancing the tab so the bolt doesn't hit.
    Slashaar[QUOTED] likes this.
  8. Jul 23, 2021 at 2:05 PM
    #7408
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It was at lock meaning if I turn the steering wheel all the way and let go, that's where it sits. If I continue to turn the steering wheel and hold it, it will keep turning, making contact.
    906taco[QUOTED] likes this.
  9. Jul 23, 2021 at 2:06 PM
    #7409
    906taco
    Cory
    08 Taco
    I gotcha now. But you do get a ton of deflection on the stock bushings at lock. Id have someone crank it to lock and watch how much that rack actually moves. Its lots.
    EatSleepTacos[QUOTED] likes this.
  10. Jul 23, 2021 at 2:08 PM
    #7410
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Yeah. So it makes sense that it happened while I was ripping donuts. I was at locklock, just holding the steering wheel fully cranked.
  11. Jul 23, 2021 at 2:09 PM
    #7411
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Would cutting less of the steering stop work I guess? What’s the issue with not cutting it at all?
  12. Jul 23, 2021 at 2:11 PM
    #7412
    906taco
    Cory
    08 Taco
    From the looks of things the factory steering stop might possibly get jammed under the arm. Id imagine that would not go well at all.
    EatSleepTacos likes this.
  13. Jul 23, 2021 at 2:13 PM
    #7413
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I'm not sure where the stop would sit in relation to the LCA. I just cut it off at the beginning of the install since that's what the instructions say. I think Cory is right though, it could possibly get wedged underneath.
    Dayman Karate[QUOTED] likes this.
  14. Jul 23, 2021 at 2:14 PM
    #7414
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I missed your edit the first time. I had considered poly bushings but one, it's a pain in the dick. Two, I've heard of some weird issue with it not returning to center, or something like that. I don't recall exactly, but there are reports of poly bushings causing issues.
  15. Jul 23, 2021 at 2:20 PM
    #7415
    906taco
    Cory
    08 Taco
    I can tell you, with the slide rack lock is lock and it doesnt keep moving. Truck drives better than stock and wheel returns just fine. I ran poly bushings in my last rack as well and never noticed anything weird. My personal bet is it made contact from deflection. If you watch that rack you wont believe how much it moves with the stock bushings
  16. Jul 23, 2021 at 2:24 PM
    #7416
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    That’s what I was thinking, too. I’ll have some time to play with everything without the wheel and coil over and see what’s what. Only thing I don’t know is if I can cycle it properly without having the toe set or without the tie rod connected?
  17. Jul 23, 2021 at 2:26 PM
    #7417
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I would wait to do anything until you have the tie rod ends mounted and at least an eyeball/tape measure toe adjustment.
  18. Jul 23, 2021 at 2:27 PM
    #7418
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If that is the case, that could be why this hasn’t been reported yet. I’m sure all of JD’s trucks have the slide rack so they wouldn’t know about it.
    kasnerd and Slashaar like this.
  19. Jul 23, 2021 at 2:49 PM
    #7419
    906taco
    Cory
    08 Taco
    It’s very possible! But hey, all of us giving input only improves the product.
  20. Jul 23, 2021 at 2:51 PM
    #7420
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Exactly why I post my progress and thoughts in here. Helps everyone out.
    bhigbee and Dayman Karate like this.
