Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Aug 5, 2021 at 4:57 PM
    #7761
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    Yeah short sighted to put it there where it’ll collide with the UCA gussets. I have way too much preload and negative camber on the passenger side so it’s coming back off anyways. I rode it around the yard and found that the tire collided with the limit strap and LCA at full lock. Steering stop hadn’t engaged yet. Alignment is way off so that needs to be fixed before I can accurately see what’s going on with that. I may have to step down to a lighter coil, it’s sitting wayyy high.
    Oreo Cat, Slashaar and ovrlndkull like this.
  2. Aug 5, 2021 at 5:01 PM
    #7762
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    If you like the spring rate but want a lower ride height let me know and I’ll trade you out for a shorter spring
    Dayman Karate[QUOTED] likes this.
  3. Aug 5, 2021 at 5:12 PM
    #7763
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    What coils are on there right now?
  4. Aug 5, 2021 at 5:21 PM
    #7764
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    18” 600lb. I think they will ride fine, just hoping they can ride lower.
  5. Aug 5, 2021 at 5:24 PM
    #7765
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I would just give it a little time before jumping to swap IMO. Wait until you get your kinks worked out in the front end. I only say that because I was a bit too high with 18”x600 and 16”x600 likely would’ve been fine, and I’m even lighter than you up front.
  6. Aug 5, 2021 at 5:25 PM
    #7766
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    I take that back I have 18” coils. I originally was going with 16” 650. Got confused
  7. Aug 5, 2021 at 5:27 PM
    #7767
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Ahhh then maybe you are a little high then. I went 16x700 then 18x600 and finally 18x500. Very thrilled with the 500s for my use.
  8. Aug 5, 2021 at 5:30 PM
    #7768
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Yeah I have a feeling backing off all the preload won’t be enough, but we will see. 18” 550’s or 16” 600’s could be the ticket.
    EatSleepTacos[QUOTED] likes this.
  9. Aug 5, 2021 at 5:59 PM
    #7769
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    @cementnotgray take a look through here and Jdfabrication.com
    Camazon, CGoss and a2lowvw like this.
  10. Aug 5, 2021 at 9:01 PM
    #7770
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Took all the preload out and still riding about an inch or so too tall. Might settle a bit. Drove really strange on the road. Hard to explain but felt like it never wanted to center itself and when you correct it wouldn’t stop turning until you correct the other way a bit. Almost like it was running over itself if that makes sense.
    First glance it looks like it’s toed out too much but they’re adjusted all the way in until the extenders bottomed out.
  11. Aug 5, 2021 at 9:59 PM
    #7771
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    You need a 16” spring or an 18” with a softer spring rate but for the weight you carry a 600# should work great.
  12. Aug 6, 2021 at 3:16 AM
    #7772
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Get an alignment and get that sorted out. Caster being way out will cause what your describing. If you can visually see toe being wack then definitely get an alignment.
  13. Aug 6, 2021 at 4:17 AM
    #7773
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    I have taco tabs set for camber/caster. I don’t see how they’re going to be able to toe it in any more since I threaded the outers all the way in and that wasn’t enough.
  14. Aug 6, 2021 at 4:24 AM
    #7774
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Do you have the double shear steering kit or just regular TRE?
  15. Aug 6, 2021 at 4:28 AM
    #7775
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    You put all new suspension under it. It's gonna require different setting than those taco tabs. And camber and caster affect toe so there is that.
  16. Aug 6, 2021 at 4:30 AM
    #7776
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Regular TRE. Just looked at it in the daylight and there’s a crazy amount of toe out. Like two inches just eyeballing it.
  17. Aug 6, 2021 at 4:31 AM
    #7777
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    The way I have them toe would benefit I would think. I have the rear most mounts half out and the front half in although they’re in different slots relative to each other.
    Three settings- 1-max in board, 2-middle, 3-max outboard
    DR-3, DF-2, PR-2, PF-1
  18. Aug 6, 2021 at 4:34 AM
    #7778
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It’s possible you were accidentally sent the steering extensions for the +4 kit
    DocME likes this.
  19. Aug 6, 2021 at 4:34 AM
    #7779
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    I thought that, but they measured 2.25”
  20. Aug 6, 2021 at 5:00 AM
    #7780
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    So those arms and everything are completely different than the stock stuff it would be good to put it on a machine or measure and see where everything is. If camber is way out it could be affecting you getting your toe set correctly
