Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Aug 6, 2021 at 7:58 AM
    #7801
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    I’ll play around with it some more. Should I shoot for more positive camber less castor? What would bring the toe in 1-2” total from what it is now without adjusting the tie rods?
  2. Aug 6, 2021 at 8:00 AM
    #7802
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    4 degrees caster and .5 negative camber
    01 dhrracer and buk like this.
  3. Aug 6, 2021 at 8:05 AM
    #7803
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    I’ll try some more adjustments but I’m banking on there being a length difference in the aftermarket inners or outers. I don’t see how that much more adjustment could be obtained from the slots. Let’s say my castor and camber are totally off, I should still have enough room to toe straight by adjusting the tie rods. I shouldn’t be even eyeball close aligned and maxed out on the tie rods.
  4. Aug 6, 2021 at 9:16 AM
    #7804
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Castor/camber will change the toe more than you think. Couple inches easy depending where everything is at.
  5. Aug 6, 2021 at 9:18 AM
    #7805
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    If anything I’m very slightly negative on the camber based on throwing a level on the tire, which would pull the toe out. If I went max inboard on the cams I’d be way too positive camber and I doubt I’d have enough room to adjust toe. Caster won’t affect toe besides the fact that it is altered when camber is altered. Maybe I’m totally off, but have been able to rough in alignments thus far without issue. At least good enough to drive it to the shop. I’ve never maxed out the adjustment on a tie rod though.
    I’m no expert, and low down on the intelligent totem pole in this thread for sure, so if I can’t figure it out I’ll throw the OEM cams back in and take it to a shop then match the settings with the taco tabs if possible.
  6. Aug 6, 2021 at 9:23 AM
    #7806
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    You can always do what I do and just throw a tack weld on the oem cams so it doesn’t move. Then you get all the adjustability you want and it won’t move.
    Dayman Karate[QUOTED] likes this.
  7. Aug 6, 2021 at 9:28 AM
    #7807
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    That and witness marks might be the best bet. I have to somehow get the toe in before driving it to a shop though. It’s that bad. I’ll play around some more. Maybe I hit a rough spot or grime when trying to adjust the tie rod and thought it was maxed out. Who knows.
  8. Aug 6, 2021 at 9:29 AM
    #7808
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Just out of curiosity, where are your cams set right now? @EatSleepTacos
  9. Aug 6, 2021 at 9:33 AM
    #7809
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Rear is all the way outboard and front is in the middle. The key to having the same on both sides is having your ride height level side to side.
    Idk what my caster is actually at but since I have a basic understanding of how it all plays together, I’m sure I’m around the 3°-4° mark. Camber at 0 measured with a digital angle finder, toe 1/8” in done with a tape measure. Truck drives great, no pulling. Tires wear evenly too.
  10. Aug 6, 2021 at 9:38 AM
    #7810
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    That’s exactly where I started and brought the camber in (positive) by moving inboard on the passenger side symmetrically. My passenger side has needed that for as long as I can remember. So ours are pretty much the same yet I’m out of toe adjustment
  11. Aug 6, 2021 at 9:48 AM
    #7811
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    And before anyone says every truck is different, that’s true to an extent, but they are made within a certain level of conformity that wouldn’t account for a wild amount of difference in toe between two trucks modified similarly. I think the problem is in the tie rods or that area.
  12. Aug 6, 2021 at 10:47 AM
    #7812
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If I were in your shoes, I would first find some level concrete to park on. Take a tape measure to it and actually see what your toe looks like. And then if necessary I would trim the tie rod down a bit so you can suck them in even more without bottoming out on the steering extension. Will it fix it? No idea. But if I were in your position that's where I would start.
  13. Aug 6, 2021 at 11:00 AM
    #7813
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Yeah that’s what I’m going to do. The plan was to toe it in decent and get it finalized at a shop, but there’s no point in doing that now since they can’t adjust it in any more. It’s obviously way too toed out even to the naked eye so I’ll have to figure that out first.
  14. Aug 6, 2021 at 11:03 AM
    #7814
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    ALWAYS set caster and camber first. Toe is last.
  15. Aug 6, 2021 at 11:46 AM
    #7815
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    FIFY
    desertjunkie760 likes this.
  16. Aug 6, 2021 at 11:48 AM
    #7816
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    It was, I just don’t have any more toe to go in.
  17. Aug 6, 2021 at 11:49 AM
    #7817
    906taco
    Cory
    08 Taco
    Kinda ran on the assumption he had already done that, but yeah. That too.
    a2lowvw[QUOTED] likes this.
  18. Aug 6, 2021 at 11:50 AM
    #7818
    906taco
    Cory
    08 Taco
    Bro, I can see from pictures your camber is straight whack. Push the rear bolt out and see what happens. And oh, ditch them stupid taco tabs if you want a good alignment.
    81Trekker[OP] likes this.
  19. Aug 6, 2021 at 11:54 AM
    #7819
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Bro, that’s the toe making it look like that. Hard to tell from pictures, but I can assure you camber is not off that bad.
  20. Aug 6, 2021 at 11:55 AM
    #7820
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Also, rear bolt outboard would increase negative camber
