Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Aug 20, 2021 at 5:52 AM
    #8141
    NcTaco27
    NcTaco27 Well-Known Member
    Brenton
    East Tennessee
    2015 TRD off-road taco
    Lt front/rear Jd fab…
    I did because I messed up the first set and went to Napa the actual shaft diameter and spline count are different. Luckily I found some used oem axles for $50 same day. Inners or outers that are aftermarket will not work.
  2. Aug 20, 2021 at 5:53 AM
    #8142
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    That's good to know, thanks for chiming in.
    Dayman Karate likes this.
  3. Aug 20, 2021 at 9:00 AM
    #8143
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    I wonder how possible it is to go 930 outers? Obviously we would either need to find a stub that works, or have them made. But honestly, sometimes its not all that expensive to have that kind of stuff machined with enough being made each run. I would pay a good bit extra to make that outer stronger, because that has been my failure on 2 shafts now.
  4. Aug 20, 2021 at 9:22 AM
    #8144
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    It's been discussed but with 934 inner/outer. It's a lot of work and money to make it happen. Makes it absolutely bomb proof, easy repair and carrying one type of spare.
  5. Aug 20, 2021 at 9:24 AM
    #8145
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    You have to eliminate the Toyota unit bearing which means moving to a custom spindle. I can easily do them they will just be very expensive... trust me, we have heavily looked into it and I doubt anyone would be willing to fork up the dough.
    Slashaar likes this.
  6. Aug 20, 2021 at 9:30 AM
    #8146
    906taco
    Cory
    08 Taco
    What about the possibility of just a different hub that works with the toyota bearing? I know DSS does lots of supra stuff with 930's and they just supply a different hub that presses into the factory bearing. I understand at some point you have to factor in the weak bearing, but to be honest it doesn't bother me personally a whole lot to change a bearing or other wear parts.
    I've heard rumors silverado 33 spline hubs will accept micro stubs. However I have not confirmed this personally.
  7. Aug 20, 2021 at 9:45 AM
    #8147
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    At that point you could just do a Dana 44 and not have press bearings anymore
  8. Aug 20, 2021 at 9:54 AM
    #8148
    906taco
    Cory
    08 Taco
    I don't disagree, but I gotta say. I have not had any bearing issues whatsoever. Maybe its my driving style, I guess I don't know. Maybe I'm just lucky. I just cant see fixing whats not broke at this point. And I can definitely say the factory outer is a weak link.
  9. Aug 20, 2021 at 9:55 AM
    #8149
    81Trekker
    La Jolla SD
    A 930 isn’t stronger than the Toyota outer so it would be a total waste, you need to go 934 for the strength and it won’t fit in the factory spindle... again we have tried
  10. Aug 20, 2021 at 9:56 AM
    #8150
    81Trekker
    La Jolla SD
    That doesn’t make any sense as you would have to run a u joint on the axle or make custom stub shafts that would cost and actual fortune
  11. Aug 20, 2021 at 10:03 AM
    #8151
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It’s what I’m running - I like just being able to find hubs easily
  12. Aug 20, 2021 at 10:07 AM
    #8152
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Makes sense on a prerunner not on something with 4wd
  13. Aug 20, 2021 at 10:11 AM
    #8153
    Dalandser
    Anthony
    Downey
    Empty Wallet Mod
    It works. Some of you guys are shelling out nearly as much for custom cv’s so cost doesn’t affect the setup. May not be your cup of tea - no problem. I’m D44 and D60 so I can get parts almost anywhere and unfortunately my 7.5 front diff is the limiting strength in the front so I don’t really worry about having to replace a shaft - not that you’d be able to any quicker. Remember this is coming from the fabbed spindle suggestion. You’re free to do whatever you want so a lot of options are possible. Spending too much time in this thread isn’t good for me - too tempting to put a lt kit and sua on my reg cab.
    tacotunner06 likes this.
  14. Aug 20, 2021 at 2:26 PM
    #8154
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    These tie rods are absolutely beautiful ~chefs kiss~
    BassAckwards, T.Barn, y=mx+b and 8 others like this.
  15. Aug 20, 2021 at 2:46 PM
    #8155
    906taco
    Cory
    08 Taco
    Since when are they black?!?!
  16. Aug 20, 2021 at 2:49 PM
    #8156
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    they’re not he destroyed a beautiful cnc’d & polished rod with a rattle can…pretty sure that’s against the rules :evil:
  17. Aug 20, 2021 at 2:50 PM
    #8157
    906taco
    Cory
    08 Taco
    That looks anodized from here…
  18. Aug 20, 2021 at 2:52 PM
    #8158
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    It’s anodized. Didn’t realize they would be when I ordered them. A nice touch since I was gonna steel-it anyways
    BEAR_KNIFE_FIGHT and Slashaar like this.
  19. Aug 20, 2021 at 2:56 PM
    #8159
    906taco
    Cory
    08 Taco
    I’m a sucker for anything billet. Even more of a sucker for anodized billet.
  20. Aug 20, 2021 at 3:16 PM
    #8160
    81Trekker
    La Jolla SD
    They are all ano black now
