Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Dec 6, 2019 at 6:43 PM
    #801
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    It will be kissing the underside of the bed
    Arcticelf[QUOTED] likes this.
  2. Dec 7, 2019 at 7:56 AM
    #802
    Jowett
    Jowett Well-Known Member
    Brian
    North Adams, MA
    Excellent build OP. Out of the box is the best way, nice job.
    jdiola likes this.
  3. Dec 7, 2019 at 10:42 AM
    #803
    81Trekker
    La Jolla SD
    Thank you!
  4. Dec 7, 2019 at 4:16 PM
    #804
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    That's the spirit. A
    I'm sure you know, flex in the shock hoop becomes an issue, how are you planning to deal with it? I'll do a hoop in the bed, bolted through the plastic to control it on my design.
  5. Dec 7, 2019 at 4:32 PM
    #805
    81Trekker
    La Jolla SD
    It won’t be a hoop, it will be all laser cut 3/16 cromoly plate
  6. Dec 8, 2019 at 11:41 AM
    #806
    camillethetoy
    camillethetoy Just a Minor Threat
    jeremy
    KCMO
    98 T100
    In the past 2 days I've read this entire post. I love for things to be done correctly and I like your style, trying to stick as close to stock as possible. It's like a super stock plus build, love it! Keep it up, best build thread I've ever jumped in.
    Just picked up a 2010 FJ, have you looked under these, wondering if the kit would work for FJs. From everything I've read so far, most of the A-Arms are interchangeable. I would love to run 35's with minimal lift and maximum flex using a kit like this! Get back when you can & thanks again!
  7. Dec 8, 2019 at 12:16 PM
    #807
    81Trekker
    La Jolla SD
    Tha k
    Thank you for the kind words! I’m not sure about the fit on and FJ but I would be curious myself. I’ve heard the suspension is the same as a Tacoma but I’m wondering how different the rest of the frame is. I would start by asking the guys on the FJ forums
    jdiola and camillethetoy[QUOTED] like this.
  8. Dec 8, 2019 at 1:57 PM
    #808
    81Trekker
    La Jolla SD
    Tha k
    Does anyone know if one of the taco drop down lift kits fits on an FJ?
  9. Dec 8, 2019 at 2:00 PM
    #809
    camillethetoy
    jeremy
    KCMO
    98 T100
    Posting in the FJ forum now, I'll hit up a couple of the other forums to find out more..
  10. Dec 8, 2019 at 2:04 PM
    #810
    81Trekker
    La Jolla SD
    If a drop down lift from a Tacoma will fit an FJ then this kit will work for sure
    camillethetoy[QUOTED] likes this.
  11. Dec 8, 2019 at 4:16 PM
    #811
    Arcticelf
    Gladiator
    Very nice. I want to see that.
  12. Dec 8, 2019 at 10:40 PM
    #812
    planesane
    planesane Well-Known Member
    2015 white Tacoma limited 4x4
    6 inch rough country lift kit, Kings shocks front and rear, Deaver leaf pack, 4xinnovations shackle flip, 6 inch shackle, front, rear bumpers , rock sliders, warn winch, 35 inch tires
    My rear go into the bed just a little. I have great clearance in the back. I rub firewall while turned. Need to tub it( I believe that's what they call it)
  13. Dec 12, 2019 at 6:45 PM
    #813
    JanBoothius
    JanBoothius Well-Known Member
    Jan (Pronounced Yon)
    Upstate New York
    2015 TRD OR DCSB 6 speed
    Heavy stuff big tires drives like hell
    Let's see a super detailed install on your buddies truck ASAP!
    I really want to be one of the early adopters of this system. I just bought SPC UCA’s, they cost nearly as much as this would, I'm tempted to return them and buy this instead.
    That said, I'm curious how this system would play with trucks that already have caster correcting UCA's, would you need to return to stock or a UCA with stock specs?
    CMScheid likes this.
  14. Dec 12, 2019 at 10:09 PM
    #814
    81Trekker
    La Jolla SD
    I should be tearing into his truck in the next week or two, still waiting on the shocks from king.
    As for the upper arms I don’t understand why anyone would buy the SPC when you can get a real 1 1/2” tubular arm with a uniball for cheaper!
    Calamity_taco likes this.
  15. Dec 12, 2019 at 10:23 PM
    #815
    literallynothing
    literallynothing I tow my new truck around with my old truck
    Noah
    2017 DCSB
    Steel and 37s
    Because if you aren’t mobbing in the desert, the adjustability allowed by SPC arms and lack of maintenance needed on a ball joint vs a uniball are nice to have. It all comes down to how the truck is used
  16. Dec 13, 2019 at 4:57 AM
    #816
    81Trekker
    La Jolla SD
    But if you get a caster corrected upper there is no need for adjustable uppers and the EMF uniballs require zero maintenance, last longer than any ball joint and when the time comes they are easily rebuildable.
  17. Dec 13, 2019 at 4:58 AM
    #817
    Arcticelf
    Gladiator
    I like JBA better than SPC, but there's definitely a big market segment where they are the best answer.
    ~signed, a uniball and heim joint evangelist
  18. Dec 13, 2019 at 5:10 AM
    #818
    Arcticelf
    Gladiator
    I agree on the adjustable ball joint, but I don't see any reason an EMF would be less maintenance or work than an FK uniball. The FK is zero maintenance, but they only last 12 to 18 months around here.
  19. Dec 13, 2019 at 6:27 AM
    #819
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    He built arms for this kit that use a uniball. He was pretty clear in the beginning that he didn’t want to use a uniball. The adjustability comes from the LCA mount on this kit and not the UCA.
  20. Dec 13, 2019 at 6:50 AM
    #820
    81Trekker
    La Jolla SD
    EMF’s are sealed and have a zerk fitting to grease the joint therefore they last way longer than any uniball. And when the time comes they are easily rebuildable
