Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Sep 1, 2021 at 8:35 AM
    #8641
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    All clear there. It's an odd sound. Only happens slow speed over pot holes or small dropouts on the passenger side...I'm leaning towards a body panel shifting or something.
    It sounds almost identical to when you first put your tire on the studs and it clanks against the rotor...if that makes any sense. That solid aluminum hitting solid steel clunk/knock.
  2. Sep 1, 2021 at 8:37 AM
    #8642
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Checked your core support bushings? They can make some crazy noise. Especially if your fender is whacking a steel bumper
    Dayman Karate[QUOTED] likes this.
  3. Sep 1, 2021 at 8:44 AM
    #8643
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Clunked before and after changing those, but not ruling out some sort of frame/body contact. Cab is far enough away from the bumper. I haven't see any hit or rub marks. It's probably something really dumb and unimportant haha
  4. Sep 1, 2021 at 8:46 AM
    #8644
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Also, sorry to throw my question in right after yours. I didn't mean for yours to be skipped over. Hate when that happens.
  5. Sep 1, 2021 at 8:48 AM
    #8645
    906taco
    Cory
    08 Taco
    Its all good, I honestly don't expect much feedback on it.
  6. Sep 1, 2021 at 8:57 AM
    #8646
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Of the 3 other tacomas that I know of that ditched their inner fenders completely for an engine cage, none of them moved the fuse box, me included. To me it just seemed like way too much hassle and like a custom harness would be easier. But if you want to cut and extend 60 wires to move yours then go for it
  7. Sep 1, 2021 at 9:00 AM
    #8647
    906taco
    Cory
    08 Taco
    Harness has been a strong consideration. But I would like things to be a little more "done" before I start that fun. Its not a cheap endeavor to build a truly nice harness, so I don't necessarily want to build one only to hack it apart. If only this 4.0 would give up the ghost.....
  8. Sep 1, 2021 at 9:00 AM
    #8648
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    On my truck I have a similar noise on the driver side. I’ve always chalked it up as the brake pads shifting in the calipers. I’ve replicated it several times.
    Another tinny popping sound I also got from the cab mounts when I went poly.
  9. Sep 1, 2021 at 9:10 AM
    #8649
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    A custom harness for the 4.0 would be the biggest nightmare ever as they are very, very finicky. The best advice I can give is don’t start messing with the wiring or you will regret it. This is spoken from my personal experience as well as a master Toyota tech that build standalone harness.
    Arcticelf, llibrm, DocME and 2 others like this.
  10. Sep 1, 2021 at 9:14 AM
    #8650
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    I had a mysto " clunk " and discovered that it was my drivers side inner CV. The PTFE liner in the ECGS bushing was worn out allowing too much slop, the bushings are a wear item and need to be replaced when they wear out.
  11. Sep 1, 2021 at 9:15 AM
    #8651
    906taco
    Cory
    08 Taco
    Oh there is no doubt about that. I have zero intentions of building a harness until the 4.0 pops and I put an LSA in...
    tacotunner06 likes this.
  12. Sep 1, 2021 at 9:21 AM
    #8652
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    Agreed. But mine came along as soon as i put poly bushings on and they settled. It also didn't go away when I put an ARB in and they get rid of the factory bearing also and go to a bushing of sorts
  13. Sep 1, 2021 at 9:24 AM
    #8653
    906taco
    Cory
    08 Taco
    Could even be diff mounts potentially...
    Dayman Karate likes this.
  14. Sep 1, 2021 at 9:24 AM
    #8654
    RonRon23
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Hmm now I want to check mine. I was told it was in there for life. 100k+ miles on mine. I wonder if that’s what my driver side noise is that I thought was caliper/pad slap.
  15. Sep 1, 2021 at 9:32 AM
    #8655
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    sounds like you need more miles bouncing off the rev limiter than...
  16. Sep 1, 2021 at 9:35 AM
    #8656
    906taco
    Cory
    08 Taco
    Not intentionally trying to kill it lol. But I'm definitely not friendly either.
  17. Sep 1, 2021 at 9:51 AM
    #8657
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    All it took was my clutch burning out and i was like yup ls time...lol. All i can say is that once you do it your gonna wonder why you waited so long...lol
  18. Sep 1, 2021 at 10:35 AM
    #8658
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Interesting. I’ve had it before with the ECGS bushing and now with the ARB locker so it may not be that. It seems to do it the worse on droop, low speed. Gotta be something dumb. It gets old hearing it, but nothing has shit itself completely to think it’s a major issue, just a nuisance.
  19. Sep 1, 2021 at 10:39 AM
    #8659
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    The spherical bearings on your coil overs?
  20. Sep 1, 2021 at 10:54 AM
    #8660
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Nah it’s happened on 5100s, Kings and now Fox. I might check the engine mounts, but I think I’d be getting some other feedback/virbrations if one was bad.
