Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Sep 13, 2021 at 10:04 AM
    #8861
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Run it at 4K plus rpms for hours in the dirt with 37’s and I promise it will over heat. Real off road stuff is much different.
    tacotunner06 likes this.
  2. Sep 13, 2021 at 10:10 AM
    #8862
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    I won’t deny mechanical fans are awesome for reliability, but they definitely don’t move air like a properly setup electric fan. But it takes lots of work to make sure every bit of air is being directed where it needs to go.
  3. Sep 13, 2021 at 10:30 AM
    #8863
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    I was looking at my truck the other week and starting thinking how much better the oem fan system can work if the air was just channeled and sealed off to keep are directed through the condenser and radiator. So many air leaks.
  4. Sep 13, 2021 at 10:35 AM
    #8864
    906taco
    Cory
    08 Taco
    Air dams make a huge difference. And are something many completely shrug off as unnecessary. Thin rubber, anything to put the air through the cores and not around. I've got lots of time under my belt building big big HP street cars. And they are a royal pain to keep cool. Air dams and shrouds are an absolute must for good cooling.
    RonRon23[QUOTED] and Torspd like this.
  5. Sep 13, 2021 at 10:35 AM
    #8865
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    Don't get a CSF rad. Just noticed mine has the ~3/16" gap on either side with the fan shroud. Guess it's time to shave down those posts or cover it somehow. argh.
  6. Sep 13, 2021 at 10:49 AM
    #8866
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    Have seen guys use rubber trim seal for small gaps like that on Chump cars or they will just use speed tape. Both of which probably aren't nice enough options for your truck.
  7. Sep 13, 2021 at 11:10 AM
    #8867
    906taco
    Cory
    08 Taco
    If only someone would build a nice core support with cooling and strength in mind. Hint hint Harry….
    Torspd likes this.
  8. Sep 13, 2021 at 11:15 AM
    #8868
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    At this rate, how soon till JD turns into the Singer Design of Tacomas?
    Trim taco and 01 dhrracer like this.
  9. Sep 13, 2021 at 11:15 AM
    #8869
    81Trekker
    La Jolla SD
    “Tacoma’s are such amazing off road trucks” -every member on TW
    “Can you build me a better version of every single part for my Tacoma” also every member on TW
  10. Sep 13, 2021 at 11:16 AM
    #8870
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    I heard that the 81 Trekker is the prototype for their own ground up vehicle
    Slashaar and 01 dhrracer like this.
  11. Sep 13, 2021 at 11:19 AM
    #8871
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    :pray:
    01 dhrracer likes this.
  12. Sep 13, 2021 at 11:20 AM
    #8872
    906taco
    Cory
    08 Taco
    Hey now. We are just too poor for the luxury pre runner shit!
    Tyler7544 and Slashaar like this.
  13. Sep 13, 2021 at 11:32 AM
    #8873
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    hey…at least we can physically fit in our trucks :boink:
    Slashaar likes this.
  14. Sep 13, 2021 at 1:00 PM
    #8874
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    I see a truggy/buggy in my future. I don’t think it’s worth it to me to spend much more on the Tacoma. Too much trouble for limited returns. I want something I can roll and it’s not immediately destroyed. By the time I get around to doing it I will have wheeled the Tacoma enough to know what I want. Who knows what will happen by then. I’m still pretty new to all of this.
    ovrlndkull and 01 dhrracer like this.
  15. Sep 13, 2021 at 1:22 PM
    #8875
    Bonzen
    Bonzen Solid Offroad motor & transmission mounts
    Lake Havasu City
    The Silver Bullet
    Everything.
    You may be right, I honestly do not know. It would be interesting to find out what a stock 4.0 V6 mechanical fan pushes at 700rpms and at 5000rpms. We just over heated the motor every race off road once we switched to the big boy SPAL fans, and always had electrical issues with them whether we were running hot or not. Lots of failure points from fuses to relays to wiring being damaged or being faulty from the many hazards of desert racing. They pull alotta amps too. We had the fan motors burn up from heat, or from who knows what multiple times as well. Then we were sitting around an overheated truck, in the middle of the desert trying to figure out how to fix it or limp it back to main pit while the competition blew by us and honked lol.
    For a DD or weekend warrior truck its probably fine, but for the average race truck running 4500-5500k RPMs off road in sand and silt for hours on end putting a huge load on the motor, we never had good luck.
    Off road racing is night and day from street driving or street racing. We blew up alotta transmissions off road with a 300HP Toyota V6 that were labeled as "good for 700 - 1000hp on the street" haha.
    But bottom line if something works for you, then it is the correct way, and I firmly believe in that concept 100%.
    Torspd, CGoss, wrmathis and 4 others like this.
  16. Sep 13, 2021 at 6:03 PM
    #8876
    906taco
    Cory
    08 Taco
    Anybody with SUA running a single piece shaft? I am currently running a tom woods single piece and want to be sure it will work with the SUA. Maybe I’ll be the one that answers this question. I do have my stock 2 piece if push comes to shove, but I’d rather not deal with that flaming hunk of crap again.
  17. Sep 13, 2021 at 6:22 PM
    #8877
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    It should be fine as long as it has enough plunge for full stuffing the tires.
  18. Sep 13, 2021 at 6:33 PM
    #8878
    Evenflow
    San Diego, CA
    06' DCSB 4x4
    Yes
    you just have to set your pinion properly which for a double cardon one piece is straight up the shaft at ride height
  19. Sep 13, 2021 at 8:16 PM
    #8879
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    2* down is what I set mine to and its grippier than it was before. Now I just need to get big boy shocks and keep the wheels planted.
  20. Sep 13, 2021 at 8:29 PM
    #8880
    Slashaar
    Josh
    Kansas City, MO
    So Harry @81Trekker my thoughts after finishing my install on the Long Bed. (I'll put the photos in when I get home.)
    1. I believe the frame has a bit of taper to it where the shock towers weld in, as such, they are a bit off parallel. Either that or they warped but I doubt that since they are pretty thick.
    2. The lower bolt holes on the front leaf spring brackets didn't line up with the existing rivet holes which led to a ~3 hour delay in my install.
    3. The gas neck needs to be a complete relocate. I didn't have enough slack to realign the filler to the bedside as the filler tube itself contacts the shock tower before it could make it back to the factory location so if you update the kit, add fuel hose to extend it as well.
    4. What is the extra set of plates for? Theres a short plate with 2 holes that makes sense for the top of the tower, a medium sized plate with 4 holes that align with the side holes of the tower which makes sense. Then there's a set of two plates that the holes are aligned in one dimension, but too spaced on the other to make sense anywhere. Am I missing something here?
    I'll have to source a cross tube and angle the ends to match up with my towers. I hope the angles don't effect my shocks too much. To compensate I mounted the shocks in them and tacked my lower mounts using the shocks as a guide, so they are angled slightly. Guess we'll see when I get around to ordering 2.5 ADS shocks to replace the 2.0s. (I have spacers to compensate on both ends for the width differences on mounts)
    This was a 3 day job that got extended into a 4 day job to get the bed on after the set back drilling out the bolt holes. Everything else went pretty smooth.
    (3x 8-10 hours, 1x 3 hours)
    I'll do a write up as best I can later for @WormSquirts so he isn't jumping in blind like I was.
