Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Jan 23, 2020 at 3:11 PM
    #921
    Chris(NJ)
    Chris(NJ) Well-Known Member
    Usually in Central Jersey
    08 Indigo 4x4 DC OR
    Mods are currently being changed .....
    Good to know! I'm going to order everything in a few weeks when I'm back from MS. Looking forward to getting fresh suspension bits on there. Just got new uniball and bushings for my Downsouth/weld UCAs. Should ride like new when I'm done.
  2. Jan 24, 2020 at 6:24 AM
    #922
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    Better than new.
    Chris(NJ)[QUOTED] likes this.
  3. Jan 26, 2020 at 1:50 PM
    #923
    crashnburn
    crashnburn Well-Known Member
    Conroe TX
    2013 DCLB 4x4
    a couple of things
    Any photos or links to the other trucks running the relocate kit? I’m on 35’s now and would like to go to 37’s but I don’t want to tub the firewall if I don’t have to. I’ve done it before on a 4Runner and it was a PITA
  4. Jan 26, 2020 at 1:56 PM
    #924
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    I will try to get some pics for you this week. I can tell you a minor cmc and this kit clears 35’s no problem
  5. Jan 26, 2020 at 5:12 PM
    #925
    crashnburn
    Conroe TX
    2013 DCLB 4x4
    a couple of things
    Well I rotated the bushings on my cab mounts to allow me to cut them back more, so my cab mounts are about as chopped as you can get without fully replacing them, and I’ve taken 3” out of the fenders. I need to work the firewall over with a sledge hammer again as my tires just kiss the firewall. I’m hoping with just a little more work and the LCA relocate that I can get a 37 to fit without having to tub it or go with a long travel kit
  6. Jan 26, 2020 at 6:29 PM
    #926
    81Trekker
    La Jolla SD
    Well if 35’s fit your current setup 37’s are only an 1” bigger from the hub center out so pushing the arms forward 1” should get you where you need to be
  7. Jan 27, 2020 at 3:07 PM
    #927
    603fishhunter
    603fishhunter Well-Known Member
    Forrest
    New Hampshire
    2014 tacoma 4 cyl access cab
    6" rough country lift
    My 5.29 gears came in today and now I’m tire shopping. Currently have 305/65 r17 (33’s) and a 6” DB lift. It looks like I still have at least an inch and a half for expansion all around in a resting position with the wheels cranked. Anyone have experience with how big I can go?
  8. Jan 27, 2020 at 5:07 PM
    #928
    Arcticelf
    Gladiator
    295/70R17s will fit for sure, with the gears 315 is an option.
    603fishhunter[QUOTED] likes this.
  9. Jan 28, 2020 at 12:45 AM
    #929
    steele-taco
    steele-taco Well-Known Member
    james
    Jersey shore
    17 TRD OR DCSB white
    2020 is the year of SUA, 2021 is the year of the link, and I believe 2022 is the year of the dragon.
  10. Jan 28, 2020 at 5:39 AM
    #930
    la0d0g
    running for the hills
    For crawling not hauling
    You have a 6" db lift. You can fit 38s.
  11. Feb 14, 2020 at 11:24 PM
    #931
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Ordered this kit from JD this week! Excited to see how this goes!
  12. Feb 15, 2020 at 5:11 AM
    #932
    81Trekker
    La Jolla SD
    Right on! feel free to message me anytime with install questions and please post lots of pics!
    CMScheid and WormSquirts like this.
  13. Feb 15, 2020 at 8:49 AM
    #933
    6 gearT444E
    Deep South
    Herculiner Hootus
  14. Feb 15, 2020 at 11:27 AM
    #934
    WormSquirts
    Braeden
    BC
    Looking forward to this! Ordered the red goat fab body mount relocation kit as well. I had to start running wheel spacers to clear the rear shocks on my 63 swap, and now the front rubs the firewall/body mount very badly. I wanted to do all of this anyway to move up to 37s, so it just moved my schedule ahead a bit! I'm still expecting to have to tub, but shouldn't be nearly as invasive as without this kit! Plus the extra strength + clearance under the engine will be nice.
    Nimble9 likes this.
  15. Feb 15, 2020 at 11:59 AM
    #935
    81Trekker
    La Jolla SD
    I’ll be really interested to see how it fits with 37’s. I’m super curious if you will even need to tub
  16. Feb 15, 2020 at 12:02 PM
    #936
    WormSquirts
    Braeden
    BC
    I figure 37's add an inch all the way around, so if this moves the wheel forward 1", then I will be exactly where I am now with 37s, which will need at least a bit of tubbing. Plus I rub the top of the wheel well at full compression when hitting big G-outs or bumps currently, so that's only going to get worse.
  17. Feb 15, 2020 at 12:24 PM
    #937
    81Trekker
    La Jolla SD
    The top of the wheel well will need to get cut out, no question but the fire wall is what I’m dying to see!
  18. Feb 17, 2020 at 3:36 PM
    #938
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    Awesome fab work, awesome thread but really just subbed for the dessert. :hungry:
    la0d0g and Taco-Obsessed like this.
  19. Feb 24, 2020 at 9:27 AM
    #939
    sbchero
    sbchero Wheeler
    Garrett
    Brighton CO
    14 TRD Sport 4x4
    TC L/T, King shocks/bumps, F/R ARB's, RCV Shafts, glassworks fenders/bedsides.
    well after reading this whole thread i'm going to order the kit. i've been plagued with having to get an alignment every time i go wheeling. and the stock mounts are pretty banged up. this is a rad setup.
    might have to modify my bumper after but that's the cost of doing business.
    now onto this steering setup? any progress or updates. i will buy now, i desperately need a better steering solution for my wheeling style. I've looked at the tundra racks and might go that route but i'm custom to my feel that i have on my rock crawler with full hydro. i realize that it wont be like that, but something that doesn't knock the wheel out of my hands on desert roads and some ability to turn in the rocks is what im after.
    just ordered it after calling jessie @ JD. im getting a steel skid instead of AL. looking forward to seeing it in person.
    honda50r likes this.
  20. Feb 24, 2020 at 11:07 AM
    #940
    81Trekker
    La Jolla SD
    It will be exciting to see your install.
    As for the steering there is a top secret setup that will be available in the next few weeks!
