Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Oct 1, 2021 at 8:24 PM
    #9601
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    I run the raptor specific 35” ko2’s which are load range C on my 2500HD for ride quality. The problem is finding a shop to “legally mount them” because they are too light duty for a 2500. They do wear faster but I’d rather buy new tires every year then drive a truck that rides like shit
  2. Oct 1, 2021 at 8:28 PM
    #9602
    04TacoRunner
    04TacoRunner Toyota Junkie!
    CC TX
    :thumbsup: We have run probably 20+ sets of these on our work trucks and are still running them. Great tires they do get hard and chip out when older but what tire doesn't?
    ovrlndkull[QUOTED] likes this.
  3. Oct 1, 2021 at 8:36 PM
    #9603
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Hard to find anything other than load E in 285+ for 16". Been eyeing the Nitto Terra Grappler's in Load D
  4. Oct 1, 2021 at 8:39 PM
    #9604
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    37x12.50R17/C 116S RBL
    BUY NOW
    MSPN80088
    Mileage Warranty50,000
    Section Width on Measuring Rim Width12.00" on 10.00"
    Overall Diameter36.5
    Max Load, Single (LB @ PSI)2755 @ 45
    SidewallRBL
    Revs/MI569
    Tire Weight64.84
    Rim Width Range (Min/Max)8.50-11.00
    Tread Depth (in 32nds)151
    Specifications
    - 3PMSF- M+S
    From BFG web site.
  5. Oct 1, 2021 at 8:44 PM
    #9605
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    That’s not a bad weight for a 37ish. My e rated Cooper mud terrains are getting old to daily drive. I rock side to side coming to a stop because of the giant lug spacing. Rough as hell unless they’re 12-15 psi
  6. Oct 1, 2021 at 8:46 PM
    #9606
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    RIP the old Firestone steeltex never had issues with them sadly like a lot of things a hell of a good tire lost to "better" performance and now they suck.
    You're right though today there isn't much out there. I like them and the AT3 XLT.
  7. Oct 1, 2021 at 9:07 PM
    #9607
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    Yeah with these E rated KM3s. I’m at 25lbs and I’m still seeing ballooning across the tread in the rear. I could probably go lower to get the tread worn evenly on pavement.
    When I had the wildpeaks at3w E’s before these, aired down to 18lbs still seemed like they weren’t aired down much either.
    I’m ready to go back to a C tire.
  8. Oct 1, 2021 at 9:13 PM
    #9608
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    Are you referring to PSI on the pavement? I ran 26 for a while, but got sketched out and upped it to 32. Nothing based in fact, just unsure if that was safe or not.
  9. Oct 1, 2021 at 9:32 PM
    #9609
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    On my Mickeys forget if they're C or D load range I run 30 front and like 25ish rear. Hauling I max the rears out and long trips I max them all out to try and squeeze every last mpg out of it.
    Dayman Karate[QUOTED] likes this.
  10. Oct 1, 2021 at 9:43 PM
    #9610
    RonRon23
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Yes it’s on pavement. If I was on long trips, I bumped to 35-40ish. It really kills the ride on crappy roads though.
  11. Oct 2, 2021 at 4:39 AM
    #9611
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    My mickeys are D’s. I run 25 front and 23 rear and get great wear.
  12. Oct 2, 2021 at 4:48 AM
    #9612
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    That’s reassuring. I don’t know why I thought it was a big deal and went back up. Just seemed so low haha In reality the door says 29 or so for smaller, non e rated tires so 26 isn’t far fetched even with a little extra weight.
  13. Oct 2, 2021 at 5:07 AM
    #9613
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    You can figure out the air pressure required for a given weight. Most non LT tires max press is 40-44. So 29 is around 2/3-3/4 the max press and max load. Chalk test the tires and then you can also do a calculation for air pressure.
  14. Oct 2, 2021 at 7:38 AM
    #9614
    dcoursler
    dcoursler They call me Tater Salad
    Derrick
    Alabaster, AL
    2012 TRD Off Road
    Currie Rock Jock High Pinion 60, JD Fab EVERYTHING, Fox shocks, Radflo Shocks, Archive Garage all the other things, spinny thing on top of the motor
    Tips and tricks appreciated. Tackling this today and tomorrow
  15. Oct 2, 2021 at 9:59 AM
    #9615
    scootter82
    Aurora, CO
    Any preference on the Toyo Open country 285s in C load but weigh 63lbs, vs the Nitto Terra Grapplers in D load at 57 lbs?
  16. Oct 2, 2021 at 10:04 AM
    #9616
    RonRon23
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    I think the trickiest part was the front spacer on the pump. I worked on it from passenger side wheel well. It’s really straight forward.
    Edit: DO NOT use oil to lube the push lock fittings with PS fluid. @906taco thanks for the heads up on my misinformation.
    Double check you have your pinch clamp on the hose before pushing the fitting on. I made that mistake once.
    Other than that, the hardest thing I had trouble with was getting the rack fittings removed. I did it with the wheel on, had to take my steering clevis off and turned passenger to get tools in there. I tightened them from the CV area last time without steering linkages attached. I figure if you have flare nut wrenches it would help a ton. I did not unfortunately.
    Slashaar likes this.
  17. Oct 2, 2021 at 10:05 AM
    #9617
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Toyo owns nitto they are actually really similar. The Toyo is going to be a little softer and more compliant.
    scootter82[QUOTED] likes this.
  18. Oct 2, 2021 at 10:50 AM
    #9618
    01 dhrracer
    Still Shopping
    A little muscle memory happening hear.
    Dayman Karate likes this.
  19. Oct 2, 2021 at 10:52 AM
    #9619
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Toyo not toyota lol autocorrect. You could say that.
  20. Oct 2, 2021 at 12:50 PM
    #9620
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    Already more dirt than @kasnerd and were only just airing down. 150D8A04-144F-40D9-A51C-14461F0BAD37.jpg
