Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Oct 10, 2021 at 8:07 AM
    #9761
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Sounds like it’s time to make room for a tig! FWIW, Everlast welders are legit and affordable. In the event you are in the market for one. My tig is a powerpro 205, even has a plasma.
    Slashaar and Arcticelf like this.
  2. Oct 10, 2021 at 8:47 AM
    #9762
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    I almost never work with aluminum so if anything I’d grab a spool gun and small bottle of gas to run off my mig. Not enough room in the garage for another machine anyways lol
  3. Oct 10, 2021 at 9:04 AM
    #9763
    906taco
    Cory
    08 Taco
    It’s not just about aluminum. For the longest time all I had was TIG. I learned to appreciate what you can do with TIG over all other forms of welding. Yes it’s a learning curve. Yes it takes lots of time behind the torch. But, MIG will never match the precision and ability. I think anybody that is in this world in any way, and does lots of their own work should invest time into learning it.
  4. Oct 10, 2021 at 5:32 PM
    #9764
    Bobotaco
    Bobotaco Active Member
    2013 Tacoma
    JD +4 JD LCA pivots JD Double Shear steering JD 934 cv axles King 2.5x8”coilovers King 2.0x2.0 bumpstops Total Chaos Spindle Gussets DMZ SUA King 2.5x 16” 3tube bypasses King 2.0x2.0 bumpstops Method 701 17” BFG AT2 35x12.5x17 McNeil +4 fiberglass fenders/bedsides 4XInnovations sliders AllPro front bumper Mazzula Offroad rear bumper
    Couple clips I got of the wife driving the truck today. Her driving definitely changed her mind on the money spent on truck parts
  5. Oct 10, 2021 at 5:34 PM
    #9765
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    whats the setup?
  6. Oct 10, 2021 at 7:10 PM
    #9766
    Bobotaco
    2013 Tacoma
    JD+4 with coilover/ 2.0 bumps front and DMZ rear with 3tube bypasses and 2.0 bumps
  7. Oct 10, 2021 at 9:08 PM
    #9767
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    L bracket from the spare mounting hole on the pump to the motor mount and everything seems solid. Pump, reservoir and cooler are mounted. Pluming tomorrow before we get snow on Tuesday.
  8. Oct 10, 2021 at 9:19 PM
    #9768
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    Would love to see a pic
    Slashaar likes this.
  9. Oct 10, 2021 at 9:33 PM
    #9769
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I tried but couldn’t get the phone in there to see it. But it’s a very simple little L bracket. Hardest part was measuring to get it to fit correctly. But got it bolted in with the 1 good existing mount and busted one bolted up and in place to where it was. Time will tell if it’s good enough but it feels solid. The one existing mount is the important one that locates the pump where it needs to be. The other just helps with deflection and rotation.
  10. Oct 11, 2021 at 4:42 AM
    #9770
    bhigbee
    bhigbee Well-Known Member
    Barney
    Hayden Id
    Wrecked 07 DCSB
    35s, flatbed, rhino liner paint, SOS front bumper, JD Fab lca pivot, JD Fab inner fenders and some other stuff.
    I think you know what snow looks like.
  11. Oct 11, 2021 at 6:24 AM
    #9771
    WormSquirts
    Braeden
    BC
    Drove through a crazy snow storm yesterday actually
  12. Oct 11, 2021 at 6:41 AM
    #9772
    bhigbee
    Barney
    Hayden Id
    Wrecked 07 DCSB
    I saw my first snow of the season yesterday too.
  13. Oct 11, 2021 at 9:45 PM
    #9773
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Well it’s up and running again. Either the new pump or the aired up tires at 40psi to make it easier to push are making steering much much easier. Only shimmied around to park so the wife could get in the garage before snow tomorrow but so far so good. I’ll air back down to my normal 15-17psi at work tomorrow and test things out a bit
    bhigbee, Airdog, ovrlndkull and 2 others like this.
  14. Oct 12, 2021 at 5:03 AM
    #9774
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Less rolling resistance makes for a definitive change.
    Slashaar and snowsk8air2 like this.
  15. Oct 12, 2021 at 6:18 AM
    #9775
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yeah first day pushing it in and out of the garage I was like what the freaking hell!!! When did I become a weak ass lol. Aired up and it rolled like a dream lol
  16. Oct 12, 2021 at 6:28 AM
    #9776
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    No gains, when it's easy. :benchpress:
    Slashaar, snowsk8air2 and llibrm like this.
  17. Oct 12, 2021 at 6:13 PM
    #9777
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Aired down drive home from work. Steering is very light now with the pump. Still tough at a stop but did some testing and if I bump the idle up to 800-1000rpm it should make significant improvements with that so I may mess with the tune some. All in all very pleased thus far
  18. Oct 12, 2021 at 6:45 PM
    #9778
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    The pumps don’t really start making pressure until about 900rpm. You have an auto right? If so I’d assume you drive with two feet in the dirt so just make sure you keep the RPMs up especially when coming into corners hard on the brakes
    ovrlndkull likes this.
  19. Oct 12, 2021 at 6:58 PM
    #9779
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    Yep it’s an auto and I go back and forth with 2 foot driving. Need to get back into it and lock in the muscle memory and stick with it. Was more thinking for in the rocks though. Where I’m barely over idle and barely moving. Shit from today I’d say anything over 2mph and 1500rpm and the thing turns like a dream and I manually shift the trans for desert stuff and keep the revs from 2-4K 99% of the time. But could also 2 foot and bring the revs up in the rocks as well which I’m always driving 2 foot then.
  20. Oct 13, 2021 at 3:08 AM
    #9780
    906taco
    Cory
    08 Taco
    Could always raise your base idle to help in the rocks too.
