Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Mar 23, 2020 at 6:44 PM
    #1021
    WormSquirts
    WormSquirts Armageddon
    Braeden
    BC
    @81Trekker what are preliminary travel numbers looking like? Is it making use of that axle's extra articulation compared to a stock CV?
    mcharfauros likes this.
  2. Mar 23, 2020 at 6:51 PM
    #1022
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    The horizontal uniball limits the travel to 12.5” but because the CV allows for more drop out the travel range has been changed. The truck now sits right in the middle of the travel at ride height and bottoms out sooner so the 35’s don’t smash into the core support.
    We have been playing around with a vertical uniball and can easily get a few more inches of travel but the steering angle is reduced over stock. Still not sure on which one I like better. Just trying to get the lower arm pocket tuned in at the moment to clear the CV. The ground clearance gained with this setup is pretty wild
  3. Mar 23, 2020 at 7:00 PM
    #1023
    bhigbee
    bhigbee Well-Known Member
    Barney
    Hayden Id
    Wrecked 07 DCSB
    35s, flatbed, rhino liner paint, SOS front bumper, JD Fab lca pivot, JD Fab inner fenders and some other stuff.
    This just keeps getting better. Keep up the good work.
  4. Mar 23, 2020 at 7:41 PM
    #1024
    81Trekker
    La Jolla SD
    Thank you... I haven’t had any time to work on it in the last two weeks but I’m back on it
  5. Mar 23, 2020 at 10:53 PM
    #1025
    WormSquirts
    Braeden
    BC
    I'm definitely interested. I believe Jesse shipped my LCA mount setup the other day. Though our border is closed, and all of our businesses are shut down (including mine) due to this covid-19 thing, so I don't know when I'll be able to do it. I have the time now because our business is closed, but can't get the parts! augh!!
  6. Mar 24, 2020 at 5:58 AM
    #1026
    81Trekker
    La Jolla SD
    I can confirm that he shipped your parts... hopefully they make it through ASAP!
  7. Mar 24, 2020 at 7:49 AM
    #1027
    2012TacomaGuy
    2012TacomaGuy Well-Known Member
    Hayden
    Goodyear AZ
    2012 Pyrite Mica DCSB TRD Sport
    Empty wallet
    Wow. Amazing work, I just read through this entire thread. Definitely interested in getting this kit to run 35s without having to do much trimming. I already did a body CMC, flattened lunch weld, etc to clear 34s (285/75/17) lock to lock full cycle months ago. Don’t really want to cut more. Any issues running this kit with more preload on the front King coilovers do you think? I doubt it- wanting time keep the truck level with my rear suspension which is 3in lift in the front
  8. Mar 24, 2020 at 3:31 PM
    #1028
    81Trekker
    La Jolla SD
    Got one burned in today
  9. Mar 24, 2020 at 3:33 PM
    #1029
    81Trekker
    La Jolla SD
    Zero issues with preload... that’s all up to you. I run mine with as little as possible so the truck sits low
    2012TacomaGuy[QUOTED] likes this.
  10. Mar 24, 2020 at 3:46 PM
    #1030
    Arcticelf
    Arcticelf Well-Known Member
    Gladiator
    I'd vote for the horizontal uniball, doubly so if you're going to put it on a fabbed spindle.
    badkids, CGoss and WormSquirts like this.
  11. Mar 24, 2020 at 6:28 PM
    #1031
    81Trekker
    La Jolla SD
    Any other votes??
    badkids and Arcticelf[QUOTED] like this.
  12. Mar 24, 2020 at 6:54 PM
    #1032
    mcharfauros
    mcharfauros IG: mcharfauros
    MO
    2017 Black TRD OR DC
    Dumb Truck Thangs
    :eek:
  13. Mar 24, 2020 at 7:04 PM
    #1033
    81Trekker
    La Jolla SD
    And FYI that’s the bottom... the top will be shown off tomorrow :)
  14. Mar 24, 2020 at 7:42 PM
    #1034
    WormSquirts
    Braeden
    BC
    I would vote more travel as well. Paired with a tundra rack which gives limited steering angle anyway, and it will be perfect
    Arcticelf likes this.
  15. Mar 24, 2020 at 9:38 PM
    #1035
    ejwan
    ejwan Well-Known Member
    Finding this thread isn’t helpful! Gonna be on the wish list for one of these kits once I need to buy new tires.
  16. Mar 24, 2020 at 10:00 PM
    #1036
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Still haven’t seen the steering solution @81Trekker and jd fab have up their sleeves. Maybe it’s a better solution than the tundra rack and maintains steering angle?
  17. Mar 25, 2020 at 5:48 AM
    #1037
    Arcticelf
    Gladiator
    They were making threats about a swing arm setup, as I recall, so possible.
  18. Mar 25, 2020 at 6:28 AM
    #1038
    81Trekker
    La Jolla SD
    It’s going to be a custom slide rack
  19. Mar 25, 2020 at 3:56 PM
    #1039
    81Trekker
    La Jolla SD
  20. Mar 25, 2020 at 3:57 PM
    #1040
    81Trekker
    La Jolla SD
    Couple more
