Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Jan 15, 2022 at 3:10 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Sweet
  2. Jan 15, 2022 at 3:11 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    There’s more to it than that. A rusty pitted rack is only going to seal for so long. And that’s why I have a leak again. I’ve tried everything to keep the rust away and it just isn’t going to happen. Way too wet of an area.
  3. Jan 15, 2022 at 3:11 PM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Ah, ok. Well the tundy should fix both those issues due to size, but yeah I get the potential clearance issues with the 934s.
    What do you mean about the pivots being useless though?
  4. Jan 15, 2022 at 3:13 PM
    906taco
    Cory
    08 Taco
    If you push the LCA forward your tie rod is going to make love to the coil over. @EatSleepTacos said his hits and he’s stock pivots with the 2.25 kit.
  5. Jan 15, 2022 at 3:17 PM
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Tundra racks skip teeth too, they are not the end all solution, again just another bandaid
  6. Jan 15, 2022 at 3:40 PM
    bhigbee
    bhigbee Well-Known Member
    Barney
    Hayden Id
    Wrecked 07 DCSB
    35s, flatbed, rhino liner paint, SOS front bumper, JD Fab lca pivot, JD Fab inner fenders and some other stuff.
    @906taco would full hydro be a better solution for you? Like Robertocrister did on his build.
  7. Jan 15, 2022 at 3:45 PM
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    @81Trekker I’m planning to have a core support made up off of the JD inners. Would it be wise to locate the inner fenders while I still had an oem core support in place for ease of locating it? Or just chop it all off?
    Installing them with an oem core support makes me believe that it will save some headache lining up the fenders and hood. Once they’re tied to the cab, then chop the front portion off to beef it up.
  8. Jan 15, 2022 at 3:46 PM
    906taco
    Cory
    08 Taco
    I kinda have a peeve with hydro. We have it on our wrangler and it’s not something I would want to street drive. I really enjoy having that mechanical connection there.
  9. Jan 15, 2022 at 3:49 PM
    81Trekker
    La Jolla SD
    As long as you take a bunch of measurements prior to cutting everything apart you will be fine
  10. Jan 15, 2022 at 4:02 PM
    thegame
    thegame Well-Known Member
    Brian
    Folsom, CA
    Cement 2019 TRD OR
    Well it sounds like you are hard enough on equipment to run a trophy truck rack or cut all the IFS out and put a Dana 60 in there like others who wheel beyond the limits of IFS.
  11. Jan 15, 2022 at 4:14 PM
    906taco
    Cory
    08 Taco
    I’m not beyond the limits of IFS lol. It’s just one issue with the current setup otherwise it’s bullet proof.
    I think what I’m actually going to do is snag the front half of a frame from our local dealership when they do a swap. I’ll jig it up and figure out how to do a swing set setup. I’ll toss another new rack in to get me by until I have the swing set figured out.
  12. Jan 15, 2022 at 5:14 PM
    Suicyco
    Suicyco Well-Known Member
    14 ac 4x4
    Can the stock cvs handle the increased range of the 2.25 kit up until the upper binds? I know they must be run to get any decent travel if extended length are used prior to getting 8” shocks and that they are a extremely solid. Just wondering if the extra range of motion of the 934 is more geared towards the +4
  13. Jan 15, 2022 at 5:16 PM
    906taco
    Cory
    08 Taco
    934 is needed for 2.25 and 4 for full travel from my understanding.
    Suicyco[QUOTED] likes this.
  14. Jan 15, 2022 at 5:20 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Correct, at least with the 2.25 kit you need to strap it like 2” higher according to harry. I assume 4” is similar
  15. Jan 15, 2022 at 5:43 PM
    dcoursler
    dcoursler They call me Tater Salad
    Derrick
    Alabaster, AL
    2012 TRD Off Road
    Currie Rock Jock High Pinion 60, JD Fab EVERYTHING, Fox shocks, Radflo Shocks, Archive Garage all the other things, spinny thing on top of the motor
    Let’s make sure to make supercharger noises together at KOH
    tacotunner06 and Supra4x4 like this.
  16. Jan 15, 2022 at 8:08 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    I may not have a supercharger but can I join? Lol
    dcoursler[QUOTED] likes this.
  17. Jan 15, 2022 at 8:54 PM
    snowsk8air2
    snowsk8air2 how hard can it be?
    Flagstaff, AZ
    Supercharged TX Pro
    2011 S/C and basic mods
    Beyond the limits of ifs just hasn’t met the limits of budget. Lots of top ultra 4 teams running ifs and a few irs this year as well
  18. Jan 15, 2022 at 8:56 PM
    snowsk8air2
    Flagstaff, AZ
    Supercharged TX Pro
    I’ll be there. Apparently trying to meet up with a bunch of people as well as finding a jump good enough to jump over my buddy on his atc.
    No. Not unless your ps pump is noisy enough to sound like a supercharger.
  19. Jan 15, 2022 at 9:37 PM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    lol mine makes some whine. My dad likes to make fun of me and ask why my truck makes so little power with a supercharger…. Gets me sad every time. :pout:
    tacotunner06 likes this.
  20. Jan 16, 2022 at 3:10 AM
    dcoursler
    Derrick
    Alabaster, AL
    2012 TRD Off Road
    I wanna know that same thing actually…. I don’t feel like this thing is lacking in the power department. It makes reliable power that keeps partying all day long.
    You just need a smaller pulley that’s all
