Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Jan 26, 2022 at 5:00 PM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    I noticed that too. Looks like an extremely weak area.
    Slashaar likes this.
  2. Jan 26, 2022 at 8:14 PM
    Dayman Karate
    Dayman Karate Well-Known Member
    Clay
    Central Alabama
    JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
  3. Jan 27, 2022 at 7:15 AM
    lferrara
    lferrara Well-Known Member
    Luke
    Saint George, UT
    2014 DC TRD OR
    JD Fab Lower Pivots, JD Fab Slide Rack, JD Fab Inner Fenders, JD Fab UCA, DIrt King LCA, King Coilovers, 4.88 gears, 91 octane tune, etc...
    This might be a dumb question but has everyone had shifting issues whenever they upsized tires. I had 33’s now 35’s and sometimes when it shifts, more so when cold it feels like it’s slipping where it revs really quick before it shifts. Did it both on 33’s and 35’s. I’ve been good at maintaining the fluid so I know it’s not that. I figured since I am still on stock gears till I save up for the new gears. It probably is screwing with the shift points. Has everyone on here for ecu tunes with the bigger tires and new gear ratio?
  4. Jan 27, 2022 at 8:32 AM
    906taco
    Cory
    08 Taco
    Sounds like you need gears. Probably gear searching.
  5. Jan 27, 2022 at 8:42 AM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    Yeah that’s what I figured. I’ll see how it is after I put the new gears in. Just curious if anyone else has experienced the same thing.
  6. Jan 27, 2022 at 8:57 AM
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    I had some odd issues a couple times before I flushed out my atf. I don’t know if it was a fluke but It stopped happening but I wasn’t sure if it was from the fluid flush. I ran stock gears with 285s and 315s with no real issue though.
    Does the rev happen in lower gears? When I had the few odd moments, they were 1-2 and 2-3 shifts. Almost like if you rev hung and dumped the clutch on a manual between shifts.
  7. Jan 27, 2022 at 8:59 AM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Yes actually. I just had my ECU flashed by @JustDSM. On 35's and 4:56 and was experiencing a similar complaint. So far I'm a fan but it's only been a couple of days.
    Torspd and lferrara[QUOTED] like this.
  8. Jan 27, 2022 at 9:08 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    Just looking for tires for the first time since last year and damn they are scarce? Whats the deal?
  9. Jan 27, 2022 at 9:11 AM
    desertjunkie760
    Shane
    Check My Sig.
    Supply chain shortages on raw materials. Just like everything else. Where have you been? o_O
    RockiesTaco, bhigbee and Slashaar like this.
  10. Jan 27, 2022 at 9:11 AM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    Under a rock duh
  11. Jan 27, 2022 at 9:14 AM
    906taco
    Cory
    08 Taco
    I mean it is entirely possible the trans is hurt too. Beadlocks aren’t light nor are 35’s. That trans has been working like a dog to keep up and that’s not necessarily good.
  12. Jan 27, 2022 at 9:16 AM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    Thanks guys. It’s typically when it’s cold from 3rd to 4th when I am easy on the throttle. If I am hard on the throttle or after it warms up from driving around a little it doesn’t do it. If I shift manually and don’t put it in overdrive it doesn’t do it. So I feel like it’s something weird with the shift points. I’ll have to change the gears first and see how it reacts. Then if I still have issues I will contact @JustDSM
  13. Jan 27, 2022 at 9:17 AM
    dk_crew
    dk_crew Well-Known Member
    Dave
    Austin, TX
    2005 Tacoma 4x4
    I just went to 35s (315s) from 265s about 2 weeks ago and have not experienced the shifting issues. So maybe try the ATF as mentioned above? I do have gears on the way (YEAH!!) so looking forward to getting some pep back, and could probably use some better brakes, but overall the trans/shifting seemed pretty normal. I finally hit the dirt Saturday so I'll see what else I need to cut/hammer ...
  14. Jan 27, 2022 at 9:20 AM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    Yeah that’s possible. I feel like if was that though it would happen more throughout driving and not be such a specific issue you know?
  15. Jan 27, 2022 at 9:30 AM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    I have flushed my transmission twice, once when I bought it at 70k and recently at 105k after experiencing the issue. I do my drain and fills every 15k with my diffs. Probably overkill but I’m a believer overkill for maintenance. I have pulled quite a bit of trailers on my 33’s. Once across the country and back. But if the transmission took a dump on me I’d be pretty disappointed at 105k with the quality that toyota supposedly built a reputation for.
  16. Jan 27, 2022 at 9:36 AM
    906taco
    Cory
    08 Taco
    I don’t understand the whole big tires and no gears thing. Honestly mine being a 6spd should give it a solid edge over an auto. I HATED how sluggish it was even on 33’s and stock gears. Gears do so damn much. From making the truck work less, to better off-road abilities to better fuel economy. Should be step number one before tires/wheels.
  17. Jan 27, 2022 at 9:39 AM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    Yeah I’ll own that mistake. It does drive pretty terrible with 35’s on stock gears. Gears are definitely on my urgent list
  18. Jan 27, 2022 at 9:48 AM
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    Just put the shifter in 4th and leave it there. When you put it in drive the trans hunts way more trying to optimize MPG
  19. Jan 27, 2022 at 10:38 AM
    Dayman Karate
    Clay
    Central Alabama
    JKU Rubicon
    After driving my f150 with normal tires and stock gearing it became immediately clear just how dumb the taco trans is at shifting with 35’s and 4.88’s. It’s probably been that way it’s whole life but I haven’t had stock size tires in about ten years so who knows. Gears are a must, but shifting at higher rpm would be nice, too. I like being able to do that in the f150 with the sport/haul mode.
  20. Jan 27, 2022 at 11:03 AM
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    Life is fine on 35s and 4.88s. The transmission/ECU needs to be tuned. Bully dog has a decent tune for trans (came with the supercharger) and I now run a custom tune which is even better from @JustDSM. Shifts are quicker, holds gears and does not hunt.
