Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Jan 27, 2022 at 11:03 AM
    RonRon23
    RonRon23 Well-Known Member
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Front suspension: Work in progress JD Fab +4 LT, LCA pivot kit, steering slide rack, 934CVs Rear suspension: Archive Garage shock relocation and SUA Conversion,King 14x2.5 shocks, King 2x2 hydro bumps, FN wheels 5 stars, sliders
    I gotta drain and fill my break in fluid. 4.88 so far feels much better. I averaged 16-17ish mpg over the break in. The boost in mpg was definitely a up side.
    906taco[QUOTED] likes this.
  2. Jan 27, 2022 at 11:10 AM
    DesertRatliff
    DesertRatliff Well-Known Member
    Mt. Hood, OR
    Mas Tacos Por Favor
    From my understanding, your problem is called "shift flare" and is entirely normal on the A750 auto trans in our trucks...to a point. When you've altered the OEM parameters, you gotta make the proper adjustments. A tranny tune from Justin (justDSM) is a great starting point but there's every reason in the world to get those 3.73 gears outta there on 35's!
    lferrara[QUOTED] likes this.
  3. Jan 27, 2022 at 11:10 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    No doubt! When I keep mine around 60mph (speed limit here is 55) I’ll pull 17 on 37’s. Not like MPG’s should be a huge concern with these things but it is nice.
  4. Jan 27, 2022 at 11:20 AM
    a2lowvw
    a2lowvw Well-Known Member
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I think it's less about mpg but miles per tank, if I can go farther on a single fill up it's a win.
  5. Jan 27, 2022 at 11:25 AM
    906taco
    Cory
    08 Taco
    When I was on 33’s and stock gearing I usually pulled 240-250 on a tank. I’ve seen 280 on an all highway trip with the 37’s minding my RPM’s. That’s filling up before the light.
    a2lowvw[QUOTED] likes this.
  6. Jan 27, 2022 at 12:25 PM
    lferrara
    lferrara Well-Known Member
    Luke
    Saint George, UT
    2014 DC TRD OR
    JD Fab Lower Pivots, JD Fab Slide Rack, JD Fab Inner Fenders, JD Fab UCA, DIrt King LCA, King Coilovers, 4.88 gears, 91 octane tune, etc...
    Yeah speed limits here in Utah are 80 and cars are going like 90. I’m doing 70 with the semi’s thinking like damn I feel slow.
  7. Jan 27, 2022 at 12:34 PM
    a2lowvw
    Justin
    Bothell, Wa
    2019 DCSB Limited
    Stuff and things
    I wish I could get that on my truck. I just did 4.56's on 33's and typically cruise a 2k going 70 on the way to and from work. I'm lucky to get 14 mpg with minimal extra weight.
  8. Jan 27, 2022 at 12:42 PM
    RonRon23
    Ronnie
    Buena Park
    2013 MGM DCLB 4x4
    Lol I ended up pulling one of those off the grid rental tear drop trailers back to SoCal from one of the Moab trips through TW. Friend was having truck issues and didn’t want late fees. So odd to see semi trucks pass me at 80 while I’m trying to lug up a grade.
  9. Jan 27, 2022 at 1:26 PM
    906taco
    Cory
    08 Taco
    A bunch of stuff showed up today! Getting closer!
    Slashaar likes this.
  10. Jan 27, 2022 at 1:53 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    Yeah, I'm doing gears before big tires. Problem is I'm on the fence between Harrop E-Locker or ARB Air locker. If I go air locker its gonna be run off of a ViAir 400P Auto.
  11. Jan 27, 2022 at 2:00 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    I am going Harrop. No air lines or compressor to deal with. Then I will carry CO2. If I do add a compressor it would be for back up and Mt bike tires.
    Slashaar[QUOTED] likes this.
  12. Jan 27, 2022 at 2:02 PM
    Slashaar
    Josh
    Kansas City, MO
    Yeah its a price difference of like $200 so its a really easy to go either way.
  13. Jan 27, 2022 at 2:10 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    If I were to do it over again I would do e lockers because the air are prone to leaking internally (and at the lines too of course).
    Slashaar[QUOTED] and RoaminRoman like this.
  14. Jan 27, 2022 at 2:17 PM
    Dayman Karate
    Dayman Karate Ruffling feathers and turning eagles into vultures
    Clay
    Central Alabama
    2001 4Runner, JKU Rubicon
    https://www.tacomaworld.com/threads/daymans-karate-class-but-you-wont-learn-nothin-4-link-lt-and-previous-iterations.755134/
    I have the worst time getting my factory rear to disengage after a steep climb. Front is way quicker, but it likes to puke and I don’t care enough to drain whatever ECGS told me to drain.
  15. Jan 27, 2022 at 2:19 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    The harrop e locker is different style than oem second gen which have engagement issues. It’s more like the third gen, which from what I understand engages pretty easily.
  16. Jan 27, 2022 at 2:21 PM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    E-lockers have weaker lock up mechanism, the rolling to engage or disengage reminds me of the stupid 90s auto locking hubs. That stuff is old. Jeep keeps mechanical locker in the front and spool in the rear. Taco will get either a 40 spline mechanical locker in the rear or an ARB comp 40 spline and keeping the ARB.
    Elockers can still fail internally just like the ARB bad thing is the repair isn't a $5 O-ring.
    Brian422 and Taco-Obsessed like this.
  17. Jan 27, 2022 at 2:36 PM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    ARB were designed to lock up in the strongest position possible. They are very course tooth while others are fine tooth. ARB did have issues with the seals a while back but from what ive heard that has been fixed. Iv not once had and issue with either of my lockers. Id run ARB's now until the day i die. Id probably change out a factory locker in another truck for the air locker its just so easy and can be turned on independently of one another and you don't have to be in 4wd to lock it up.
  18. Jan 27, 2022 at 2:46 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    Pretty much everyone I know with an air locker has one that leaks to some degree. My compressor has to cycle every 30 seconds or so to maintain pressure, and I know for a fact it’s an internal leak. Doesn’t cause it to unlock or anything but is a mild nuisance that I hope doesn’t get worse.
    BassAckwards likes this.
  19. Jan 27, 2022 at 2:52 PM
    Brian422
    Brian
    Birmingham, AL
    Not Stock
    That's really strange, I've never had an issue with either of mine. Might be a fault in the install then. Not that the install was bad just that maybe something was slightly so off that cause it to leak inside. If its not bad and isn't getting worse i wouldn't be worried. But I've never had and issue like that so i really cant speak to it.
    EatSleepTacos[QUOTED] likes this.
  20. Jan 27, 2022 at 2:52 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    They are finicky for install which is where I think most leaks derive from is the seal gets pinched or rolled, or something to damage it ever so slightly causing the leak. From what I've seen it won't get worse. I've wheeled with guys whose ARBs had been doing that for years. It does get annoying.
