Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Feb 2, 2022 at 3:41 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    proper annealing methods in effect.
  2. Feb 2, 2022 at 8:49 PM
    DocME
    DocME Well-Known Member
    California
    '07 FJ Cruiser
    TRD S/C, UCON, 61# inj, 2.5 pulley, 7th inj, Roostfactor Y Pipe, URD exhaust, WAT Nomad Valve body, Dana 60, DK LT, JD FAB LCA mounts, custom roof rack...and way too many others.
    Some people like big rear ends, others go for big racks. Who’s to say you can’t have both. A3A5D32B-CDA3-4E81-BB26-CF0DC79C0E39.jpg
  3. Feb 2, 2022 at 9:09 PM
    Torspd
    Torspd Tor-nication
    Tor
    The Great America!
    MMVI 4.4L 4x4 Access Cab
    Well played.
    Mmm. Whistlepig. :cheers:
    Slashaar, llibrm and DocME like this.
  4. Feb 3, 2022 at 7:22 AM
    racebug68
    racebug68 Well-Known Member
    Travis
    Chandler, AZ
    05 DCLB 4x4 TRD SPORT SILVER
    I can't leave anything well enough alone
    Care to elaborate on that rack any? I haven't seen anything like what appears to be an offset aluminum bushing on the drivers side? TIA
  5. Feb 3, 2022 at 7:45 AM
    DocME
    California
    '07 FJ Cruiser
    I had started down this road a while back before Harry confirmed that the slide rack mod would work for the FJ platform. In truth, I would have gladly gone with the Tacoma and slide rack combo. However I had already purchased a Land Cruiser 200 rack and an offset bush from Iconic. The rack is the same one than Marlin fell back on after they abandoned their own design. It’s massive compared to the stock rack. You use the offset bushing to locate the driver’s side mount at the differential mount bolt and add a frame mount on the passengers side. The rack is wider between the mounting points, which a set of clevis ends mitigates some of that extra width. I don’t expect there to be too much additional bump steer with my long travel setup, but if you have stock spindles the extra width something to be aware of.
    I worked with Harry on a custom adapter to the -6an pressure line. Actually pretty damn awesome how quickly he brought it together. Ordered the rack on a Thursday, he asked for my stock fittings which I shipped out the next day and within a week he had me all setup. Big thanks to Harry and team, it’s coming together quick.
    While this will be way strong than a stock rack alone, I doubt this solution is any stronger than the slide rack. It will allow for boots on the rack for those concerned about get dirt under their fingernails. Also for anyone that’s gone to the LC200 rack and exceptionally oversized tires….you can now have a power steering pump and cooler solution that will help you steer those massive tires.
    Torspd and llibrm like this.
  6. Feb 3, 2022 at 8:20 AM
    Wishbone Runner
    Wishbone Runner Because 4R
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Nice, I plan to pair my tundra rack with the Howe pump at some point, should be a solid setup. Is there any bushing on that bushing, or is it solid aluminum?
  7. Feb 3, 2022 at 8:43 AM
    DocME
    California
    '07 FJ Cruiser
    It’s currently solid aluminum, which I share your concern over one being flexible and the other being rigid. The offset hole is about as close as you can get it to the edge of the barrel. Not much more space in there for anything else.
  8. Feb 3, 2022 at 9:00 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Gotcha, I guess I don't understand why the need for the offset bushing as you are fabing the location for the passenger side mount anyway. From what I measured on mine, it was only off by 1/4" to the driver side, and the rack has more than enough stroke to compensate for this by centering the rack gear instead of the rack body. I ended up chopping out the entire crossmember and centered it on the frame, and lowered it to the stock height, but I cut the rack gear to stock width so do not have as much stroke on the gear to work with.
  9. Feb 3, 2022 at 9:11 AM
    DocME
    California
    '07 FJ Cruiser
    I believe it’s due to a couple of reasons. First centering the rack in the vehicle, then providing more clearance for the sector shaft connection, and the passengers side bolt head head placement is tight (as I write this I’m realizing the offset bushings make this tighter.) My buddy made me some sweet recessed frame support brackets that the bolt heads will recess into, so that last one may not be an issue for me. I saw your pictures of your cross member. Looks like there’s a lot of space when the diff bracket is out. Maybe that’s not as big of issue as I thought?
  10. Feb 3, 2022 at 9:34 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    It’s tight, but it fits, about 1/4” clearance from the pass rack bolt to to the diff mount, the two bolts are about 2” apart and the diff bolt is slightly offset from center to the rear. I’ll be chopping out the frame for the sector shaft clearance, and probably doing a new driver motor mount that will be angled.
  11. Feb 3, 2022 at 10:19 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    Is the duct tape a required element for this installation ?
  12. Feb 3, 2022 at 10:20 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    Absolutely, no custom work is completed without a little duct tape.
    whatstcp, Slashaar and dk_crew like this.
  13. Feb 3, 2022 at 5:47 PM
    xweslingx
    xweslingx Well-Known Member
    Wes
    Durham, NC
    09DCSB locked and armored
    Just gussets... everywhere
    This makes not wanna be cheap and go 14 bolt or sterling. Watching to see finished product.
    Slashaar and ovrlndkull like this.
  14. Feb 6, 2022 at 7:46 AM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    Well I think I gotta give @81Trekker some props on building some stout lca mounts. Hit a g out at about 25 and this seems to be the worst of the damage. Pretty sure if I was still on factory mounts I would have ripped the forward mount off the frame.
    Slashaar and desertjunkie760 like this.
  15. Feb 6, 2022 at 8:13 AM
    Wishbone Runner
    James
    CO
    04 SR5 4Runner
    King/Dirt King
    did you rip one of the tabs off?
    Slashaar likes this.
  16. Feb 6, 2022 at 8:23 AM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Looks like one of the alignment tabs is sheared off. Which definitively puts it into a hard hit.
  17. Feb 6, 2022 at 8:31 AM
    81Trekker
    81Trekker [OP] Well-Known Member
    La Jolla SD
    81 Trekker and 2015 CCSB Tacoma
    Too many to remember
    How come you didn’t have the alignment cm bolted in place?
  18. Feb 6, 2022 at 10:02 AM
    tacotunner06
    Edmonds, Washington
    2006 White Tacoma
    I wish I had a good reason….lol.. I had them rolled all the way in as well so it pulled it all the way out and pushed it past the tab. Not sure if the backside is also broken, will have to check when I get back home. But other than the tab itself it doesn’t look any worse for wear.
  19. Feb 6, 2022 at 10:14 AM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    There's needle bearings inside this stub shaft from the ADD to the diff.. I rebuilt mine not too long ago because of a bad pinion bearing on the flange side. I also wanted to open up the ADD to inspect everything after shearing a front Currie Interprises extended axle. The clamshells aren't too hard to do..
    Rebuilt and resealed the ADD stuff too.. I also soldered terminals at the motor to prevent corrosion which is a common problem for the East Coast dudes..
    Also polished the shift fork , no more high/low spots..
    Torspd, RockiesTaco, Slashaar and 8 others like this.
  20. Feb 6, 2022 at 10:36 AM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Love the "Covid19 Edition" Gonna look at that in 5yrs and laugh.
