Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Feb 7, 2022 at 1:31 PM
    Slashaar
    Slashaar Trail Limo Supreme & Certified Hole Massager
    Josh
    Kansas City, MO
    2015 Tacoma TRD-Sport DC LB
    Coastal HC Front, 6112s+650lb King Coils, JD 62 Swap + 14" Fox 2.0s
    I like spicy brown mustard and diced jalapenos. :notsure:
    Dayman Karate likes this.
  2. Feb 7, 2022 at 1:42 PM
    Airdog
    Airdog did your Mom
    Tom
    SoCal
    https://www.tacomaworld.com/threads/airdogs-2012-prerunner-access-cab-slow-build.264263/
    The RCLT thread isn’t enough???
  3. Feb 7, 2022 at 2:03 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    Pineapple is acceptable on pizza. :crapstorm:
  4. Feb 7, 2022 at 2:28 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    My kid puts ketchup on rice. I dunno. Sometimes I suspect. . .
  5. Feb 7, 2022 at 2:30 PM
    wrmathis
    wrmathis Dark Lord of the Sith
    Bonaire, GA
    2006 Tacoma TRD OR 4x4
    parts and stuff
    smart kid :anonymous:
  6. Feb 7, 2022 at 2:31 PM
    scootter82
    scootter82 Well-Known Member
    Aurora, CO
    Ok now you're getting a little far fetched
  7. Feb 7, 2022 at 2:32 PM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Yes it is.
  8. Feb 7, 2022 at 5:03 PM
    Calamity_taco
    Calamity_taco your friendly neighborhood weeb :3
    Jacob
    I have no idea. send help!
    2017 f-150, 23 Klx300R
    just a couple of things tbh
  9. Feb 7, 2022 at 5:42 PM
    desertjunkie760
    Shane
    Check My Sig.
    Ive installed 4 of them already… I don’t need advice, I need the kit itself.
    It’s a $130 kit. You can’t expect but so much.
    GlitterGulch and Slashaar like this.
  10. Feb 7, 2022 at 6:09 PM
    Calamity_taco
    Jacob
    i guess so i was just kinda disappointed the rears were so off and had gaps oh well
  11. Feb 7, 2022 at 6:18 PM
    Slashaar
    Josh
    Kansas City, MO
    I have a set sitting in my garage but I haven't decided if i want to save money and just use them or spend money and do the JD fab LCA pivots.... I know the latter would be the best option, but money is tight and I already have bent tabs.
    ovrlndkull likes this.
  12. Feb 7, 2022 at 6:22 PM
    Calamity_taco
    Jacob
    if you have it i would say use it and hope yours isnt as off as mine is lol
    Slashaar[QUOTED] likes this.
  13. Feb 7, 2022 at 6:24 PM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Mine were toasted. Even with the tabs welded. Plus my LCA I am pretty sure we’re tweaked as well
    Slashaar likes this.
  14. Feb 7, 2022 at 10:05 PM
    desertjunkie760
    Shane
    Check My Sig.
    IMO, the MC kit is pretty well designed for its intended purpose. Most people will never wheel hard enough to damage a truck with a properly installed MC kit and be able to drive away. It’s kind of a bitch to install though.
    Obviously, the JD relocation kit is the pinnacle as far as design and strength goes but with that comes more time & cost. So if you’re not appealed to the JD kit for another reason, I.E the additional caster for bigger tires, then the MC kit isn’t a horrible second option.
    That said, make sure you are confident in your decision because once you hot glue gun the MC kit on it’s not coming back off without significant amounts of work.
  15. Feb 8, 2022 at 6:44 AM
    Evenflow
    Evenflow Well-Known Member
    San Diego, CA
    06' DCSB 4x4
    Yes
    damn ! what hot glue gun are you using ?
  16. Feb 8, 2022 at 9:01 AM
    RokMgmt
    RokMgmt Well-Known Member
    Alex
    4th Gen 4Runner
    A few mods
    I'm pulling 12" of travel but I tubbed the crap out of my forward inner fender area and cut out the factory bump stop to run 2" stroke hydros. I have BFG 37s (so 36s), and I can probably run a true 38" tire without moving the battery or tubbing the firewall. Group 35 battery. I could get that travel number to 12.75" by dropping the diff 1" but that's not worth it to me. The RCVs bind with ~1/2" of shock shaft remaining so I strapped it 1/4" above that. I guess 934s would also get me that extra bit of travel. From ride height I have 7" of uptravel and 5" of downtravel, which I've found to be a good balance for rocks and desert. I talked with Jessie a few times before I went with RCLT. I really liked their subframe/LCA mount kit but was told that it wouldn't work on my 4th gen. I just posted a GoPro video on my IG ripping from JV to Cougar Buttes leaving KOH last weekend. It shows the front end putting in the work. I'm amazed with how fun whoops are now compared to my BS stock+ Icon ext travel setup I ran for years. I hammered the truck for 4 days straight at KOH, on the rocks and over whoops, and it drove straight on the highway afterward.
  17. Feb 8, 2022 at 9:16 AM
    desertjunkie760
    Shane
    Check My Sig.
    What's your IG?
    RokMgmt[QUOTED] likes this.
  18. Feb 8, 2022 at 9:20 AM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
  19. Feb 8, 2022 at 9:53 AM
    RokMgmt
    Alex
    4th Gen 4Runner
    A few mods
    EatSleepTacos[QUOTED] likes this.
  20. Feb 8, 2022 at 11:54 AM
    sicki
    sicki Well-Known Member
    @81Trekker ... any cool photos of my truck?
    Im so stoked to be getting the LCA Pivots, upright gussets, heim steering, and the +4" LT installed down at the JD Shop.
    Gears and E locker install at the end of February.
    and as soon as I get it back and dial in the front ADV Fiberglass fit and paint, Ill be scheduling a rear SUA install at JD.
    **Anyone wanna buy Camburg Billet UCAs and Fox Ext travel DSC's?
