Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Feb 15, 2022 at 5:44 PM
    Sixthelement
    Sixthelement Ran over a Yeti once, Texas, never again
    Flagstaff
    24 F150
    Fox 2.0
    Fucking done with Radflo.
    Who has Kings/Fox ready to go for JD +2k kit?
  2. Feb 16, 2022 at 4:12 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    Lol, probably nobody.
  3. Feb 16, 2022 at 6:44 AM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    I know. Every issue that comes up centers around the fact that they couldn’t follow plain instructions. Oh and they have built em before and since for YotaMafia. Several sets too.
    Just tired at this point.
  4. Feb 16, 2022 at 6:47 AM
    Brian422
    Brian422 I fell into the pit that is TW
    Brian
    Birmingham, AL
    2012 DBCSB F/R Locked, 35's ,Long travel, 23 Tundra 4x4 limited
    Not Stock
    They were valved wrong? or what?
  5. Feb 16, 2022 at 6:48 AM
    906taco
    Cory
    08 Taco
    What's the issue you have going on?
    Brian422 likes this.
  6. Feb 16, 2022 at 6:53 AM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    Wrong Misalignment spacers that took over a week for correct ones to be shipped
    1. Wrong misalignment spacers that took over a week for the correct ones to show up. So we could attempt to cycle at least.
    2. Wrong resi hose lengths and fittings where they’re supposed to be and clocked for clearance
    3. Wrong lower rod end and spring cup causing steering interference and binding
    So currently truck is basically is undrivable again because the tie rods hit the spring cups and springs. Of which we don’t have the tools or means to change the rod end. Which upon itself will change the end to end lengths.
  7. Feb 16, 2022 at 6:58 AM
    906taco
    Cory
    08 Taco
    Yeah, I would probably be pretty wild myself. JD shows stuff in stock but I'm not sure how accurate it is. Maybe @81Trekker could confirm or deny. Hell even the rear free bleeds show in stock.
  8. Feb 16, 2022 at 7:03 AM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    He told me yesterday 9months. If by chance he does have in stock. Um yea I’ll snatch it up.
  9. Feb 16, 2022 at 7:07 AM
    906taco
    Cory
    08 Taco
    Ouch. The wait definitely blows. I want to start on mine, but that would mean taking a gamble that everything shows up when its supposed to. Been hearing some people got stuff way early and others are beyond the original lead time.
  10. Feb 16, 2022 at 7:27 AM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    I mentioned to Radlfo that it seems my order was rushed. They said oh the original order was Aug 27, 2021. Yea and I didn’t get a call about shipping them until 3 days before Christmas. Which they still didn’t show up until Jan 7 2022
    RETR0spec and Slashaar like this.
  11. Feb 16, 2022 at 4:13 PM
    RETR0spec
    RETR0spec Well-Known Member
    Sacramento, CA
    JDFab +4 LT
    I feel your pain. Ordered my shocks from Locked on 8/12/21 with an estimated 12 week lead time. Didn’t receive any updates nor shipping info. Every time I ask I get “it’ll ship at the end of the month” 4 months in a row. I gave up and cancelled.
    My JD +4 kit will sit in the box I guess until I can find something that works or until these kings show up.
    Slashaar and ovrlndkull like this.
  12. Feb 16, 2022 at 6:42 PM
    Sixthelement
    Flagstaff
    24 F150
    Fox 2.0
    So now the question is King or Fox with DSC?
  13. Feb 16, 2022 at 7:45 PM
    MonkeyProof
    MonkeyProof Power Top
    SoCal- SGV
    Are you using an APP and bluetooth dongle or Scan Gauge to monitor your temps? If you are not, then there's a good possibilty that you are running hotter than you think you are. I over heated twice in the past, the second time was recent. The stock temp gauge doesn't move until temps go past 230. And when it does actually move, it doesnt really move enough to indicated an over heating condition..in my experiences.
    Right now i'm experiencing coolant system issues that suggests a restricted radiator. The worst case is maybe some weird and very slow head gasket leak that is causing an over pressure of the coolant system. This morning I ordered a Mishimoto two row aluminum radiator and some other goodies from them. I'll be installing a mechanical gauge for the coolant and trans temps along with a trans cooler and e-fan on the cooler. I'm also just about done with a spreadsheet of stuffs needed for a PWM electric fan and controller for the radiator making it a closed system. The trans temp gauge will control the relay for the cooler fan.
    If anyone here knows off hand what size fittings that are on the transmission side cooler lines, that's where ideally I would like to install a manifold for the temp sensor probe..that would be great!!!
    This is the trans cooler and fan that will be installed.. unless someone here can suggest a better option
    https://www.amazon.com/Hayden-Autom...33d959c98c1&pd_rd_wg=7y40o&pd_rd_i=B000C3BBKS
    https://www.amazon.com/Maradyne-M103K-Champion-Reversible-S-Blade/dp/B005R52JKW
  14. Feb 16, 2022 at 8:01 PM
    desertjunkie760
    desertjunkie760 @DesertJunkie760 (IG)
    Shane
    2011 MGM DCSB TRD Sport 4x4
    Check My Sig.
    I have an UltraGuage installed to monitor temps, mainly tranny but I have it setup for engine temp too.
    I’m sure the factory setup isn’t ideal to run in mid summer but I don’t recall a time of being concerned about engine temps. A lot of it is application though, and I’m not trying to go anywhere fast so that could be the main difference.
    I have, however, experienced and been concerned about high tranny temps and will absolutely be looking into solutions. At the end of the day, if you have the expendable cash to go all aluminum they are sexy. Just seems costly to do for minimal return if it’s not a consistent issue.
  15. Feb 16, 2022 at 8:50 PM
    kasnerd
    kasnerd candied bacon
    SoCal Yokel
    '14 SC LT Mall Runner
    Mods? Yes, oh yes..
    Derale Performance
    https://derale.com/
    MonkeyProof[QUOTED] likes this.
  16. Feb 16, 2022 at 8:53 PM
    tacotunner06
    tacotunner06 Well-Known Member
    Edmonds, Washington
    2006 White Tacoma
    LS Swap with RSG Tranzilla, Custom hi clearance front bumper, Relentless: Slider's, bed rails, rear bumper, Prinsu with 40" BD s8. Dirt Designs 3.5 LT. Archive Garage rear towers/shackle flip/SUA. King Air bumps. King LT Coilovers in front. King 12x2.5 in rear. ARB rear air locker and twin compressor. SCS f5's with 33" Ridge Grapplers. 20" S8 mounted in bumper, squadron sport fog lights, squadron pro backup lights, LP6's bumper mounted.
    You ever test fit those fenders?
  17. Feb 16, 2022 at 8:58 PM
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    they fit like a dream... behind my garage. :rofl:I've been working like mad lately. The front will come apart here soon and then fenders go on.
  18. Feb 16, 2022 at 9:23 PM
    Suicyco
    Suicyco Well-Known Member
    14 ac 4x4
    2” mcneil? Or do you have something else going
  19. Feb 16, 2022 at 9:37 PM
    kasnerd
    SoCal Yokel
    Mods? Yes, oh yes..
    Yep, will run them for now. Thrash and trash, which is where they were headed without me, so game on! Will replace with adv glass later on. The OEMs I'll keep because Harry's handiwork looks sharp and want to recreate that look again. Feel really bad for wrecking them but shit happens and had the front driver get smashed and the passenger side already had some broken tabs.
    tacotunner06 and Suicyco[QUOTED] like this.
  20. Feb 16, 2022 at 9:39 PM
    01 dhrracer
    01 dhrracer Well-Known Member
    Palm Desert/Bermuda Dunes
    Still Shopping
    We need pics. Maybe updates on IG too.
    kasnerd[QUOTED] and Suicyco like this.
