Fitting 35’s with minimal trimming NOW ADDING LONG TRAVEL AND 934 CV’s
Discussion in '2nd Gen. Builds (2005-2015)' started by 81Trekker, Aug 25, 2019.
  1. Feb 20, 2022 at 11:04 AM
    lferrara
    lferrara Well-Known Member
    Luke
    Saint George, UT
    2014 DC TRD OR
    JD Fab Lower Pivots, JD Fab Slide Rack, JD Fab Inner Fenders, JD Fab UCA, DIrt King LCA, King Coilovers, 4.88 gears, 91 octane tune, etc...
    Yeah I think I’m going to do 1/0 for the starter cable and 4 guage for grounds. I don’t think you’d get any voltage drop at only 15 ft though
  2. Feb 20, 2022 at 11:18 AM
    Supra4x4
    Supra4x4 IG: hash_brown55
    Andrew
    SoCal
    MGM 2011 DCLB 4X4 Long Travel'd
    Whole lotta stuff
    Research first. Last thing you want is a vehicle fire.
    If I recall, you have to upsize due to resistance from added length. Otherwise the wires get too hot because resistance = heat. Any electricians in here who could elaborate better?
  3. Feb 20, 2022 at 11:27 AM
    Supra4x4
    Andrew
    SoCal
    Whole lotta stuff
    Ahh, well there ya go. I just know many people have had to upsize the gauge due to heat. Idk if it’s because we only run 12 volts or what. But yeah nobody wants to burn up their rig.
  4. Feb 20, 2022 at 11:36 AM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    Here is the calculation for single phase circuits which should include dc. But yes you are correct it’s due to the resistance of the wire.
    (2(12.9) x 15 x current)/ 10560.
    I’d have to know the actual current draw to calculate which I can measure if my truck wasn’t torn apart. But that’s the calculation in case anyones curious.
    ovrlndkull likes this.
  5. Feb 20, 2022 at 11:39 AM
    906taco
    906taco Well-Known Member
    Cory
    08 Taco
    You 100% need to upsize everything if you’re running it back. No questions asked. If you have a winch that will also need to be upsized. Automotive wiring is substantially different than home/commercial.
  6. Feb 20, 2022 at 11:42 AM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    Ya to be safe I will. 2 gauge to 1/0 should be plenty so that’s what I’m doing.
  7. Feb 20, 2022 at 11:45 AM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    I mean not really though, it’s just a dc circuit vs ac. Which is different. The principles of electricity don’t change though.
  8. Feb 20, 2022 at 11:56 AM
    ovrlndkull
    ovrlndkull STUKASFK - HC4LIFE
    Skip
    Burlington, NC
    2005 DCLB Silver
    63s, XD Machete, Beat not Babied
    I'll see if I can't find it but there's a pretty simple chart to figure size wire to length for DC. It's not as scientific as you're getting there.
    For your grounds just make better factory grounds to the chassis, eng., and body and then run one at your battery to the chassis, and if you really want to the cab as well, that'll be plenty. Doing the ground that way you can keep the wire smaller like you're thinking. For the power just put a junction block on the inner fender and run the power wire from the battery to that junction block and attach what would be the OE battery cables right to that. I'd run a big ~200A fuse on the main power wire coming off the batt. to that junction block just in case.
  9. Feb 20, 2022 at 11:59 AM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Science is hard. Don't go dropping Ohms law in here you might let the magic smoke out of some.
    lferrara[QUOTED] likes this.
  10. Feb 20, 2022 at 12:18 PM
    lferrara
    Luke
    Saint George, UT
    2014 DC TRD OR
    Yeah it’s probably not a big deal. Just oversize a couple sizes to be safe and make good grounds and hopefully my truck doesn’t start on fire.
  11. Feb 20, 2022 at 12:22 PM
    906taco
    Cory
    08 Taco
    If it’s going in the cab it should also be a sealed battery.
    Slashaar likes this.
  12. Feb 20, 2022 at 12:28 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    FIFY
    Slashaar and CGoss like this.
  13. Feb 20, 2022 at 1:08 PM
    906taco
    Cory
    08 Taco
    Unsure of what you really fixed?
  14. Feb 20, 2022 at 1:48 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    Terminology.
  15. Feb 20, 2022 at 1:53 PM
    906taco
    Cory
    08 Taco
    I sure would hope anybody that knows even a little bit about cars knows what a sealed battery is. Because, that is after all what they are known as by many.
  16. Feb 20, 2022 at 2:05 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    But technically you do not have to have a sealed battery to have one in the passenger compartment, which is what you were implying. Certainly anyone in the automotive industry would understand that especially looking at pretty most european cars.
  17. Feb 20, 2022 at 2:12 PM
    906taco
    Cory
    08 Taco
    Main reason I didn’t mention a box is because by the time you buy a nice sealed box, you’re nearly halfway to a good AGM. So at that point, why wouldn’t you upgrade? I guess I just don’t see the reason to pick apart what I said unless you’re just trying to come off that way.
  18. Feb 20, 2022 at 2:33 PM
    EatSleepTacos
    Randy
    West Valley, AZ
    2017 4Runner
    I had no idea sealed boxes were a thing so I appreciated the information.
  19. Feb 20, 2022 at 3:07 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    If you already have a good Lead acid why not buy the $80 sealed box. Upgrading and doing it right opens up a whole other can of worms with having to upgrade alternator stuff to charge them properly. When 80 bucks and your already good lead acid is a lot cheaper and quicker install. Not to mention later down the road you don't have to spend a min. of $220 bucks on an AGM or the like battery when it's dead.
    And yes I was picking apart what you said because it was total bunk what you were implying.
  20. Feb 20, 2022 at 3:14 PM
    ovrlndkull
    Skip
    Burlington, NC
    2005 DCLB Silver
    EatSleepTacos[QUOTED] likes this.
